Amps and volts
Corn Cracker
Amps and volts
Post by Corn Cracker »
After the discussion on grain mills and power supply, it got me thinking about the 6500w element I ordered for my steam and 3 inch setups that should be here tomorrow. After a little research, im reading that my wire size will need to bump up from 10 to 8awg?? And I'm not sure, off the top of my head what size breaker i replaced the other worn out breaker with but I might need to upgrade it to 40a as well. So it seems spending a couple hundred on upgrades is going to cost me another hundred or so in system upgrades before i can use them.
I think I'll go home and fire up my still, it might not make me feel better but, I bet it will
Bolverk
Re: Amps and volts
Post by Bolverk »
Yeah you'll need 8ga wire at a minimum. If its a long run from the panel you want to go 6ga.
Watts/volts=amps
Amps×volts=watts
So you have a 6500w element and in order to run that sustainably you want 20% more than that so that works out to 6500+1300=7800w
7800/220v=35.5a
So yes, you'll need a 40a breaker
Edit to add:
You can run 6500w on a 30a circuit BUT you have no head space and your cutting very close to the max of that circuit. This is risky and does not follow electical code. Fire risk, burned wires... definitely not advisable.
Tammuz
Re: Amps and volts
Post by Tammuz »
Yep Ohm's law will help you figure out any of your electrical questions.
Igitur qui desiderat pacem, praeparet bellum or party till the cows come home!
Windy City
Re: Amps and volts
Post by Windy City »
You should check the actual voltage at your location.
It seems everyone always calls it 220v but around here (Chicagoland) it is actually 240v, two 120v legs.
My house will range from 238v t0 244v depending on time of year and demand.
Salt Must Flow
Re: Amps and volts
Post by Salt Must Flow »
You could go with a 5500W element, use a 30A breaker and 10 AWG wire.
NorthWoodsAb
Re: Amps and volts
Post by NorthWoodsAb »
It never hurts to go 1 size larger on wire anyway, especially if it a longer run, as Bolverk mentioned. Saving a few bucks on "what will work" and have an end fry off really saves nothing. I've been anal about going up 1 size if there is any question at all about load capicty, for years. People ask me why my extension cords ar so big. I'll say that cord is 10, 15, 20 years old. How many cords have you bought since I built this one?
Uisge beatha
Copperhead road
Re: Amps and volts
Post by Copperhead road »
NorthWoodsAb wrote: ↑Thu Feb 12, 2026 2:36 pmPeople ask me why my extension cords ar so big. I'll say that cord is 10, 15, 20 years old. How many cords have you bought since I built this one?
Sorry for off topic.
Do you make your own extension cords ?
NorthWoodsAb
Re: Amps and volts
Copperhead road wrote: ↑Thu Feb 12, 2026 2:51 pm
Yes Copper for my power tools and outdoor use. Our cold temps break up cheaper vynal covered cords rapidly.
Uisge beatha
fzbwfk9r
Location: Smack Dab in the Middle of God's country. Saskatchewan!
Re: Amps and volts
Post by fzbwfk9r »
I always try to go up one size copper. buy once/cry once, and gives me peace of mind when loads are running near max limits!
