My first runs at home
MattHoll
Post by MattHoll »
Hey folks.
I did my first spirit runs on Sunday, two of them, and it took 16.5 hours. Oh man.
My new setup showed up on Thursday, and I soaked the still in 50/50 vinegar/water overnight. Then Friday I did a vinegar run and water run after that to steam it out. Saturday morning, I used foreshots from a craft brewery to do a sacrificical run. At the beginning of that, I fiddled around with the setup to make sure everything worked. I found the threshold for how far I can turn down the Digiboil 35L (220v version) before the electronics stop working. Just gotta keep it above 110V, which worked nicely for the spirit runs later. Then, during the sacrificial run, after familiarizing myself with everything, I cranked it up with both heating elements at 2400 watts, and did it as a stripping run. Distillate was clean with no blue.
Then Sunday, I got started at 5:30 am. Sunday’s runs were all tails that a craft brewery gave me. The first run was 26.5 liters in that 35 liter boiler, at about 18.7% abv. I dropped a dollop of butter in there for anti-foam. Foreshots came off at ~77% abv. I collected about 220 ml in 250 ml jars for much of the run, though switched to about 500 ml in 540 ml jars for the middle of the hearts and for late tails, since I won’t be using those in the blend, just saving those feints. I’ll do the blend this evening, but took notes as I went. I labelled the foreshots XXX, then after that, from 1, and upward. The cut point from heads into hearts seems to be at jar 6, but I left the jars to air out and will see what I think tonight. Jar 6 is 75.2% abv. After that, I had a mix of those two jar sizes. And notes from last night say that maybe the cutoff for tails is after jar 23, which is 59.5% abv. Again, I’ll see tonight.
That first run took 8.5 hours. To get to dripping coming off the still was something like an hour and twenty minutes, hour and a half. I collected down to 11.6%. I ran off pretty slow throughout until I got to later tails, then I sort of just stripped it to collect those feints. 39 jars total, the last of which were collected in 540 ml jars. You can see in this picture below. It looks like the small jars have blue distillate, but that’s just the glass. Compare to the empty jars in the back at the right. Same tint. The larger jars have no such tint. Guestimate for final volume collected, counting foreshots and feints: 11.4 liters out of 26.5. the section that *might* be in the blend is around 4.6 liters, though I could change my mind tonight when I sit down with a fresh nose and mouth for tasting.
For the second run, I did mostly the same, with slight tweaks from what I learned the first time around. I collected more of the hearts in larger jars. At the border of heads/hearts, I collected in those smaller jars, but only up to 170 ml or so, so I’ll have more fine tuned control over that border to decide where to make the cut. And I did the same with the hearts/tails border.
The second run was done after lunch and a half hour nap. Old man. Heh. That one was a liter more at 27.5 L, but I forgot to measure the abv of the blended tails. Probably around the same, though, since they come from the same demijohns. Because the volume was slightly higher, I kept an Eagle eye on it early on to watch for puking. I don’t yet have a sight glass (an upgrade for later when I can spend the $), so kept it low and slow and watched that runoff. No problems, though. Clean runoff throughout. Foreshots came off at 76% abv, again labelled XXX, then the jars are numbered from 1 on up. Jars 4-6 were collected at smaller amounts of ~170 ml. I noted that 4 was still heads and 5 might be late heads/early hearts, while jar 7 is full-on hearts, after which I switched to 500 ml collections for 2.5 liters. In the second run, the tails *seem* to have shown up earlier. They smelled nice, but in the mouth, I got that cardboard taste. I’ll see tonight when I taste them again. I noted jar 14 (66% abv) as late hearts and jar 15 as early tails. This blend might only be 3.5 liters.
But, I intend to age this in an actual barrel (figure I'll wax it to ease angel's share, then check it frequently to see what's going on), and from what I’ve read *some* tails in the blend becomes nice after aging. Any insight into that is welcome. For the second run, I stopped collecting at 17.8%. A bit higher, but after more than 16 hours of doing that in one day, I’d had enough and wanted to go to bed.
The jars were covered with coffee filters and are in my beer room where my cats can’t fuck with them and knock them over.
I cleaned out the boiler and noticed that the butter residue had a green tint to it, presumably from interaction with the copper. Anybody experienced that? Google gives some info on this, but it sounds like something that wouldn’t make it into the vapor. I haven’t heard of that, though, so any input on that is welcome.
Anyway, there you have it. My first two runs.
Re: My first runs at home
Hee hee , looks like a KKK convention :ebiggrin:
Don’t need to worry about Butter and pukes on a spirit run . That only happens on a stripping run .
I don’t get waxing a barrel . The whole purpose of a barrel is letting the air in and the heads out . But then again , sounds like you ended up with a bunch of tails to distill so probably not much heads in it anyway .
Digging deep into tails has never served me well . Filk recon they age out , but in my experience that could take 6-8 years .
I guess there is a reason Scotch whisky is best after 8-12 years .
MattHoll
Post by MattHoll »
Yummyrum wrote: ↑Mon Mar 16, 2026 1:21 am Hee hee , looks like a KKK convention :ebiggrin:
Wax: I'd only wax a portion of the barrel to reduce the aeration, not cut it off entirely.
Tails: I won't use much in the blend. Those will mostly go in the feints jar. I'm curious about using early tails that are right on the border with hearts, not the deeper tails. Those are terrible.
Sounds like a sound plan MattHoll :thumbup:
MattHoll
Post by MattHoll »
Yummyrum wrote: ↑Mon Mar 16, 2026 1:40 am Sounds like a sound plan MattHoll :thumbup:
Thanks, and thanks for letting me know I don't need anti-foam for a spirit run. I was worried if the late tails used in this run would foam up, and can't see into the boiler. I'm used to making beer where I can watch for boilover.
For the wax on the barrel, I figure it's sort of like those Bad Mo barrels blocking off all but one side so it doesn't get too much surface contact with wood at the reduced barrel size. If I generate enough of a blend, the plan is to do it in a 20 liter barrel, though, not a smaller one. I'm hoping partial waxing will do the trick, but will monitor it closely and see. If I end up doing that, I'll be sure to post results.
bilgriss
Post by bilgriss »
Puking is mostly related to proteins in the original ferment and a the first part of a stripping run before they have been boiled sufficiently. Pretty much none of that stuff will carry over to low wines (unless you have lots of puking), and you'll see none of it in heads or tails from a spirit run.
PalCabral
Post by PalCabral »
Did you ferment to 18% and only run a spirit run, or was the 18% charge from a stripping run? I didnt really follow.
MattHoll
Post by MattHoll »
PalCabral wrote: ↑Mon Mar 16, 2026 3:46 am Did you ferment to 18% and only run a spirit run, or was the 18% charge from a stripping run? I didnt really follow.
I was given 150 liters of tails by a local craft brewery, and 15 liters of mixed foreshots and heads. I forgot to mention, each run had 1.5 liters of that foreshots/heads as MooseMan recommended, though I didn't use any of the 20 liters of backset they gave me this time around. I have four more runs like this to do.
MattHoll
Post by MattHoll »
I did back-to-back blending of the whiskey after it sat to air out for a day. Each run produced about 11.3 liters or so, something like that, so around 22.6 liters, of which right around 7 liters made it into the blends, so a bit less than a third.
Here's how I set up, with all the jars lined up. I spit everything out until I was done, then sampled each and they're pretty nice. I used eye droppers to pull samples from each jar, proofed down to 35% abv or so, smelled, tasted, breathed through it, coated my mouth, then spat out. This was a mostly-tails run, and the border between hearts and tails was pretty distinct. Not a transition, but more of a BOOM, now you're in tails with wet cardboard character. And there were a ton more tails than heads, including getting into that butyric baby vomit thing. Anyway, in this set up you can see the whiskey glasses I drank from, water to mix, water to drink, printed out notes with percentages of each jar, etc.
And here's the final yield. 5 liter jars with PTFE wrapped gaskets. Total just under 7 liters, one with maybe 200 ml more than the other. One 67%, the other just over that, but the hydrometer is touching the bottom,not flloating, so I'm not sure exactly. Next time, I'll switch to 4 liter jars, figuring I'll likely again blend to ~3.5 liters. These won't age on wood yet, but will await an oak barrel I'll order this week.
MooseMan
Post by MooseMan »
Nice detail Matt and great write up of your process.
Stuff like this is really useful for others to find, coming along behind you on your journey.
So you got a pretty decent yield there, considering you are running someone else's so called "Waste" and will continue to benefit from it for quite some time.
Will be interesting to hear what the difference is in the product, without any of the fores/heads added next time, I assume that is what you're planning?
Once you've decided which blend you prefer to distill with, you can also start to keep a "Heart of hearts" cut, just a few 100mm from each run of the very cleanest from the middle of the run, that's nice to keep white for an instant, simple and approachable sipper while you age the rest.
Look forward to the next brief!
MattHoll
Post by MattHoll »
MooseMan wrote: ↑Tue Mar 17, 2026 11:06 am Nice detail Matt and great write up of your process.
Thanks for the advice. And yes, I'll do what you recommended in my other thread (and here). So, the total of those 150 liters of tails and 15 liters of mixed foreshots/heads, will take six runs. I did the first two runs with those foreshots/heads in a tiny percentage of the run. The next two, I'll do without those, just the tails. And I'll see which I prefer, and do the last two accordingly. Then, I might well run all the feints from those six runs, as there'll be a ton of it, likely 48 liters or something. Will see. Might even strip those then do a spirit run to clean em up a bit.
For hearts, yes, that's my intention. I think from the next runs I'll put aside a small amount of each center hearts section, like 125ml, and collect ~500ml from those next four runs, for me to drink white, with no oak aging. I'm learning the process, the tastes, my preferences, and all that, so it'll help me soak up the knowledge if I do a broad set of things like that.
Thanks again for your input. It looks like Friday, I might well do a run with old mead. I have 14 and 15 year old mead made with Rosemary honey and Chestnut honey. The meads are in great shape, but the corks are rated to eight years, and I don't drink much of the stuff, and one cork is looking iffy. So I figure I'll rescue them with distillation before they become vinegar. 29 bottles total, so about 21 liters. And these were no boil meads, only honey (lovely honey, straight from beekeepers), and came out quite nice at 16.5% and 17% abv. They're aged and have some oxidation that's nice. I'll be curious to see what happens there. I stood the bottles up yesterday so they can settle. Then, Friday, I'll pour them through a sieve and be gentle to not pour the lees, and I figure I'll do a low-and-slow run. No stripping run, I'm thinking. Just slow, with a lot of small jars. I have 72 of the 250ml jars, so might just use those all the way through and stay a little tight, but maybe some small amount of late heads if they're floral/honey. Will see. Then, I intend to use the mead backset to create a dunder pit (well, in a glass demijohn. I won't use a bucket.) and innocculate that with dregs from two bottles of Lambic, let that go wild for a year or so with occasional feedings of sugar for the bugs, to use in a rum next spring or summer. We'll see. That's the thinking at the moment.
MattHoll
Post by MattHoll »
I did the third run of these feints yesterday, and ran only tails for this run. The early part of the run was much cleaner. Hardly any harshness even in the first jar, but I still dumped the first 220-230ml into the foreshots jar. Jars 2 and 3 were actually pretty nice, but I didn't add them to the blend. Jar 4 made the cut, though. I think on the previous runs I cut at jar 6 or 7, something like that. So, not adding the mixed foreshots/heads compressed the heads on the run, which makes sense. The tails started showing up around jar 15, collecting 230ml (though I had two 500 ml jars during the hearts). I kept up to jar 19 for the blend. After that, everything was dumped in with the feints. I switched to 540ml jars for later tails around jar 25 or something, and collected up to 35, and went down to 3.5% abv. I was cleaning up anyway, so just let it run and kept and eye on it. I collected about 11 liters off a 27.5 liter run, and have about 3.25 liters that made it into the blend. This run was all tails, though, so the numbers may look weird to folks. Hell if I know. At the end, after all these runs, I'll have a lot of feints to run as a feints-of-feints run. I guess that's the Princess Run if the initial run was the Queen's Run.
MooseMan
Post by MooseMan »
Yes that totally makes sense Matt, there should have been very little to almost no heads volatiles since what you were running was what had been previously cut at the end of a run as tails.
It remains to be seen if the product will actually taste better than the one distilled with heads though.
Try some of both white in a taste comparison, and you might get an idea if you have a preference.
Try tasting at 35abv and hand warm, that should bring out the most flavours.
Once you've run it all once, you could plan a "Neutral" run with those combined feints to get a base spirit for some gin maybe.
MattHoll
Post by MattHoll »
MooseMan wrote: ↑Mon Mar 30, 2026 12:35 pm Yes that totally makes sense Matt, there should have been very little to almost no heads volatiles since what you were running was what had been previously cut at the end of a run as tails.
Thanks for replying, MooseMan.
I've been doing my tasting at 50/50 RO water/spirit, and the spirits are at 62-67% or so, so I'm drinking under 35%. I figure I'll do all the runs, let that last one sit a week, then compare them. Then I'm going to blend them and slowly proof them down over a couple of weeks, and let them sit to marry before transferring into an oak barrel I'm currently seasoning with port and sherry. That's the intention, anyway. I'm not into neutrals and loathe gin, so won't be going that route. This one, I intend to age in that oak, longer term if it doesn't get over-oaked. But I'll keep an eye on it. Or keep my taste buds on it, anyway. I might do a sort of quasi-solera with that barrel. So, when it seems like it's about ready, pull 25%, around 5 liters, and top up that barrel with whiskey from a fresh run. Then, with the 5 liters I pull, split those into a series of jars. Keep one as-is, then try out different finishing woods with the others, so I can compare and learn from it. At least that's the current thinking, which may well change further down the line.
Tammuz
Post by Tammuz »
Curious what type of beer was given to you and what yeast did you use? Never made beer before, never realized they also take cuts.
Igitur qui desiderat pacem, praeparet bellum or party till the cows come home!
MattHoll
Post by MattHoll »
Tammuz wrote: ↑Wed Apr 01, 2026 8:57 am Curious what type of beer was given to you and what yeast did you use? Never made beer before, never realized they also take cuts.
I wasn't given beer. That brewery makes whiskey once a year. They gave me 150 liters of tails and 15 liters of foreshots/heads. Their house yeast is US-05, so probably they used that. But they brewed a whiskey wash, not a beer. Then they did stripping runs and two spirit runs to yield ~800 liters of spirit.
