new old guy
rayray
new old guy
Post by rayray »
this is my first post that is seeking advice..I've been distilling for about 2 years and trying to figure out my own problems not trying to be a bother to others. all ways trying to figure out newer faster out of the box way and means to an end. My latest and greatest escapade is to mash in store bought hominy with cracked corn for my mash. I usually mash in 5 gal buckets and have a 5 gal stainless homemade.. i have about 24 runs in and have made my share of mistakes without any life altering hic ups. my current massh is about a half gallon cracked corn a gallon of hominy ground into a meal through a meat grinder 5 lb sugar and about 4 gal of water.. SG 1.060.. the mash water is white like milk thick and was slow to start fermenting actually had to repitch DADY yeast. it is working but not a very vigurous it has a smell that compares to a stale toilet my initial thoughts on using hominy was no husk, all the starches would be exposed for conversion..The hominy was in a brine type liquid could this be effecting my ferment..iI drained the brine off also ive read that pickling lime and citric acid can be used to stip the husk off corn for hominy maybe that is the problem..
subbrew
Re: new old guy
Post by subbrew »
I would definitely check the Ph. Hominy is made using a caustic to remove the corn husks. It is rinsed after that so the caustic should be removed but still probably has an alkaline Ph.
Your SG sounds a little high. Without any enzymes the cracked corn and the hominy are not adding any sugars, there is nothing to convert them. I wonder if the starches from the ground hominy is not adding some density to the water and causing a higher SG than what the actual sugars warrant.
I would also look at adding some yeast nutrients, some DAP. Many people use boiled yeast as well. A lack of nutrients and a Ph out of the yeast happy zone of 4.8 to 5.2 could definitely cause a slow ferment.
rayray
Re: new old guy
Post by rayray »
I added alpha amylase and gluco at the beginning and threw in some brewers yeast Haven’t checked ph.
