Remove tannins from the wood before flavoring
- Demy
in this post I'm not talking about the noblest method for flavoring a distillate but about "fast" flavoring if you can define it that way.
I would like to ask the forum: do you know any simple methods for removing tannin from wood before immersing it in the wood? I was thinking about boiling the wood before toasting but I don't know if it's a good idea... Basically: boiling the wood - toasting in the oven - immersion in the distillate. Any intervention is well accepted.
- PalCabral
Re: Remove tannins from the wood before flavoring
Hi Demy. Here is a long thread discussing how to leech out tannins from oak before aging. https://homedistiller.org/forum/viewto ... 2&start=60
The quickest and easiest way is to buy firewood of the right species that was cut with sap down and stacked outside in the weather.
Time, plus rain and sunshine works wonders on wood.
You can try boiling wood before toasting but I don't know how well it will work.
- Demy
thanks for your suggestions. I've used old firewood before but it still had a certain amount of tannin...so I thought that in addition to natural aging, boiling might help.....
- Demy
Great post, not so far from my idea.....PalCabral wrote: ↑Sun May 03, 2026 1:25 am Hi Demy. Here is a long thread discussing how to leech out tannins from oak before aging. https://homedistiller.org/forum/viewto ... 2&start=60
Maybe boiling will remove tannins but I'm wondering will it also remove some of the good characters?
I haven't a clue since I've never tried it. Long story short go for it and keep us updated on what you learn.
Toast some boiled wood and compare it to normal toasted wood to see if it makes a difference in the vanilla aroma we love.
Here's a thought.
Start with several sticks that are equal and cut a small groove in half of them for identification.
Boil the marked wooden sticks, remove and let dry.
Toast all the sticks until the vanilla aroma appears, remove from the toaster oven and sniff each stick to see what you like.
If boiling doesn't hurt the aroma, put all the split sticks back into the oven and turn the heat up.
I figure at some point higher temps will make the tannin become acrid and easy to identify for comparison.
- Tammuz
You might steam some for a little longer then boiling. It will pull out some of the water soluble tannins also, but it would open the pours more.
Igitur qui desiderat pacem, praeparet bellum or party till the cows come home!
- Demy
All excellent advice....as soon as I have some free time I will do some experiments....a long time ago I had tried boiling on already toasted wood but as is obvious the opposite is better (first boiling then toasting), in the meantime if anyone has tried it would be nice to know the results.
