Nasty smell and mold on my crushed oystershells.
Osse87
Post by Osse87 »
When I'm done fermenting I'm lazy and keeping my shells in their bags which I submerged in the wash. Post ferment I give them a steam bath (no rinse in water before, only let them drip over the fermenter until they stop dripping) and store them away in a somewhat ventilated place and this has worked a few times before. This time within a few days they developed a nasty smell (was close to puking when I noticed where it came from) and quite a bit of mold on them. Now I've given them a thorough rinse/wash and I'm doing a steam bath again. Anybody experienced something similar and are they safe to use for fermentation again? I dont want any nasties follow over to my product.
8Ball
Re: Nasty smell and mold on my crushed oystershells.
Post by 8Ball »
I bought a 50 pound bucket of crushed shells for $10 several years ago. I sanitize a quart at a time to use as needed. Toss in the compost pile when done fermenting. Never have a problem like yours.
Tammuz
Post by Tammuz »
Boil them
Igitur qui desiderat pacem, praeparet bellum or party till the cows come home!
PalCabral
Post by PalCabral »
I use mussels shells, but I guess it's pretty much the same same. I put the crushed shells in a hops bag, which has been boiled before use. Then it's dropped into the ferment. That's it. When fermentation is done and I rack to the boiler, or to a secondary, the bag is pulled out. I empty the remains in the garbage and clean the hops bag. Crushed mussels shells cost nothing, not need to reuse.
Osse87
Post by Osse87 »
Thanks guys, the pH drop is quite violent where I live and I need to use a lot of shells to counteract the drop, it would be rather wasteful to toss the large amount of shells I need to use every time I ferment and I would need to buy a lot of new shells. I want to try again with the ones I have (if anything I will learn they will spoil my next wash). I'm gonna think about boiling them rather than doing the steam bath inside a kettle, but they reach around 205F so I would guess its sufficient to kill any bacteria that a boil would.
I'm also using hops bags like you PalCabral, they are perfect for it.
PalCabral
Post by PalCabral »
Osse87 wrote: ↑Wed May 06, 2026 9:41 am Thanks guys, the pH drop is quite violent where I live and I need to use a lot of shells to counteract the drop, it would be rather wasteful to toss the large amount of shells I need to use every time I ferment and I would need to buy a lot of new shells. I want to try again with the ones I have (if anything I will learn they will spoil my next wash). I'm gonna think about boiling them rather than doing the steam bath inside a kettle, but they reach around 205F so I would guess its sufficient to kill any bacteria that a boil would.
I also live in a place where you need to be careful about the PH drop, especially during spring (no idea why that is but experience guides me). I bought my crushed mussels shells at the local feedstore, 15kg or so at 10 bucks, about a year ago and the bag is still half full. For a 50 liter ferment I use 3 or 4 fistfuls, ie 5-6 tbls. It'll take me a year more to get through the bag, probably more. Not sure about your volumes, are you sure you're not overdosing your oyster shells? I assume that they get consumed as they are needed. If your hops bag still contains crushed shells after fermentation, my guess is that not all of it is needed. Maybe use less and keep more for the next batch? :)
There are other ways to keep the PH from dropping. When I make sugar/rum washes, I also use CaCO3 to add more PH buffer during mashing (grains) or before fermentation (sugar/fruit). It's also good for my local water so the addition it's a pretty simple option. Guarding the PH during fermentation and adding slaked lime when needed is another alternative, but for me it's too much work. I only react when things have gone wrong (unfortunately).
Salt Must Flow
Post by Salt Must Flow »
You just need to thoroughly rise it before setting them out to dry.
For mold and stench to occur I have to assume there was residual mash or wash in the shells. You can steam it, but that won't stop mold & bacteria from growing due to the residual. Once it's thoroughly rinsed, there won't be anything left behind for mold or bacterial to thrive.
The worst sugar wash infection I've ever had was due to reusing crushed shells.
The ferment smelled like a lead acid battery that was being overcharged. :lol:
Osse87
Post by Osse87 »
PalCabral wrote: ↑Wed May 06, 2026 11:38 am
I'm using very roughly around 6 kilo's of crushed shells (I haven't weighted it, it's just from my estimation) for about 120 liters of wash. Almost everything is still in the bags post ferment. It does not prevent the pH to drop to around 3.4 before coming back up again. I can't find a source of slaked lime or CaCO3 easily so I'm relying solely on shells as for now.
Sounds like I should try some other ways to fix the pH drop. would be nice to cut down the amount of shells if I can prevent the drop and use the shells more as a buffer.
Osse87
Post by Osse87 »
Salt Must Flow wrote: ↑Wed May 06, 2026 12:31 pm You just need to thoroughly rise it before setting them out to dry.
The ferment didn't ferment dry, you're right. Quite a bit of sugar left. That's probably why it was working before with better attenuation but not this time.
Button
Post by Button »
The way I do it, not saying it’s the best. Just it’s what works for me. Collect shells from beach, rinse them with water hose, toss them in the mash/wash whole. Over time they breakdown so I have a mix of ‘crushed’ with some whole ones. I recover the shell and give a quick rinse. The large pieces are laid out dry or promptly put into next mash/wash. Small pieces are tossed into the chicken coop as a calcium supplement. This process works for me. Get to spend time beach combing, end up with liquor, and chickens get calcium with minimal effort. I have never had my shells go moldy. I’d suggest you rinse them better and lay them in the sun for a day or more. The sunlight will not hurt them. I leave many a shells outside in the sun, just rinse them before dropping in mash. It’s also interesting to watch the progression of large oyster shells dissolve away.
Crushed shells will have a bigger impact on ph due to larger surface area. If that is an issue just use more whole shells. Just gotta find a system that works for you that’s reliable. Oyster shells is not the only solution to a ph drop. You can use other materials to combat the acidity.
Osse87
Post by Osse87 »
shadylane wrote: ↑Wed May 06, 2026 2:02 pm The worst sugar wash infection I've ever had was due to reusing crushed shells.
Fortunately for me the wash was unaffected by this, it was just the shells post ferment :wink: I hope that after a thorough washing of the shells and a steam bath for an hour or so they are good to go again, I'll keep an eye/nose on them before next ferment to see if they develop mold or smell once again!
My 2 cents worth.
Shell grit is dirt cheap and almost sterile because there's nothing for bacteria to eat and it's dry but if reused....
Bacteria would love multiplying @ 8ish pH, living off fermentation residue and just waiting for the chance to fuck up the next batch. :shock:
If calcium carbonate from crushed shells isn't effective enough and you need too much, try adding a small amount of calcium hydroxide, also known as slaked lime.
MooseMan
Post by MooseMan »
As the guys have suggested, they need to be physically cleaned to get rid of anything clinging to the surface, steaming will sanitise, but not clean. Just steaming then leaving them in a bag to drip is asking for trouble. There will be puddles of goop, which is a bacteria buffet!
Sounds like your water has no buffering capacity.
I'd suggest you start using a combination of fine crushed shells and whole.
Keep a note of how much of each you add, what's left at the end and you'll be able to fine tune it to your needs.
The fine crushed will absorb faster, giving early buffering, and the whole will help to keep the pH more stable through the rest of the ferment.
Osse87
Post by Osse87 »
MooseMan wrote: ↑Wed May 06, 2026 10:04 pm
I'm gonna get my hands on some calcium carbonate and hope I can lower the amount of shells, grinding them is hard work! I'd like to get some calcium hydroxide too, not sure it's available in manageable sizes tho. Thanks for the suggestions everyone!
MooseMan
Post by MooseMan »
There's no need to buy any crazy expensive or highly base chemicals Osse, you're more likely to get things wrong with these unless you understand the pH process and have a reliable meter.
Just get some shells and shell grit/CC granules (Or bash up some shells, no need to grind!) and work out what your ferments need by trial and error.
Once you have worked out the amount of fine calcium you need to help your water buffer, you'll be able to just drop a couple of shells in as insurance then fish them out at the end and hose them off for next time.
Salt Must Flow
Osse87 wrote: ↑Fri May 08, 2026 11:23 am
You don't need to get powdered Calcium Carbonate, but you can if you want to. I mostly do sugar washes, which are very susceptible to big and fast PH swings. I suspend a big ol sack of Marble Rocks/Marble Chips half way into the fermenter and it has worked perfectly. It dissolves and uses as much as it needs to buffer the PH. Once fully fermented I remove the bag, rinse it thoroughly and set out out to dry.
I found a bunch of bags of Hydrated Lime (Calcium Hydroxide) at a local hardware store in the garden section. Any place with a decent horticulture section should have it. It was on sale during the off season so I bought a bunch real cheap. A little bit goes a VERY long way. Add just a little bit, mix thoroughly and test the PH. Add & test in increments. You can also buy Mrs. Wages Pickling Lime (calcium hydroxide) in any store with a canning section.
Archee72
Post by Archee72 »
Leave your oyster shells in a bag in your freezer. Most Aussies have a beer fridge in the shed, mine is a fridge/freezer so I leave mine in there. Takes up bugger all space.
Which side are you on Boy? Which side are you on?
