Thermo pot 80L - possible mash, ferment and pot still?
PalCabral
Post by PalCabral »
Hi guys.
I have the opportunity to buy a thermo pot of 80L (21G) on the cheap'ish. Initially I thought this would be a way for me to increase my mash size. The mash tun can easily do 60-70l (15-18g) mashes and the pot is double walled so it only loses like a degree C per hour. The lid's got hinges so it keeps well tight. Down side is that it doesnt have a heater so I would have to heat the water somewhere else. Not a biggie but it is what it is, my distillery isn't a football field. I would really like to hear endorsements or warnings about this type of tun from peeps who have or are using them.
However, then I started thinking if this tun couldn't be turned into a boiler? The size is a step up for me, it's got hinges and the lid is heavy. But the double walls make it not suitable for gas heating (I think), and I don't know the work involved to make space for two tri-clamp ferrules. The same with making a 4 inch connect on the lid for the riser. The metal is SS of course. I reckon double walls are more work than single sheet SS if I wanted to "weld" (not sure about the lingo, sorry) a port and a ferrule?
Is it worth it? Or should I just look at the tun as a mashing vessel and nothing more?
Username
Re: Thermo pot 80L - possible mash, ferment and pot still?
Post by Username »
Is there insulation between the walls or just an air cavity?
I've seen both in this style vessel
PalCabral
Post by PalCabral »
Not sure but I believe it’s got something considering how well it keeps the temp.
BigSwede
Post by BigSwede »
Wow... if the price is right, even if never converted to a boiler, it'd be a nice addition. Looks like a quality bit of kit.
If there's insulation foam or the like, converting it to a boiler might be impossible. With just air between the walls, you'd still have to breach into the inner portion with a tri-clamp stub, and solder both walls for a leak-tight seal.
I'm trying to think of some way to steam heat it, and my experience there is nil. Hope others might have some ideas. I'd be all over it if reasonably priced.
Salt Must Flow
Post by Salt Must Flow »
BigSwede wrote: ↑Mon May 11, 2026 11:47 am Wow... if the price is right, even if never converted to a boiler, it'd be a nice addition. Looks like a quality bit of kit.
He could use a Tri-Clamp bulkhead fitting for the heating element. That way he wouldn't have to solder or weld which could harm the insulation.
zach
Post by zach »
If you use the boiler you already own, as a steam generator, then using this pot for distilling is possible. I would outfit the lid with a couple of tri clamps, one for a condenser, and another for a steam injection wand, and you are on your way without molesting the sides of this pot.
PalCabral
Post by PalCabral »
zach wrote: ↑Tue May 12, 2026 5:44 am If you use the boiler you already own, as a steam generator, then using this pot for distilling is possible. I would outfit the lid with a couple of tri clamps, one for a condenser, and another for a steam injection wand, and you are on your way without molesting the sides of this pot.
It’s an interesting suggestion, Zach. It would enable me to use it both as a mash tun and retort (or whatever is the correct name for it. I was considdring a steam set up a year ago but after much planning I realized I dont’t have the necessary space in my distillery for it. The lid is insulated too, btw.
MooseMan
Post by MooseMan »
Man that's a nice vessel I'd have to have that if it's a good deal.
I really like Zacks idea too.
But, what does the underside look like? :think:
PalCabral
Post by PalCabral »
MooseMan wrote: ↑Wed May 13, 2026 10:10 am Man that's a nice vessel I'd have to have that if it's a good deal.
It's double walled the whole way round. I asked the seller if he'd heated it with gas flame and he said it couldn't be done because of the double walls. He was using an immersion heating fork at 3.5kw. It had "lip" of about 2cm deep along the edge.
MooseMan
Post by MooseMan »
Ah that's a shame I was gonna suggest one of the tea urn type elements for the underside.
Probably the only sure way for a fixed element then, is with a bulkhead fitting, but there's a risk that the back of the element could melt the insulation where it goes through.
Sorry if I’ve missed it , but is there actually any insulation ( IE injected foam or polystyrene ) in the space between the inside and outside that is it just an air space like those insulated drink bottles ?
This could change the approach .
PalCabral
Post by PalCabral »
Yummyrum wrote: ↑Wed May 13, 2026 1:12 pm Sorry if I’ve missed it , but is there actually any insulation ( IE injected foam or polystyrene ) in the space between the inside and outside that is it just an air space like those insulated drink bottles ?
The seller says it is. And if it loses less than 1C per hour, I think it must have foam or similar. I’ll try to find the manufacturer.
Edit: the add where the seller bought the pot only says ”double walled with insulation” but not with what material. It also says it cant be heated from the bottom.
Hmmm ….non the wiser then .
My thinking is around the issue of movement between the inner and outer layers . So say you bored a 1.5 or 2” hole right through the side to fit an element . If there was no insulation , then I would doubt that a bulk head would create a good enough seal as when you tightened it , the inner and outer would tend to pull towards each other . This would mean you can’t tighten the nut enough to squish the gasket to seal .
If there was expanded foam , it probably would be rigid enough to work .
But if there is no insulation , just an air gap , that would mean you could solder a tube between the inner and outer to seal it for a standard element with a screw-in or tri clamp fitting . Or a bulk head element .
Another option might be to squirt some sort of caulk in the gap around the hole . When it sets , it would have enough rigidity to allow a bulk head element to tighten and seal .
Salt Must Flow
Yummyrum wrote: ↑Wed May 13, 2026 2:24 pm Hmmm ….non the wiser then .
When using a bulkhead fitting, you could cut away a bit of the outer layer and cut a hole for the bulkhead through the inner layer. So basically to accommodate the bulkhead fitting, the outer hole would be a bit bigger than the inner hole.
Salt Must Flow wrote: ↑Wed May 13, 2026 4:33 pm
Nice :thumbup: ….I like that
In the pic there's already a drain and thermo hole through the jacket, so I'm guessing the insulation survived having the fittings welded in.
That or it has no insulation, which would make it a better deal, since the jacket could be plumbed for steam heat and/or water for chilling.
If it's cheap enough buy it and find out if it can be modded.
PalCabral
Post by PalCabral »
The seller told me the thermometer & spout were mods put in by the vendor. Checked their site and noticed they offer also to mod the pot with this type of heating element. I’m not sure if this give a hint?
I think I’ll call them tomorrow (holiday today here) and ask them if there is any foam or other material inside.
MooseMan
Post by MooseMan »
Yeah deffo call, if they can answer with confidence, then you can plan from there.
Good luck!
PalCabral
Post by PalCabral »
The vendor of these pots got back to me and told me these pots are insulated with a sort of foam. When they are installing heating element and spout on them they are using bulkheads.
Tammuz
Post by Tammuz »
Wet rags,high silver content,small focused tip, should work to solder a tri-clamp fitting on.
Igitur qui desiderat pacem, praeparet bellum or party till the cows come home!
