Structured Packing Quest
BigSwede
Post by BigSwede »
The recent threads on multi-column reflux rigs and the many threads about column packing had me geek out a bit and do more research.
Almost all of us use what are called random packings. Scrubbies, scoria, Rachig rings, SPP. Stuff gets dumped in randomly, hence the name. The big boys in many industries (distilling liquor? not sure) use what is called structured packing, which I'll call StP for short. This stuff has many efficiency advantages, with the 2 drawbacks being cost and the need for a very even redistribution of falling reflux. If we make it ourselves, it's maybe cheaper, and the reflux redistribution isn't impossible.
Good primer on StP: https://www.chemicalpackings.com/articl ... cking.html
Images of StP are almost all of a huge size. There was one that caught my eye - "Sample lab StP up to 80mm dia."
This looks to be around 2", comes as "biscuits" that slide into the tube. Note the outer strap with outward bent tabs (soldered copper sheet for us!) to channel wall reflux back into the material. Cool! And something one could make. So I've started. I'm probably nuts. :wink:
BigSwede
Re: Structured Packing Quest
Post by BigSwede »
Why? For fun. I like to experiment.
Step one was to investigate mesh shapes, materials, and there are a lot. I figured copper or stainless mesh would be a good place to start.
Step two was to make a miniature die set to see if it was even feasible. I made a tiny one out of 7075 aluminum, just for testing. Any big one for production would need to be steel for durability.
To press any material, the system needed dowel pins:
BigSwede
Post by BigSwede »
I began to press materials. The idea is to create a diagonal pattern on a strip of mesh. A 30 degree angle is called Type X, with a high flow, low pressure drop characteristic. 45 degrees is type Y, longer dwell/mass transfer and a higher pressure drop.
These strips are then placed in alternating order so as to avoid the packing from nesting. Maximizes flow area as well as minimizes channeling.
I tried copper mesh (too soft) and copper sheet (fiddly and it tears)
Then came some SS304 mesh I had. This stuff worked beautifully.
MooseMan
Post by MooseMan »
Oh man, images of work like this makes me really miss having access to a tool room...
Salt Must Flow
Post by Salt Must Flow »
That's a really innovative idea, to try and duplicate that structured packing. I always suspected that stuff would probably have a lower HETP than SPP though because of the amount of air space between the corrugations (in comparison to SPP which is more tightly packed). Can't wait to see how this goes.
Immediately after I ready you say you're starting to make some ... I imagined a 3D printed jig. Then I saw you're machining aluminum! :shock:
BigSwede
Post by BigSwede »
To verify what I thought I was seeing in the many pictures, I cut the long SS mesh into 4 segments, and stacked them as they would be arranged in a 2" or 3" insertable biscuit.
By alternating the angles, they stood proud of each other and made a nice sample wedge just to see if the stuff would stand up.
One of the beauties of this arrangement is that reflux would flow at an angle as it traversed the given biscuit section. You'd have thin streams going in alternate directions, while vapor mixes intimately. At least I hope.
The next step would be to scale up the die. Something 6" wide or so that would accept a strip of SS mesh. Make enough of those. Then, begin cutting progressively longer pieces and stacking them into a 2" or 3" former. From there, big hose clamp to temporarily hold them, and 2 copper bands soldered to secure the bundle. Into the column it goes.
I know I could use scoria, or scrubbies. This could be quite a challenge, and the only way to find out if it is a waste of time is to maybe try it. :moresarcasm:
BigSwede
Post by BigSwede »
Salt Must Flow wrote: ↑Sat Jun 06, 2026 1:06 pm That's a really innovative idea, to try and duplicate that structured packing. I always suspected that stuff would probably have a lower HETP than SPP though because of the amount of air space between the corrugations (in comparison to SPP which is more tightly packed). Can't wait to see how this goes.
I did the SPP machine long ago, and that was one fiddly beast. Once tooled up, this might actually be easier.
That little die setup is hardly bigger than a large postage stamp! Aluminum is fast and easy so as to try and understand geometry and how hard it is to press a section, etc. Durability is secondary. I didn't want to expend effort on a big steel set until I know more. The mesh pressed easily enough, and it should be OK to scale up.
Corn Cracker
Post by Corn Cracker »
Pretty cool, Big! Do you have a CNC machine at home?
I think I'll go home and fire up my still, it might not make me feel better but, I bet it will
Copperhead road
Post by Copperhead road »
Corn Cracker wrote: ↑Sat Jun 06, 2026 1:49 pm Pretty cool, Big! Do you have a CNC machine at home?
+1 very cool indeed!
I’m excited Bigswede 👍
Did the commercial ones use mesh or solid ? Do you think there is going to be any advantage , between stamping from mesh or solid ?
OtisT
Post by OtisT »
Damn Bigswede, this is very cool. And yes, you are nuts, but in a good way. :-).
Looks like a fun project, and I’ll bet it’s gonna work well. Cant wait to see the finished product and hear your results. What size and height of column is this going to go in? Hopefully the same as you use now so you can compare like for like.
I know you plan to solder copper around them. Have you considered stitching them with fine stainless wire?
OtisT wrote: ↑Sat Jun 06, 2026 8:30 pm
I think he mentioned the top edge of the copper bands are snipped into fingers and spread out so they contact the column wall to draw back in any reflux running down walls .
BigSwede
Post by BigSwede »
Thanks Corn Cracker, my machines are manual. I have digital readout, so doing things like die tooth spacing is as simple as moving the table like 0.200" per pass.
Yummyrum wrote: ↑Sat Jun 06, 2026 2:29 pm I’m excited Bigswede 👍
This is where certain theories on this stuff are way over my head! :esmile: It seems that there are mesh varieties, perforated solids, mesh with bigger holes in places, a huge variety of material styles. I'm just going to use some intuition. Making perforations is beyond the scope here. The mesh pressed so well that I think it's a no-brainer.
Coarse mesh (bigger holes) vs finer mesh (smaller holes) - With the segments stacked, it creates angled void channels, through which vapor and liquid can travel and mix. There will be some movement THROUGH the mesh instead of along it, but I think we want the bulk to be along those formed channels. So I'm leaning towards a finer mesh, but not so fine that it prohibits migration through the mesh itself. And a fine mesh creates huge surface area and wetting. Does this make sense?
OtisT wrote: ↑Sat Jun 06, 2026 8:30 pm Damn Bigswede, this is very cool. And yes, you are nuts, but in a good way. :-).
Hi OtisT - First go will be a 2" column, since that is what I'm used to, and it'll use a lot less material than a 3". It's hard to estimate material cost for the mesh. It won't be cheap like scoria, but I don't think it'll be too bad. 304SS mesh rolls are all over the place online. :thumbup:
BigSwede
Post by BigSwede »
Next step - I have some 1018 steel bar stock for the big die. I'm going to cut the die fingers at a 37 degree angle so I can feed mesh strips in straight, rather than angling the raw mesh strip relative to the die. It'll have die springs to open, and I'll tie the top die to my little press ram.
The test die used a 1/4" 90 degree cutter, the big one will have larger "V" shapes, probably 3/8" or 10mm. And I've got some 40 mesh and 50 mesh SS rolls inbound for testing.
Got to plan and draw up the dies. I don't want to make more than one set if I can help it! :D
BALDR
Post by BALDR »
Boy I thought I was a glutton for punishment. That looks like some lost weekends ahead of you. But after looking at prices I understand. I've been looking into buying a sample bag of copper pall rings from Alibaba. If I had the equipment I would do what you're doing with a copper sheet with very small perforated holes.
30xs
Post by 30xs »
Are you set up with a full machine shop? A set of helical gears would allow for faster production speeds.
BigSwede
Post by BigSwede »
BALDR wrote: ↑Sun Jun 07, 2026 6:33 am If I had the equipment I would do what you're doing with a copper sheet with very small perforated holes.
Baldr, I tried copper, I don't think it had the necessary strength once formed. And the cost to fill even a 2" column would be eye-popping.
30xs wrote: ↑Sun Jun 07, 2026 1:36 pm Are you set up with a full machine shop? A set of helical gears would allow for faster production speeds.
:ebiggrin: You and I think alike! I thought of a pair of rollers cut like a helical gear set. 6" wide, hand crank or a slow motor. Feed in a strip of mesh, out it comes fully formed. I could very possibly do straight rollers, not helical. It's an excellent thought. Just have to feed the strip in at an angle. Damn now the mental gears are grinding.
I decided to make dies from a smaller strip of A2 tool steel which would then be mounted onto an aluminum base. Had to order the A2, I didn't have any wide enough. The A2, when correctly heat treated, should last 10X as long as anything else I'd use.
Roo
Post by Roo »
What about herringbone gears? I guess that'd be trickier than helical. But I wonder if that'd avoid the need to feed at an angle?
Windy City
Post by Windy City »
Keeping an eye on this one.
Seems very promising especially for guys running 3" and 4" columns that can't get properly sized SPP
Using gears could really make production fast.
Yeah nice.
Windy City
Instead of copper bands. Why not use the same mesh material (not embossed) and maybe tack weld it together.
If your modules are 6" maybe three bands 1.5" tall with the snipped fingers to prevent channeling.
BigSwede
Post by BigSwede »
Windy City wrote: ↑Mon Jun 08, 2026 7:58 am Instead of copper bands. Why not use the same mesh material (not embossed) and maybe tack weld it together.
I do have a bench spot welder. I'll drag it out and try it on some SS mesh. Might be ideal. Make a mesh ring a hair smaller in diameter than the column, and use that as a former to load with strips,
30xs and Roo on the gearing : That may be the way, so easy once set up. Damn, I can't do helical or herringbone, but I can do straight. A pair of 1" dia rollers that mesh, with adjustable spacing, like a bench roll with teeth. Hand crank. Otherwise it's press, release, press, release, 1,000 times for a biscuit.
Rollers it has to be, and I just dropped $80 for a slab of A2 steel. Oh well, it'll find use elsewhere. :thumbup:
30xs
Post by 30xs »
It would take a pretty wide set of rollers to be able to do any length per strip. I’d think maybe 6-9” long to keep from getting too much deflection. Built like a roller mill. May even be able to fit a roller mill with some custom rollers to save on some of the fab.
Windy City
30xs wrote: ↑Mon Jun 08, 2026 8:47 am It would take a pretty wide set of rollers to be able to do any length per strip. I’d think maybe 6-9” long to keep from getting too much deflection. Built like a roller mill. May even be able to fit a roller mill with some custom rollers to save on some of the fab.
I think the idea would be to use a roller a little bigger than 6" and feed it with a roll of stainless mesh material. then cut whatever length strips you need.
It's a mesh material so it shouldn't need too much force to press/roll
Windy City
I wonder how much a company like this would charge to make these.
https://www.rushgears.com/services/prototypes
I am also going to reach out to a friend of mine that owns a big cnc shop.
30xs
Post by 30xs »
Windy City wrote: ↑Mon Jun 08, 2026 8:59 am
I was referring to width. He had mentioned a 1” diameter, so that would start to deflect if made very long. Aiming for a 37 degree angle it would be short pieces to keep it from running off the rolls. Most helical seem to be 45 degree cut, and stupid on price from my searches.
BigSwede wrote: ↑Mon Jun 08, 2026 8:22 am
Maybe buy readymade helical gears that are 1" wide and stack several of them on the shafts to get the width needed.
I’m thinking a dye like you got but it’s only one corrugation wide .
Sort of press release —-pull —-press release——pull with mechanism timed to grab corrugation and pull it to next position while dye is separated . ……if that makes sense . Would need less pressure than stamping full section at a time and should allow straight feed with no sideways creeping .
BigSwede
Post by BigSwede »
Been thinking quite a bit on the roller possibilities.
Picture a set of 6" straight tooth rollers meshed together with adjustable spacing, one roll fixed, the other adjustable vertically via screws, so as to adjust the gap between the rollers. Like a toothed bench roll.
Now, I've got a long strip of mesh that is 3" wide. I angle it at 37 degrees relative to the rolls, and feed it in as far to one end of the rolls as possible. Start rolling. The strip doesn't travel along the rolls, it pops out formed somewhere North of the starting point on the other side.
I actually drew a long line on paper to simulate the rollers' working contact area, and cut some paper strips to simulate the mesh. Fed it in at an angle, and the mesh occupies (here comes some trig) about 4" of the rollers, the hypotenuse of a triangle. In theory, it'd feed but not move along the rolls, allowing long strips to be processed.
The one thing that concerns me is that a "V" cut in a pair of 8" rolls isn't a true gear form. Yes they'd mesh, but it'd be potentially sloppy and might not make a good form in the mesh itself.
BigSwede
Post by BigSwede »
The plan now is to execute a pair of short test aluminum rolls just to see if the mesh form is acceptable. Same V form cut, same diameter, 1", which is the plan for a pair of 6" or 8" long steel rolls.
I'll run a little mesh strip in there and see what happens. As much as I'd like to go helical, or stack a bunch, I can neither make them, and buying them to stack would break the bank.
A last gasp on the roller concept would be to use an actual gear cutter hob to cut the rolls, rather than a V form. I've done it before, it's tedious but not difficult.
