New HD Equation Calculator
Uncle Jesse
Site Admin
Post by Uncle Jesse »
Just implemented a native wiki extension for real-time equations/calculations tailored toward brewing and distilling.
Try it and let me know what you think. Looking for suggested additions.
Also, this is a work-in-progress so if it breaks or changes, just roll with it for a while.
https://homedistiller.org/wiki/index.ph ... _Converter
Copperhead road
Re: New HD Equation Calculator
Post by Copperhead road »
That Calculator is a great idea and seems to be working perfectly Uncle Jessie.
PalCabral
Post by PalCabral »
Look real good, UJ! Maybe a good addition would be a dilution calculator where the goal is to know how much spirits of a specific ABV and how much water it takes to dilute to a specific volume and s specific ABV.
Uncle Jesse
Site Admin
PalCabral wrote: ↑Thu Jun 11, 2026 9:18 pm Look real good, UJ! Maybe a good addition would be a dilution calculator where the goal is to know how much spirits of a specific ABV and how much water it takes to dilute to a specific volume and s specific ABV.
This has been added.
I think.
PalCabral
Post by PalCabral »
Uncle Jesse wrote: ↑Thu Jun 11, 2026 10:08 pm
I think.
I explained it really poorly, or I am missing it, UJ.
The dilution calc in the current version calculates how much water to use to dilute to a target ABV. However, many times you want to dilute down to fill a bottle or a jar, so you're aiming for a target volume with a target ABV. How much high proof spirit at a specific ABV and how much water do I need to mix to get a target ML and target ABV?
BigSwede
Post by BigSwede »
This is a great addition to our calculator resource. Everything seems to work perfectly.
Many thanks UJ! :thumbup:
Bolverk
Post by Bolverk »
Great tool
Might I suggest and alternative view?
Something like this
Volume of the fermentor × last 2 numbers of desired specific gravity × to percentage of the grain you want ÷ grain points
Common grain/gravity points:
Corn 35
Wheat 35
Barley 35
Oats 35
Rye 27
Example:
10g (fermentor) × 75 (gravity points) × .6 (percentage of grain in bill) = 450
450 ÷ 35 (grain points) = 12.8lbs of grain
So that way when you say i want a starting sg of 1.075 and have this much volume, and want x percent of these grains, these are the weights I need to achieve this mash bill
Uncle Jesse
Site Admin
Bolverk wrote: ↑Fri Jun 12, 2026 3:59 pm Great tool
Something like this
Corn 35
Wheat 35
Barley 35
Oats 35
Rye 27
Example:
go try Grain Bill Mode -> Target O.G.
Bolverk
Post by Bolverk »
Uncle Jesse wrote: ↑Fri Jun 12, 2026 10:06 pm
Thanks ill try that, sorry this post was meant for the new grain bill calculator post
Salt Must Flow
Post by Salt Must Flow »
Hydrometer correction in F, not only in C, would be ideal. Just being picky.
Uncle Jesse
Site Admin
Salt Must Flow wrote: ↑Sat Jun 13, 2026 4:53 am Hydrometer correction in F, not only in C, would be ideal. Just being picky.
Added.
Copperhead road
You’re doing a fantastic job with these calculators Uncle Jesse. Well done 👍🏼
What about a bottling calculator with units option .
Stock ABV ( or Proof)
Desired ABV ( or Proof)
Bottle size ( Liters , Quarts or Gal)
Add this much water .( Litres , Quarts or Gal)
Copperhead road
Yummyrum wrote: ↑Sat Jun 13, 2026 5:59 pm What about a bottling calculator with units option .
That is an excellent idea 💡 yummy.
Uncle Jesse
Site Admin
try it now
Uncle Jesse wrote: ↑Sat Jun 13, 2026 11:34 pm
try it now
Not quite what I was thinking , but that is actually better .
OK so , if I got to fill. 700ml bottle , I just need to tweak stock volume until I get close . :thumbup:
But it also means if I find say 500mls of 75% on the shelf , I can dilute id down to what ever with the same calculator ….nice .
I’ll be using this from now on . :clap:
And thanks for the units . :thumbup:
scubatech
Post by scubatech »
:) The most advanced distilling calc on the interwebs
Uncle Jesse
Site Admin
OK I changed the logic so it's more useful for bottling/aging/storage.
Two modes, proof down existing stock or fill containers.
Here's an example of one.
Awesome stuff UJ
Copperhead road
:thumbup: Your the bomb Uncle Jesse…
You relentlessly improve the Forum day by day!
Awesome work sir.
OtisT
Post by OtisT »
Hi Uncle Jesse. It’s looking good. Thanks for making that.
There is an issue with one of the calculators. The proofing down calculator still has the same bug in it that Rad’s has (The one I have used for years). It may be good to add a note to it so people can adjust accordingly.
The issue is that the calculator is going by volume, when it should be by molar weight to be accurate. Because alcohol is lighter for the same volume, using the existing formula will result in a higher proof than desired (What you entered for the desired target). For example: If you want to proof down a 64% ABV spirits to 40% ABV and use that calc, the resulting spirits will end up around 42%.
I’m no chemistry expert, but have proven that out many times. Someone once explained to me the complexities of trying to make a molar weight calc that allowed us to use volumes. I think they said a calc using volume adjusted for molar weight would only work if you were using the same molar weight each time, which can vary by product (I think that includes spirits with added sugar in them, etc.). This part is over my head, but I can confirm through much practice that the calc here is off.
I deal with this by either proofing twice, and that gets me really close on the second proofing, or if I’m doing my standard barrel strength ABV to 40%, I target 38% ABV and hit close to 40%.
Uncle Jesse
Site Admin
OtisT wrote: ↑Sun Jun 14, 2026 5:25 pm Hi Uncle Jesse. It’s looking good. Thanks for making that.
Well, you are right and you're wrong Otis. You're wrong, it isn't a molar weight value, but you're absolutely right in that ethanol is very anhydrous and does not mix equally with water. This is why the azeotrope max proof for drinkable ethanol is 192 proof. It is so anhydrous that even if your still is 100% efficient, it will suck moisture out of the air to settle at 192 proof.
Having said that, I do not want to integrate the TTB tables at this time - which would give me accuracy. Instead, A note has been inserted into the calculator, so thanks for reminding me of that.
Also, the calculator now not only tells you the volume of water you need to add, but also the weight, which for me is always the easiest and most accurate way to determine a volume of water.
Uncle Jesse
Site Admin
OK folks, because Otis brought it up, the calculator now uses published TTB data and is accurate to 1/10th of a U.S. proof point.
It will now give you the old, not-so-accurate, linear formula value, and actual TTB derived values for water to add and water weight to add.
Yonder
Post by Yonder »
Great job!
Uncle Jesse
Site Admin
OK, since this calculator is so standalone valuable, I have split it out to its own wiki page.
Please test and report your results.
https://homedistiller.org/wiki/index.ph ... Calculator
Uncle Jesse , The fill containers one is missing volume input . It only has stock and desired strength .
Uncle Jesse
Site Admin
Yummyrum wrote: ↑Tue Jun 16, 2026 1:17 am Uncle Jesse , The fill containers one is missing volume input . It only has stock and desired strength .
that's what happens when you do a global search and replace and fat-finger a variable name.
try it now.
Uncle Jesse wrote: ↑Tue Jun 16, 2026 7:56 am
try it now.
:thumbup:
OtisT
Post by OtisT »
Thanks for doing that Uncle Jesse.
The Booze Pipe
Post by The Booze Pipe »
You guys just turned my world upside down
13.5g/50L keg
12,000watts of fury
