My top 5 at the moment
PalCabral
Post by PalCabral »
Season has started although I am not distilling yet, waiting for Saccharomyces to do his thing first, so I have some time to kill. Sitting round waiting doesn't change the fact that I have a few favorites at the moment. And as you do, you count backwards to number 1.
5. Brewing bags with 800 micron mesh. Awesome to work with. Just lift out the bag and let it self-drain. Perfect for corn mashes. No squeeze malarky.
4. My corn grinder. It took a few minutes to grind 9.5kg/21lb of whole corn. What was I thinking I could do it hand cranking the Corona? I must have been nuts.
3. Still Spirits Distiller's Conditioner. Not a single foam up since I started using it. 5 stars stuff.
2. Super Sucker transfer pump. Self-priming, can lift up to 3.8m/12.5ft. Who cares? With a name like Super Sucker, how can you not be on the top 5? ;)
1. Belgrano corn from Portugal. Man, this corn is something else than the feed corn. Small popcorn sized kernels, fruity, sweet, awesome. Can't wait to test the whiskey made from this corn.
What are your top 5's these days, fellas?
Corn Cracker
Re: My top 5 at the moment
Post by Corn Cracker »
I dont think I have 5 yet, let's see,
1. My modular keg still, i like my 6 gallon stove top alembic but.......
2. my stand up plate grinder, made the process easier and more versatile as far as the fineness of milled grain is concerned.
3. my 2 inch CCVM i made, it works great and im learning all about running the thing.
4. My 3 inch, type K copper column with 2 bubble plates, I've got the column done just needing to get the shotgun condenser built and the 6500W element installed and it will be ready for its maiden voyage.
5. I reckon would be the opening of my senses and finding some of the notes, taste and smells they talk about
I think I'll go home and fire up my still, it might not make me feel better but, I bet it will
Username
Post by Username »
I'll play the game
5. My set up, I had done years of research on and off. I almost started twice before (wish I did) but by the time I jumped in I pretty much knew what I wanted. I'm not a metal worker so I pretty much bought or had made everything. It's modular so I'm sure things will morph over time
4. Saying the above, I was underpowered, so my next item is my 2nd 2.5kw element, bring my power up to 5kw for 50L boiler and 4" column
3. Bench disc sander, it's the only tool I bought to make Badmo clones, I use the basic tools I had (jigsaw and hand plane) but couldn't make them without this
2. My latest white (ish) rum, dark brown sugar wash, one and done run, it's a bit bland but when blended 8 to 1 with a 6 month old, oaked black treacle rum that's too harsh on it's own, gives an off white quick sipper that's the most drinkable thing that I currently have
1. Walking into my rickhouse, stillhouse, shed. The under lying smells of oak and spirit, fermentation and the visual of my growing stack of full clones and the still in the corner
PalCabral
Post by PalCabral »
Username wrote: ↑Fri Aug 07, 2026 11:06 pm I'll play the game
Now you said something! Very good point. Having two 2.5kw elements is great, enables me to lower the risk of scorching. It's great.
Username wrote: ↑Fri Aug 07, 2026 11:06 pm 1. Walking into my rickhouse, stillhouse, shed. The under lying smells of oak and spirit, fermentation and the visual of my growing stack of full clones and the still in the corner
Lol. A dream. Just wait until you get the black spirit fungi. ;)
Username
Post by Username »
PalCabral wrote: ↑Sat Aug 08, 2026 9:39 am Now you said something! Very good point. Having two 2.5kw elements is great, enables me to lower the risk of scorching. It's great.
The reason for the 2 lower wattage elements was to work within the power supply I have in the shed, I hadn't even thought of that benefit :D a happy accident
5. A separate shed for my equipment. So, I don't have to takedown the still, just close and lock the door when done running.
4. Store bought high temp alpha and gluco enzymes. Before it was available, my all-grain mashes where hit and miss.
3. A temperature controlled fermenter. Yeast loves a constant temp.
2. An agitator for the boiler. Using this gets all the boiler contents up to temp at the same time.
When I pull the forshots, all of it comes off at first and doesn't linger and smear.
1. A homemade jacketed boiler with direct steam injection. I can mash and distill in it.
The jacket not only heats the mash but also can be used as a chiller.
PalCabral
Post by PalCabral »
shadylane wrote: ↑Mon Aug 10, 2026 9:35 am 2. An agitator for the boiler. Using this gets all the boiler contents up to temp at the same time.
Makes my mouth water, that's for sure ;)
Post by Novice »
Pascules, Pto. Escondido,Chalacatepic, IB, some redhead in Portland.
PalCabral
Post by PalCabral »
Novice wrote: ↑Wed Aug 12, 2026 12:25 pm Pascules, Pto. Escondido,Chalacatepic, IB, some redhead in Portland.
Yeah, that redhead in Portland is really something! :)
