Need a better fermenting vessel
- BigSwede
I've been rebuilding and upgrading after returning to the hobby from a long time off. I need to upgrade how I ferment. No more sloshing buckets, big funnels, or heavy lifting! My goal is to ferment, strip (probably 3X), dilute, and roll those low wines into one spirit run. Mostly neutrals, but maybe grains or more advanced ferments in the future.
Boiler charge is 12 gallons max. Working back from a 30% ABV boiler charge, and estimating losses, I think I need a 35 to 40 gallon fermenting vessel.
I am leaning towards a conical bottom vessel. I like the idea of allowing the settling and purging dregs as much as possible, then gravity draining the vessel directly into the boiler for stripping. Height isn't an issue, I have lots of head room in the shack, and can mount the vessel on a table or stand well above boiler height.
That said, I don't mind spending some of the kids inheritance on something decent. Stainless? Plastic? Necessary gadgets, ports? Any gotchas to look out for? I'm wide open to suggestions.
Many thanks.
Many thanks.
greggn
Re: Need a better fermenting vessel
The very first thing that comes to mind when talking about large vessels: clean in place (CIP) capability.
________________
- subbrew
Have seen both stainless and plastic used in micro-breweries. Mostly a matter of dollars. Something to think about putting it on a table is how do you fill it? I would look at getting a pump to go from fermenter to pot rather than having the fermenter that high.
A second consideration is cleaning. If fermenting on the grain I would think you would want a port in the side to allow access to dig the grain out as it will tend to pack in the cone. Ease of cleaning might also dictate not putting it up high.
- Username
Depending how deep you want to dig into that inheritance fund built in cooling/heating would be a very nice addition.
Something like https://www.polsinelli.it/en/refrigerat ... -P2736.htm would be nice, maybe overkill but.....
If I was going that route, I'd be inclined to get a decent pump, to make transfers easier and allow you to CIP as some of the lads are saying
- BigSwede
Thanks guys.
Maybe something tall enough to put a 5 gallon bucket below it, drain dregs, but not so tall as to make topside access a hassle. Then yes, pump vessel contents to pot. Having a clean-out hatch too, good call.
Two excellent points. I was just thinking about the vessel to pot transfer. There are really three transfers... got to fill it up, drain waste, transfer remainder to pot.subbrew wrote: ↑Fri Aug 28, 2026 6:29 am Have seen both stainless and plastic used in micro-breweries. Mostly a matter of dollars. Something to think about putting it on a table is how do you fill it? I would look at getting a pump to go from fermenter to pot rather than having the fermenter that high.
I've got a KW PTFE coated immersion heater + control that I could adapt. Cooling in the summer would be critical. This is one of those things I want to get right the first time. Thanks.Username wrote: ↑Fri Aug 28, 2026 6:54 am Depending how deep you want to dig into that inheritance fund built in cooling/heating would be a very nice addition.
Bolverk
Check out 50 gal barrels on Craigslist and/or fb marketplace, you should be able to pick up a used hdpe pickle barrel for around $50.
Here's how I transfer from the fermenter to the boiler.
Draining the fermenter into a catch basin and then pumping it into the boiler both degas the wash.
The almost flat bottom of the fermenter does an excellent job letting solids settle out.
I built a really nice conical fermenter a couple years ago and I wasn't impressed.
The solids wanted to cling to the tapered sides and wouldn't drain when cracking the valve open.
- PalCabral
I have no experience from bigger set ups, I am using either 8g or 15g buckets, but in my book conical fermenters are intended for off-grain fermentation, not particularly practical for on-grain. The idea is that the yeast slurry is gathered in the bottom cone and emptied first, then the settled beer. Grains would likely stuff the exit and block it, and I would bet getting both beer and grains out of the fermenter after fermentation in a conical fermenter is just as troublesome as in any other fermentation vessel, maybe more even.
I use a self-priming transfer pump called Super Sucker. I love that name. As long as the wash is below 140F/60C it transfer to all the necessary heights in a distillery. This is an investment I made for my back as I turned 60 in March.
- Username
We use larger conical vessels in work, I wouldn't attempt to ferment on grain in one, even dry hops can cause severe blockages.
30xs
If money were no object I’d look into a stainless 55 gallon drums and a lift table. Here’s a lift table offering almost 6’ of lift height.
https://mechmaxx.com/products/stationar ... height70-1
Mash at floor level, lift to drain, lower to clean. Maybe the next Swede build will be an acme thread scissor lift table.
Powder Monkey
I use the Rubbermaid Brute trash cans. They’re food grade, sturdy, come with the lid and thick walls to hold up to mash weight and heat. I have both the 32 and 44 gallon sizes depending on what I’m fermenting. I also made some wheeled bases to roll them around, but you can also buy a base.
- Salt Must Flow
BigSwede, here's a link where I bought a conical Inductor Tank and built a wood stand used to clear my sugar washes. I ferment in two 55 gal poly drums. I pump the fermented wash into the conical tank and add Bentonite Clay to clear the wash. If I could go back in time I would really try to find a conical bottom with a steeper angled bottom. I do not recall what degree angle my tank is and the original link to the tank is dead now. Shipping is extremely expensive so I found a dealer within an hour away who had the tank in stock. The impeller for the Little Giant pump cracked so instead of directly pumping the wash, now I drain the tank into a 5 gal bucket and use a submersible pump to transfer the cleared wash into my boiler.
- Stump Lake
Here is a picture of my fermenter. It is a 55gal blue barrel. I mash in the barrel using SCDs large batch method. I pump from the bottom of the barrel over to my still. ( see the yellow quick fitting to the bottom right of the barrel).
I use a mash bag to strain my mash. I had to install a winch to lift the bag.
The truth shall set you free. But first it will piss you off.
- PalCabral
Stump, do you cook the corn with the brew bag already?Stump Lake wrote: ↑Fri Aug 28, 2026 12:28 pm IMG_4792.jpeg
- Stump Lake
Yes, I dump the hot water water from the silver keg directly on the corn in the in the bag. It takes me 3 tanks of hot water to fill my barrel.
The bag holds up well with the heat.
- BigSwede
Looks like the "one vessel no-lift no-pump" fermenter really isn't a thing.
So, conical plus grains = likely horrible plug up. I really like the notion of maximum settling/clearing in a conical. If I do grains, it's probably be best to do them separately in an open flat bottom, then pump them into a conical for clarifying.
Cooling and heating - In the summer, it can be 105 f / 40c here for weeks. I have a pool that is around 84 f / 29 C - Maybe I can connect a small pump from the pool into the sort of liquid flow heat exchanger seen in fermenters, and have it stabilize at that temp.
I like stainless. I know plastic is fine, but stainless cleans so easily. The plan for the moment is a 35 to 40g conical stainless on a scissor lift table, and a pump that can handle fine dregs if needed. Time to shop a bit.
- PalCabral
I've been eye-balling scissor lifts for a while now. Lifting full 8g/30 liter buckets is still doable but above 30 liter forget it. I manage to get the 16g/60L bucket down from the bench where it sits during fermentation down to a dolly board on the floor, so I can move it around, but lifting is out of the question. A scissor lift on wheels that can lock would be great.
Another great thing with scissor lifts is that you can put your boiler on it and then adjust the height before distillation so that the condenser and whatever collection jar you're using will align without problems. It's not a huge issue, I use board game boxes from the kids to lift the collecting vessel to the spout but being able to lift and lower the height of the still would be perfect.
Homesweethome
I have put my stainless steel conical on top of a stainless steel work table in which I drilled a big hole. So that I could mount valves + sight glasses etc. under it. I will try to add a picture.
Homesweethome
Last edited by Homesweethome on Sun Aug 30, 2026 5:46 am, edited 2 times in total.
- Copperhead road
that's a flash set up, Homie...
Roo
Beer fermenters/unitanks normally have a 60 degree cone I believe.Salt Must Flow wrote: ↑Fri Aug 28, 2026 12:26 pm If I could go back in time I would really try to find a conical bottom with a steeper angled bottom. I do not recall what degree angle my tank is and the original link to the tank is dead now.
A suggestion from left field, you could consider a jacketed boiler or mash tun. Depending on what you are making you could cook grains and then ferment in there and even strip on the grains.
While likely more expensive, it'd be a multiuse vessel.
- BigSwede
Nice and very clean setup. I like it.Homesweethome wrote: ↑Sat Aug 29, 2026 12:39 pm I have put my stainless steel conical on top of a stainless steel work table in which I drilled a big hole. So that I could mount valves + sight glasses etc. under it. I will try to add a picture.
I wish I knew more about higher-end processes like what you suggest. Need to read more. Something I've found shopping, 85% of what's out there is aimed at beer. Pressurized fermenter? Some of them look like space capsules. What I don't want to do is pay for widgets/attachments I don't need.
Actually that unit is spot on. I like everything about it. Heating/cooling, not crazy complicated or expensive. I need to find USA distribution, or shipping might get ugly.Username wrote: ↑Fri Aug 28, 2026 6:54 am Depending how deep you want to dig into that inheritance fund built in cooling/heating would be a very nice addition.
Thanks again fellows.
- Username
On Roo's suggestion I took a look around, maybe something like https://oakstills.com/products/electric ... eel-boiler could do everything you want. Looks sexy as hell, I do know a very small commercial set-up using something very similar to this, in 200L
- Copperhead road
I have been eyeballing the 120L or 200L potbelly boilers from Stilldragon, the only problem is i run on gas and don't want to convert to electric.
has anyone tried running gas with a potbelly boiler?? i have considered capping off where you would install the elements.
Bolverk
Youd need to use gas to boil water to heat the jacket.Copperhead road wrote: ↑Sun Aug 30, 2026 11:31 pm I have been eyeballing the 120L or 200L potbelly boilers from Stilldragon, the only problem is i run on gas and don't want to convert to electric.
has anyone tried running gas with a potbelly boiler?? i have considered capping off where you would install the elements.![]()
- BigSwede
I'm rapidly approaching choice and decision paralysis.
I really like this one, about 32g / 120l, not jacketed but has a cooling coil installed. Of course, not stocked when you want it.
https://www.stouttanks.com/1-bbl-fermen ... n-lid.html
Or I can break the bank and go here, but I don't need half the features. It's more for beer I think, can handle pressure. It is jacketed, which is nice.
https://morebeer.com/products/brewbuilt ... 7657932065
I thought "Just buy a stainless 30 gallon drum, adapt it." Darned things are hundreds of dollars!
There's always trash cans from a big box store. I'll figure something out.
zach
Here is my 55 gallon HDPE barrel that I use as fermenter. I only ferment on the grain or fruit pulp. I fill and remove material from the barrel with an 8 quart stainless bowl. I lift 10 or 15 pounds per scoop, so no strain on my back.
I have a poor man's tank jacket using an ice bath tub that I found on amazon. I am currently cold soaking 40 gallons of grape must prior to fermentation. I have an air cooled chiller that maintains the tub water temperature at 40 F and must is at 54 F. I have an aquarium heater that I plan on using this winter to heat whisky ferments in an unconditioned space.
I had thought about making a DIY chiller from a window air conditioner, but found a 1/3 hp aquarium chiller for $200 that does the job.
- BigSwede
Thanks Zach. I like what you've done there.
I am back on board to do a proper amount of DIY work. 95% of the stainless fermenters out there seem aimed at brewers. Most are too small. Those large enough are phenomenally expensive, and have beer-oriented features I just don't need. All I really wanted was something I could sample, dump, heat and cool. Going this direction:
50 gallons, food-grade HDPE. For a few bucks, I can add bulkhead fittings where I want them. And in the lid area, ports for heating or cooling using a coil. All-in cost a tiny fraction of some stainless beer beast of similar capacity.
I appreciate all the suggestions.
Time to get going with some Shady's Sugar Shine to finally test the structured packing.
- BigSwede
Salt, I re-read your thread entries, and it's motivating. But like you, I'm finding the pricing to be a bit nuts on these. The tanks themselves, even new, not too bad. But... "Oh, you want a stand with that? OK, double the cost. Shipping? Triple the cost."Salt Must Flow wrote: ↑Fri Aug 28, 2026 12:26 pm BigSwede, here's a link where I bought a conical Inductor Tank and built a wood stand used to clear my sugar washes. <snip> Shipping is extremely expensive so I found a dealer within an hour away who had the tank in stock.
It's crazy. I don't have the patience to make a nice stand like yours, and besides, I don't have the woodworking tools. I'd drive to get one, but the places reasonably close to me don't have what I want, and lead time is 6 weeks. Damn.
Have you found good technique to clear the trub without too much volume lost? Did reducing the bentonite or using a different flocculant help at all?
