All grain mash study
Post by Novice »
PalCabral
Re: All grain mash study
Post by PalCabral »
Interesting. In Europe, it custom to separate grains before fermentation, at least when malt is the main ingredient. If it is proven that yields are higher with fermentation on grains, it is likely some distilleries will change. Maybe not in Scottish malt whiskey industry but in other areas.
I remember having read or heard that European distillers arriving in the US in the 1800's needed to be "re-educated" to learn how to ferment and distill on grain. Maybe now US distillers need to travel to Europe to teach us how to do it? :)
Post by Novice »
I would have thought vodka was fermented on grain.
PalCabral
Post by PalCabral »
Novice wrote: ↑Tue Sep 29, 2026 10:01 am I would have thought vodka was fermented on grain.
Not sure, honestly. High prood grain spirits is produced in many countries in Europe, originally under different and local name. The German Korn and Doppelkorn I believe is separated from the grain before fermentation. So is custom in Scandinavia for the local firewater. How the Poles and Ruskies do it, I don't know. Much of the vodka produced in France, UK and other places in Europe today could very well be fermented on the grain. They are all new recipes, probably following how azeo are produced for the industry.
Post by Novice »
I never heard of those spirits, I googled and it seems they are fermented on grain and some are distilled with the grain in. It's sad that I can find tequila and Corona in Europe but no European spirits over here except maybe for some Italian wines.
Krishan
Post by Krishan »
PalCabral wrote: ↑Tue Sep 29, 2026 10:42 am Not sure, honestly. High prood grain spirits is produced in many countries in Europe, originally under different and local namemoviebox latest. The German Korn and Doppelkorn I believe is separated from the grain before fermentation. So is custom in Scandinavia for the local firewater. How the Poles and Ruskies do it, I don't know. Much of the vodka produced in France, UK and other places in Europe today could very well be fermented on the grain. They are all new recipes, probably following how azeo are produced for the industry.
do you think modern European craft producers of traditional spirits like Korn or Scandinavian aquavit will ever experiment with AGI methods to improve efficiency
tommysb
Post by tommysb »
A key hint would be to look at the still type used. Continuous or column stills would typically distill on the grain (if you look at grain whiskey, this is common) , and would be the same with vodka or anything else. It is more process/expense to separate from grain, and has lower yield, so why do it unless your process can't support NOT doing it.
This book has some info about protocols if you can find a copy, it's well worth a read
https://www.goodreads.com/book/show/1551455.Whisky
