After much reading, I have started collecting parts for my first proper build. I started out with a Vevor kit, but seeing what is possible has inspired me to level up. I also have some questions about how to plan my build effectively to adapt.
With my Vevor, my first product was an apple brandy which was tasty, but harsh in any but small doses, and my latest effort was a rum that was very difficult to make cuts.
Starting out, I want to work with fruit products and other products that need to preserve flavors of the wash, so I think a pot still is in order, but I have also got the impression that some reflux can complement a pot distillation in some cases, is this accurate? If so, want to account for this in my current build.
Q1: some reflux can complement a pot distillation for some cases, is this accurate?
For 150USD (with shipping), I sourced a very conveniently configured 15.5g keg with 4 in ferrule on top and 1.5 in at the base.
I have a heating element to mount at the 1.5 on the base, but I am also open to using propane, and given that most US circuits are 120V x 15A-ish, I don't expect to be putting much more than 1800W (unless I use propane?).
I have a 4x2 reducer and a sight glass as well.
I was tempted to just get a quick start and use the oakstills pot with liebig kit on Amazon, but I felt like it could be pretty easy to make a copper liebig. This is where my questions started emerging.
Q2: what is a good "general purpose" liebig configuration?
I have seen Bearded & Bored's 1 inch x 1/2 inch on Youtube, and that seemed doable, but I have also read that a 3/4 x 1/2 inch design works just fine too. I have seen discussions of a condenser's "knockdown ability" but not much regarding general principles of estimating condensing capacity for a given setup.
Q3: From what I've read so far, seems like I might need 4 ft of length for a 3/4 x 1/2 inch liebig with my base setup, and perhaps just 3 ft of length for a 1 x 1/2 inch liebig? But this is just my "gut" guess based on my reading/rambling. Perhaps a shotgun is better for this configuration?
I have also seen shotgun condensers recommended too, but I don't really want to build one just yet, as it looks more complicated of a build than a basic liebig, and I would like to get my hands dirty with some DIY. But I might go for an oakstills shotgun condenser if a basic DIY liebig is just insufficient for my condensing needs.
Q4: Sort of related to Q1, but more specifically, as I was reading about VM and LM and pot stilling I started getting a bit muddled. I understand that VM and LM both involve reflux, but are they opposed to pot stilling, or can a pot still use VM or LM methods as appropriate? As with many things, I anticipate that "it depends" but I wanted to get more clarity. Just wanted to consider these styles in designing my build in case they can complement the products I'm starting out with.
My first post
- BigSwede
Re: My first post
Welcome Aja. I think you're realizing the depth of info here, and it can be intimidating. I'll try to answer a Q or two.
If you have a 4 foot column normally used for reflux, and you remove the packing from it and simply route the vapors directly into a condenser, there's a still for stripping or pot stilling. There will be some passive reflux from a tall riser, but not a deal breaker. Still configurations aren't always mutually exclusive, the same components can do many tasks, especially if these can be configured via tri-clamps.
You are at a good moment in the hobby where taking a bit of time and deciding what you want to make, how to do it, and how much, will drive the purchase decisions. Best to do it without rushing.
Reflux simply increases ABV. It can be increased to near azeotrope, leaving most/all flavors behind if the cuts are skilled. Or it can be reduced, allowing flavorful components other than ethanol to be collected. Many sorts of stills can be tuned with packing, power, or both, to reflux more, or less.
You'll find the majority here are huge fans of electric heat, for both control and safety. Most USA houses have 240V 20A service somewhere inside, and these can be tapped for plenty of juice if needed.I have a heating element to mount at the 1.5 on the base, but I am also open to using propane, and given that most US circuits are 120V x 15A-ish, I don't expect to be putting much more than 1800W (unless I use propane?).
There are calculators in the site Wiki that can figure condensing power for you. Generally, wider/longer in a Liebig is better. Always best to have excess condenser capacity. I use shotguns, which I like as being very space efficient, and also fun (and yes challenging) to build. You can always buy a stainless shottie, but there's a lot of satisfaction in DIY, and a liebig is about as simple as it gets.Q2: what is a good "general purpose" liebig configuration?
VM and LM are 2 ways among many to draw high ABV product from a reflux column. The same piping that makes a reflux rig can in many cases be used for stripping or pot stilling.Q4: Sort of related to Q1, but more specifically, as I was reading about VM and LM and pot stilling I started getting a bit muddled. I understand that VM and LM both involve reflux, but are they opposed to pot stilling, or can a pot still use VM or LM methods as appropriate? As with many things, I anticipate that "it depends" but I wanted to get more clarity. Just wanted to consider these styles in designing my build in case they can complement the products I'm starting out with.
- Copperhead road
aja
Re: My first post
Thanks BigSwede for the pointer to the condenser calculator! I guess a 1 x 3/4 inch at 36+ inch liebig might be better if I did a liebig, but I am gathering that liebigs are less space/cooling efficient than shotties, and that shotties are preferable.
- BigSwede
Re: My first post
A shotgun can be more compact, but that doesn't make it better. Just different. If you run with propane, a Liebig is preferable, almost a necessity, to get the condensate (and possible leaking vapors) away from open flame.
If you buy or make a shotgun, do one with tri-clamps both ends, large enough to do any job needed. Stick it on top of a packed column, its a reflux condenser. On the end of a lyne arm, its a product condenser. Tri-clamp spools, elbows, condensers, adapters, are your friends, allowing all sorts of still configurations.
aja
Re: My first post
Ah, using liebig for an open flame setup is a helpful consideration for choosing a PC.
Yes, I'm definitely looking at triclamp parts for modularity. Seems like there's quite a bit of pre-made chinese kits on Amazon these days. I gather this has not always been true, and that they probably varied widely in quality. I have seen oakstills mentioned, and their stuff _looks_ pretty good and competitively priced. I haven't seen many people complaining about quality, but I am sure opinions vary. Although I want to get my hands dirty with parts building, I am kind of itching to start out with one of these kits.
aja
Re: My first post
Electricity is pretty expensive in my area, and my rudimentary research on controller + heating elements suggests ~300USD for ready-made equipment. And since I have a propane burner already, I'd like to start with that and see how it goes.
This brings me to considering a liebig. Looking at the calculator, seems that the smaller diameter tube has a big influence on the cooling capacity. I am not 100% on what power input I should use. I just threw 2500W in there. Based on the calculator estimate, I am thinking that a 1 x 3/4 inch liebig at 48 inches might be better, but I am not 100% if I am using the calculator correctly.
- Copperhead road
Re: My first post
plenty of top notch spirits have been distilled with a beerkeg boiler sitting on a gas burner.
I for one started with a HP gas burner, LPG works best for me, would never change to electric.
zach
Re: My first post
I also live in a place where electricity is too expensive. 4 to 6 times what propane cost per unit of energy.
Propane has many benefits over electric in that you generally can get more heat for faster stripping runs, no worries about a low level burning an element, and much less chance of scorching with solids in boiler.
I have this condenser and it will knock down what ever I throw at it with my 100,000 btu burner. I have an extension on the outlet to collect another 2 feet from the outlet so it effectively 3'6 long. It's likely less expensive than fabricating a liebig these days from copper.
