Close call at work
Corn Cracker
Close call at work
Post by Corn Cracker »
Had a high temp regulator blow off a 6 pack bank of nitrogen A tanks and hit me in the head today, the ⅜ inch nipple that goes into the regulator was damaged and broke when I opened the valve, 2,400 psi sent the regulator straight to the side of my hard hat, luckily I turned sideways and tilted my head/hard hat towards it, it was like a baseball bat hit me. The regulator broke into pieces and went everywhere people bringing pieces from all directions. Crazy shit, having a stiff drink now. Last job i was on a guy was killed when a pipe blew apart at 125psi and got him in the face,,, yeah, i teared up a little pulling in the driveway at home today and just sat there for few silent minutes
I think I'll go home and fire up my still, it might not make me feel better but, I bet it will
Copperhead road
Re: Close call at work
Post by Copperhead road »
That's a close call Corn Cracker.
Its amazing how dangerous high PSI can be so dangerous when they let go. i have seen some catastrophic accidents working in oil & gas
pipelines over the years.
I'll have one for you too Corny , that is sobering shit .
Glad you're still with us .
Corn Cracker
Hey, it's definitely no longer "just another step" I've hooked those things up so many times, never even thought this could happen. Something made me step sidewards and tilt my head towards it this time though. My young, 22 yo apprentice was shaken up more than I was, poor kid, i should have gave him a hug and told him it was ok, he was about in tears but, that would have just been weird 😆
Forest Beekeeper
Post by Forest Beekeeper »
I have seen some impressive shyte when 3,000 psi hydraulics develop a pinhole leak. That will slice your whole arm or leg off.
NorthWoodsAb
Post by NorthWoodsAb »
Corn Cracker it's a good thing you turned your head when you did. Working in oil and gas most of my life I've seen some scary things happen with valves, gauges and pipe under pressure. Enjoy that drink, hug your family and be thankful that hardhat did its job.
Cheers
Uisge beatha
PalCabral
Post by PalCabral »
OMG, what a close call, CC! I am so glad you’re ok, man! I can understand you, and your apprentice, are shook up about it. Noone should die or be mamed (correct word?) at work, but some jobs are more dangerous than others, and this shit happens. Something in your system told you to turn and tilt your head. Man!
The Booze Pipe
Post by The Booze Pipe »
I've worked many years in the big woods of Oregon cutting timber and have had & saw too many near misses to count. My partner said once, "only Marines, and timber cutters joke about dying" :lolno:
I'm glad you're okay Corn Cracker :thumbup:
13.5g/50L keg
12,000watts of fury
WVtired
Post by WVtired »
Had some imbecile put a cast iron ell in piping to a pressure gauge on a hydraulic ram we used for destructive testing at the time. It was my turn to test a new panel and it was doing quite well, exceeding 2500psi when the elbow (3/4") decided it's had enough. That was probably the scariest moment of my life at the time, the sound alone was scary, never found half of the elbow in the shop, it vanished. Luckily other than hydro fluid all over, I escaped without any damage. Thank goodness your protective equipment did it's job and you are okay!
Corn Cracker
It's crazy how fast things can happen, even though i did everything right hooking it up, i didn't check to make sure that 2½x⅜ brass nipple wasn't damaged. i ended up taking yesterday and today off, i needed a break
PalCabral
Post by PalCabral »
Corn Cracker wrote: ↑Fri Oct 30, 2026 6:57 am It's crazy how fast things can happen, even though i did everything right hooking it up, i didn't check to make sure that 2½x⅜ brass nipple wasn't damaged. i ended up taking yesterday and today off, i needed a break
You've had a shock from what happened, CC. Good you're taking it nice and slow. If you feel you're mulling over and over, talk about it. Get it off your chest, dont bottle it. Trauma can sit with people for years and really fuck with you. All the best, buddy!
NorthWoodsAb
I have never understood why brass fittings are allowed in High Pressure applications. Yes the cylinder regulators are made of brass and engineered for the application. But because of a very few "specialized brass fittings" being used. I have seen the results of several, potentially dangerous failures, of regular brass fittings when misused in hydraulic applications. I cringe when I see brass in a hydraulic application.
Uisge beatha
Interesting Northwoods
What is the preferred metal .
Corn Cracker
I know stainless steel tubing is used for high pressure systems in labs with swagelock fittings, I've seen it tested at 2500psi
BigSwede
Post by BigSwede »
NorthWoodsAb wrote: ↑Thu Nov 05, 2026 10:34 pm I have never understood why brass fittings are allowed in High Pressure applications. Yes the cylinder regulators are made of brass and engineered for the application. But because of a very few "specialized brass fittings" being used. I have seen the results of several, potentially dangerous failures, of regular brass fittings when misused in hydraulic applications. I cringe when I see brass in a hydraulic application.
Hmm, brass isn't cheaper than steel, it's costlier. From a machining perspective, I think it's used because it's free machining, parts can be puked out on automatic screw machines at high speed, vs. steel. Especially leaded brass compositions, which cut like butter and are fine for gas or hydraulic use.
Edit: When I say "fine for gas or hydraulic" I'm referring to chemical composition, not necessarily strength. :oops:
Looking back through the years, I'm amazed to still have 10 fingers and both eyes.
Most likely its due to luck and not good judgment. :lol:
Copperhead road
shadylane wrote: ↑Fri Nov 06, 2026 5:46 pm Looking back through the years, I'm amazed to still have 10 fingers and both eyes.
Must be why i have 7 fingers and 3 stumps... :lolno:
Copperhead road wrote: ↑Fri Nov 06, 2026 6:22 pm
Sounds like you've had dangerous jobs, like in yakuza or been sticking fingers where they don't belong. :lol:
Copperhead road
shadylane wrote: ↑Fri Nov 06, 2026 11:43 pm
It was a 45 Tonne metal press in a ship yard, helping my Dad at his work... what kid didn't want to go to work with there Dad.. I loved running around the wharfs and in the ships. You would never ever get away with that type of stuff these days. If a kid lost half his hand workplace health & safety would shut the place down with an investigation
Corn Cracker
Copperhead road wrote: ↑Sat Nov 07, 2026 1:24 am
Damn, I could imagine how hard that was to deal with growing up
