Beer Kegs
Binkmaneod
Beer Kegs
Post by Binkmaneod »
I have noticed that some people use beer kegs as boilers. I thought these were aluminum. I also thought that it was not good to use aluminum as a boiler. Please clarify anyone that can because I have access to a keg and would like to use it as a boiler.
olddog
Re: Beer Kegs
Post by olddog »
Some are aluminium, some are stainless steel, only use stainless for your still as aluminium will pit when boiling alcohol.
dixiedrifter
Re: Beer Kegs
Post by dixiedrifter »
If its a 15.5 gallon keg, has a "Bud" or other american label on it, and it weighs in at around 30lbs empty (make sure you drain it of course before you weigh it) you can pretty much bet its 304 stainless steel.
Hawke
Re: Beer Kegs
Post by Hawke »
Most kegs will have a stamping on the center bottom. If it has 304 or 304L stamped there, it's stainless. Due to the aluminum/health scare of the early 80's, most kegs went stainless.
Binkmaneod
Re: Beer Kegs
Thanks for the info. I will check that out today.
eternalfrost
Re: Beer Kegs
Post by eternalfrost »
also, if its aluminum, youll be able to cut through it like butter but SS will take 4.32 years
Q-bIc
Re: Beer Kegs
Post by Q-bIc »
stealing the thread a bit...
i thought all 50L keg in Australia was stainless, or am i wrong ?
Ugly
Re: Beer Kegs
Post by Ugly »
I've seen aluminum kegs in the EU but never in NA or Aus. The bottom will likely be stamped 304L
FeralPig
Re: Beer Kegs
Post by FeralPig »
eternalfrost wrote:also, if its aluminum, youll be able to cut through it like butter but SS will take 4.32 years
Should be a law against cutting the keg. I had so much trouble on my first still (reflux) because I cut a hole in the top. Sealing is a bit of a pain and mounting the column to the stainless dog bowl was a bitch. Should have listened and used an unmodified keg with the tri-clover clamp and fitting. I did do that on my second still (pot) and it is much easier to prepare and run and not too much trouble to clean.
This is so much fun it ought to be illegal..wait..never mind.
51" LM and a 24" Pot still with 62" Liebig with turbulator and spiral coolant swirler thingy. Both running on an unmodified keg with Tri-clover clamp attachment.
eternalfrost
Re: Beer Kegs
I totally agree, triclover right to the sankey is the best way and what i use. I was more referring to cutting a hole for an internal electric element.
goinbroke2
Re: Beer Kegs
Post by goinbroke2 »
I second that!! Tri-clovers ROCK!
punkin
Re: Beer Kegs
Post by punkin »
You go your way and i'll go mine, but i love having a four inch hole in the top of my pot still. Just cause you are happy with the way you clamp to your keg doesn't mean it's superior.
You don't need a dog bowl or anything else as ghetto as that either when they make parts for sealing 4" holes...
dixiedrifter
Re: Beer Kegs
Nice thing about those tri-clovers is you can weld in a 6 or even 8 inch ferrule on top and just cut it out with a plasma cutter and your just as good.
FeralPig
Re: Beer Kegs
Post by FeralPig »
"You go your way and i'll go mine, but i love having a four inch hole in the top of my pot still. Just cause you are happy with the way you clamp to your keg doesn't mean it's superior.
You don't need a dog bowl or anything else as ghetto as that either when they make parts for sealing 4" holes..."
I wasn't really saying the clamp is superior over all other options...just the stainless bowl idea (based on my experience building both). I generally remind folks of my novice status when I post...and as such, I am sure there are numerous ways to attach the column that I am completely unaware of...The picture you posted looks like a solid way to do it. I wish I had tried that on my first still. To be honest, I did see someones post using that method but I couldn't/didn't find the adapter.
Some of us just prefer our holes a little smaller than others :lol:
ghetto...that is funny :roll:
punkin
Re: Beer Kegs
Post by punkin »
dixiedrifter wrote:Nice thing about those tri-clovers is you can weld in a 6 or even 8 inch ferrule on top and just cut it out with a plasma cutter and your just as good.
Yep, a hundred ways to skin this cat. :wink:
bourbonbob
Re: Beer Kegs
Post by bourbonbob »
I use a keg for my worm condenser, I cut a hole about 8" diameter for my boiler and used the peice I cut out the condenser keg as the the boiler top. I didn't weld the the 2" pipe to the top, flour paste is all that is needed. You could easily build a still without weld/solder, the only weld on mine is where the worm exits the keg but that could be replaced with compression fittings.
Image Keep on Stillin' Image
