IrishEnigma wrote:Well I was kind of thinking that before I posted. So since it's not coming in contact with the vapors is it ok to use it? it's still coming in contact with low alcohol percentage at high temps.
Okay IE, now we're treading a fine line in terms of speaking for the HD community. Speaking for myself only, and considering myself as a well educated and overly cautious individual who tries to utilise only the best equipment and practices...I can say that I have done extensive testing on 100% silicon gaskets, and am more than happy to use them even in the vapour path (I wouldn't even think twice about the boiler here).
I may have to post my silicon thread here, but the main potential problem on paper with silicone, is its poor chemical resistance to acetone (not ethanol). Through my own experiments, I concluded that indeed silicone did have a poor resistance to pure acetone, but even in pure foreshots (just the first 50ml straight off the still), showed absolutely no sign of breaking down or leeching over a period of months (can only assume my experiments showed that despite the smell, the percentage of acetone composition in foreshots is much lower than thought). So I personally (only speaking for myself), am happy to use the 100% silicone gaskets which I have tested, in the vapour path for sight glasses in my plated column, and obviously a seal in the boiler doesn't even register a concern due to this. I must stipulate though, that I cannot speak for the community as this is not a material such as SS or glass which is completely inert to solvents. I hope I was able to convey my point while remaining politically correct
edit: to add to this after reading your post PP, these actually seal with the thread too with the 100% silicone gasket resting against the external ridge of the welded socket...however the whole conversation sparked my strong interest and opinion on high quality silicone (for my own use).
