Losses in distilation
Rocky_Creek
Post by Rocky_Creek »
Anyone have an insight into the differance in the amount of loss of alcohol due to distilling in a pot still vs. a compound still ?
You can fool some of the people all of the time, and all of the people some of the time, and them's pretty good odds.
Grayson_Stewart
Post by Grayson_Stewart »
Thats like comparing apples to oranges. Are you talkin about multiple redistillations with a pot still versus a single run with a column?
Rocky_Creek
Well let's say one run in each.
Grayson_Stewart
assuming you use a 20% wash in each setup and have 15 gallons....there is 3 gallons of potential alcohol in each wash. A single run in each is still apples to oranges, but her's a go at explaining why.
Pot still: The vapor will initially come off at about 140 proof or 70% and for a single distillation you would collect down to about 80 proof or 40%. At 40% there will be about 7% alcohol left in the original wash or about 1 gallon.
Column: With a column you can get 190 proof continually throughout the run once you equalize the column. Towards the end of a run with a column you can decrease the take off and increase the reflux and as long as you can maintain the temperature at about 174 F in the top of the column you can remove the high % product and squeak out the last little bit. I've never measured the % left in the boiler but by estimating the amount of product recovered ther is about 2% left in the boiler.
Rocky_Creek
Thanks. That's what I was looking for.
