Alcohol question or two
I had marbles (lost them), went to copper scrubbers and when I went to clean them....filthy. So I regrouped, got rid of all of the packing and shortened the column retained the condenser. I am still getting 100 proof on the first run. I guess my first question is, why? I thought I would need the refux action to increase the alcohol content? I have ran the tails thru again and on the second run I get 120/130. To achieve ethanol for auto use, do I need to continue to distill, it would seem after so long this could become dangerous **boom** The recipe is listed on this site, sweet grain, 5 gallons. I am so glad this site (forum) is back.
not sure where u are safeside, but for automotive u need it stronger how strong depends on what form of alco fueling ur going for, here in the uk sugar is like £1 a kg,, but an option is potatoes they have a high starch content n cost £3.50 for a 25 kg bag. They also make for a low space high yeald crop.
Re-distillin isnt anymore dangerous than distillin over 100 proof, at 100 ur flamable...
for more info check this thread http://homedistiller.org/forum/viewtopic.php?t=228
I have read the link provided (thanks), and I am aware that I am going to have to increase the alcohol percentage. I just ain't sure how, is re-distilling the answer, I don't know.
I am in the US and can legally make fuel, now, I know that all of this 120 stuff is trash (not good for fuel) so I guess I will have to dispose of it.
Potato's, hmm, that sounds interesting, I will check the Faq for a recipe, who knows, it might just make more waste. If this waste fuel was diluted to what 50%, 60% or is it just personal preferance?
My setup is a gas turkey fryer, a copper lid with 2.5 inch copper pipe which is 2 ft long, this is then reduced to a 2 inch copper pipe which is now only5 inches long, this is reduced to 1 inch and a 1 inch tee tops the column (the top of the tee was to be used for a thermometer) the 1 inch pipe flows thru a water jacket for 3 feet, where I reduced this again to 1/2 inch. I had used marbles as packing and replaced that with copper scrubbers, however, I removed those as well and can tell no difference. The section of the column that is 2 in copper pipe, was 1 1/2 feet long, I changed it when I removed the packing and can still tell no change.
The wash was a sweet grain wash as described in the faq, the yeast was not a turbo, I purchased it from a home brewery store. The heat is consistent, temperature is unknown. I heat until I receive output, and then lower the heat, I collect about 1 pint every 30 minutes.
I have been considering replacing the tee with a 1/2 inch 90 degree elbow/45 degree elbow. I am not sure what this would accomplish, but I am thinking it would restrict the output and increase the percentage.
More than happy to receive help, any and all is appreciated.
Jaxom, did I forget anything?
Changing from 1" tee to 1/2" 90 bend will do nothing but increase the speed the vapor travels through your condensor. Sounds like you are running a pot still cause I don't see anything about reflux return lines. If this is so, then you need to turn down the heat like Holy said in order to allow your vapor a chance to condense and fall back down a packed column. Thats where you will get greater purity.
Yes I get a pretty good stream coming out, so I will try to slow it down. It started out as a reflux still and it still have the column and the condensor, so I don't know what to call it.
Thanks for the info, I will be giving it a go and will be back with results, later
