Fruit / Berry Recipes
Tater's Fruit Recipe
From Homedistiller
Taters fruit recipe;Take 1 bushel[40 - 50 lb] of any fruit/ berry.Freeze them thaw and add 20 lbs sugar 1/4 cup lemon juice 1 pack E 1118 and 1/2 oz distillers yeast: If apples or pears grind and or mash them. Peaches nectarines plums cherry's blueberry .I pour boiling water with dissolved sugar on it and lemon juice .I blend it with a drill powered thin set mortar mixer. Thats blades I had sharpened .Adding water as I blend till I have a 13 gallon total wash.That's a thin gravy or thick soup texture. I pour mine through a rat wire sieve I made to remove seeds and any fruit that wasn't blended.Stir hell outta wash to get air back in wash and take a gallon of cooled wash and add 1 pack of E1118 yeast and distillers yeast stirring in let set till morning and add back stir in well and cover and vapor lock. Remember to leave space in ferment for pulp to rise or you'll have a mess and stir pulp gently back in wash as needed. Will make 3 gallons of around 100 proof fruit likker. If doing a no sugar added wash add more fruit to get wash to texture and use this chart to figure fruit sugar content. http://www.nutritiondata.com/facts-001-02s01ja.html" onclick="window.open(this.href);return false;" rel="nofollow
Retrieved from "http://homedistiller.org/wiki/index.php/Tater%27s_Fruit_Recipe"
From Homedistiller
I use a very similar recipe, but for 5 gallon batches. 20lb fruit, 5lbs sugar, tbspn or 2 of lime juice. and 21grams of active dry bakers yeast.
"Be nice to America, or we'll bring democracy to your country."
"The best things in life aren't things."
"Imagination is more important than Knowledge"-Albert Einstein
leaving headspace is very good advice, I was too enthusiastic and forgot about it ........ my grilfriend was very pleased !!!!!
I was just wondering, why add lemon juice if you don't know the pH. I always measure mine before I do that. This year the pH of my apple batch was 4, so I didn't have adjust it by adding lemon juice. Or is this perhaps done to add some addition nutriënts?
Freeze 50 to 70 lbs peaches and thaw .Should look like this after thawing
Then add a little water and stir .I use a sharpened morter mixer.
Then pour through sive to get seeds and large pices of pulp and skin out.Save this to add a bit of water back to and stir agin
Use hands to rub fruit through sive seeds help with this.After all fruit is poured through and seeds and skin are tossed wash should look like this
Take a pot add 20 lbs sugar 1/4 cup lemon juice water and heat till clear.
Add sugar water to wash and add enough water to make 14 gallon total.Stir well and put gallon of wash in bucket and add yeast. This was 1/2 oz ec 1118 and about same distillers
Next morning it looked like this
So I added it back to wash well stirred in like this.
By end of day wash had formed a cap.
Ferminted out in 18 days kept cap stirred back in wash to stop from drying or molding .
Then when cap fell i ran wash and got 3 gallons of 110proof.The end
Tater,So I added it back to wash well stirred in like this. [img]http://i46.photobucket.com/albums/f136/ ... f78279.jpg
When you say the above, what are you adding it back to???
cheers,
Nimrod
My neighbor has a few peach trees and last summer I was up to my shins in peaches, but I ate them all with home-made ice-cream. Next summer, I'm going to make brandy for sure.
Thanks for the tutorial, Tater!
Each step of the pH scale requires 10 times as much acid as the previous one. So if you added enough acid to get from pH 7 to pH 4 into a wash that was already at 4, you would be only reducing it to slightly below 4. It would take 10 times as much to get to pH 3. So Tater's practice of always adding that amount is very logical.I was just wondering, why add lemon juice if you don't know the pH. I always measure mine before I do that. This year the pH of my apple batch was 4, so I didn't have adjust it by adding lemon juice. Or is this perhaps done to add some addition nutriënts?
I was afraid that sooner or later my bubble would burst. Use of the word "inverse" doesn't work with my image of goose-eye -- the local dialect using - young good-ole-boy - dressed in a lumberjack shirt and overalls, hunched over his PC watching "them" run "their" shine.tater wrote: Careful goose your education is showing
Aidas
noed to men . one couldnt read nor write the other was the first
school taught pill pusher in these parts.they came to be the best of friends. to the day the drugest died he said he wont no where as smart as the other in remedys. goldseal an such. ole doc was the first that brought hydrometer to these parts the other ole man didnt need it. alot of them tea totalers never had a clue who was makein the main ingredent in there cough syrup or what it was.
ole man showed doc how to make wine - blackberry- for stomach ailments- ole doc used that word on me one time - inverse-.
they was both dam good men
Aidas wrote:I was afraid that sooner or later my bubble would burst. Use of the word "inverse" doesn't work with my image of goose-eye -- the local dialect using - young good-ole-boy - dressed in a lumberjack shirt and overalls, hunched over his PC watching "them" run "their" shine.tater wrote: Careful goose your education is showing![]()
Aidas
bruised peaches are good to use.
how the freezing thing works:
by freezing the fruit, there are tiny ice kristals formed inside the plant cells, due to the the water in the cells that's freezing too. those kristals are hard, pointy and frozen water has a larger volume then liquid. they 'stab' in the cell membrame. And that makes the fruit more soft and 'liquid' after being frozen. the citoplasm can run out of the cell.
-I have too much blood in my alcohol system-
Let them ripen till there soft.Sugar content of fruit will be at its peak and fruit will be easyer to work with.I usally will seperate ripe fruit out of batch freeze it Putting less ripe fruit in cardboard box and close it up .That will make fruit ripen on out quicker.If ya get it from large source guess ya could pick out enough ripe fruit do freeze at one time but if your single treeing it it will take a while to get all fruit .Peaches sure are fun to work with . Late frost got most them round here.
