Best wound coil
pyrobrewer280
Best wound coil
Post by pyrobrewer280 »
I saw a photo of a beautifully wound double coil (I have read hundreds of posts in the last week) and now cannot find it :( . If you have posted a coil photo take pity on me and point me to your post.
I would like to hear from others as to what they think the best pics are of coils they have seen or if not so pretty, proven good performers. At least they would then be all in one place.
A person is only as big as the things that make him angry
Confucious
airbalancer
Post by airbalancer »
I wound this coil around a piece of 2” copper. I used a spring bender and just kept twisting around. I think the key to the spring bender is a lot of lube. I used some wire pulling lube but dish detergent would work too. After I finished coiling I put a drill point screw through the end of the ¼” tube into the 2” pipe to hold it in place, then twisted it as tight as I could and put a screw through the other end. I took a few extra feet of the ¼” tubing and squashed it flat on a treadle hammer, a vise would work as well, and soldered it along the sides to every 3rd coil or so. The excess was folded over to hook it on the 3” pipe. When I was done, I removed the screws and slid it off of the 2” pipe, cut the ends back and finished with ¼” elbows. I used some extra pieces if the flattened tube to make standoffs to keep the coil centered in the pipe. The condenser is extremely ridged, and a bit overkill but it works nice.
Mike
http://img.villagephotos.com/p/2003-11/ ... enser2.jpg" onclick="window.open(this.href);return false;" rel="nofollow
http://img.villagephotos.com/p/2003-11/ ... enser1.jpg" onclick="window.open(this.href);return false;" rel="nofollow
http://tinyurl.com/kfs53" onclick="window.open(this.href);return false;" rel="nofollow
Brewmeister
Post by Brewmeister »
pyro,
Dunno if this is the one you are after. The coil is down the bottom of the page.
http://homedistiller.org/forum/viewtopi ... sc&start=0
Regards,
The Brewmeister.
1st guy :- My wife is an Angel.
2nd Guy:- You're lucky, mine's still alive.
jmc91199
Location: Middle Managment..Just as i've always dreamed!
Post by jmc91199 »
airbalancer
What is the purpose for having a second condenser hooked to your take off point.
What is the controller box for? Is that what you use to regulate the element in your milk jug. If so that's a fine bit of work!
Dave's not here!
hornedrhodent
Post by hornedrhodent »
pyrobrewer280
Something like this one?
http://i71.photobucket.com/albums/i131/ ... l/Coil.jpg" onclick="window.open(this.href);return false;" rel="nofollow
Looks great have'nt seen that one but its given me an idea:)
Confucious
stoker
Post by stoker »
lets make this a topic to post all our coils :)
I Think Grayson Steward has a nice one too
-I have too much blood in my alcohol system-
Rotgut
Post by Rotgut »
stoker wrote:lets make this a topic to post all our coils :)
please excuse my ignorance but is that coil wound for the water flow or is it for the spirit? is it a double helix?
Rebel_Yell
Post by Rebel_Yell »
Water flow. The tubing is too small to use for spirit flow.
I would rather teach a pig to sing than argue with an Idiot.
stoker
Post by stoker »
single helix, water run
6 mm copper
Grayson_Stewart
Post by Grayson_Stewart »
