After a stripping run of my pear mash, about 30% abv which I intend to redistil, I added Baking Soda (sodium Bicarbonate) @5 ml per liter and much to my surprise the distillate has changed color to an aqua blue/green color. Is this normal or what?
Distillate color change
mine settled...what is it?rangaz wrote:was it coloured tiny suspended particles that settle out with time, or did the solution turn that colour and is completely see through but coloured?
"Be nice to America, or we'll bring democracy to your country."
"The best things in life aren't things."
"Imagination is more important than Knowledge"-Albert Einstein
not sure exactly, but i would say that there was some form of copper salt in solution that was colourless, which is unusual for copper, it normally takes blue or green colours. I would hazard a guess that the Cu ions formed an insoluble salt with the bicarbonate ion and dropped out of solution as a precipitate and eventually settled to the bottom.
You wont be able to see the tiny specks, it will just appear as more of an opaque colour than a transparent colour. Has some of it settled out, making it more see through?
Spose it doesnt really matter as you'll redistilling it again anyway so it wont carry over in the first proper run.
If it is a precipitate it should be able to be filtered or decanted to get it out of final distillate, or distilled if its dissolved in the alcohol
Check out http://distillers.tastylime.net/library" onclick="window.open(this.href);return false;" rel="nofollow - 'Artisan Distilling' pages 74 on for info on flaws.
"In distillates from sour, acetic mashes a blue or blue-green cloudiness can be observed, partly in form of small pellets which can be attributed to
copper/fatty acid combinations. "
J
J
