Keg with 2.5" (63mm) column packed with copper mesh, 48" (1.2M) to where the reflux enters the column. 6" (15cm) up from there a 2 x 2 x 2 (50 x 50 x 50mm) tee goes over to the condenser, collection cup. The condenser is 26 turns of 1/4"ID (6mm) copper inside 2.5" (63mm) pipe. The coil is separated enough to keep the coils from touching together, but the gap between turns isn't near equal to the OD of the tube. The coil is separated from the sides of the condenser shell by about 1/2" (13mm) all around. My condenser water is pumped from a picnic cooler with a pump that can be described as over sized. It flows into the top of the condenser and exits the bottom. To make the transition between this 2.5" (63mm) condenser and the 2" (50mm) tee/drop to the collection cup, I made a cone/reducer that allows the vapors to come up through a 3/4" (19mm) hole surrounded by 6 more 1/4" (6mm) holes, this also funnels the condensed vapor down the center of the 2" (50mm) Dia. drop through the tee to the collection cup. The cup is dished at the bottom and the condensate drains at the center where it tee's off, one way back to the column, the other to the output.
I had to get that out of the way so you folks might understand what's happening next: Hope some of you are still with me.
I made a trial run with plain tap water. My condenser will not knock down the amount of vapors I can produce. It can do it at a VERY low flame, but no higher. I also hear a gurgling noise coming from inside the condenser that maybe sounds like condensate hitting a hot surface and re vaporizing!
The output/reflux valves are almost too hot to touch, and the condensate is hot! It kind of drains out unevenly too.
Should I scrap this condenser and go with a completely different design? Would removing several turns of coiled tube, increasing the distance between coils make the rebuilt condenser more efficient even though the tubing length has been shortened? Is my cone that the vapor goes up through and the condensate drip down through the surface that is possibly re vaporising condensate, or could the collection cup area be hot enough to vaporize condensate? Should I lose the holes in the cone and just open it up till it's just a 2.5" (63mm) to 2" (50mm) reducer? Is everybody else with this type of rig have valves and the surrounding part be so hot? Is an even smaller burner the answer? Or scrap this thing and scavenge parts to make a pot still?
I got a wash that's gonna be done in a day or two...
