I think your methods would work. However, you would want to test several situations for each type of material using:
Materials:
- 100% stainless (assume as baseline, or possibly glass would be needed).
- Copper (copper column, copper packing, copper condensor).
- Different non-standard componenets (PP, PTFE, ...)
Locations for the material (NOTE not all material can be used for a location)
- Boiler
- Column
- Packing
- Condensor coil
- Take off / reflux tubing
- Connections / gaskets / sealants
- Storage container.
As you can see, to do a "real" test, there is a lot involved. It is possible that PP could be used successfully as a boiler, but nowhere else. Possibly PTFE is OK for any cooled distillate of any strength, but should not be in the high vapor path, or in the reflux stream. (NOTE I really do not know, just making hypothesis)
A test like this "could" be done, but it is pretty intensive. I am sure that a distillery "might" undertake something like this, however, for the cost and time involved in this, it would probably become proprietary trade secrets for that company. The test could take 7 or more distillations per each type of material, along with the associated time at a mass spectrometer (or other chemical measuring device).
NOTE that Chemist has already stated within this thread, that EVERY time he has tested high proof in plastics that :
In the course of my work, I've seen many, many plastic bottles with high proof spirits in them. Sent to me by the distillers. I have yet to find one sample that didn't contain detectable amounts of plasticizer. How much di-iso-octyl phthalate do YOU want to eat?
(I certainly don't mean to be argumentative on this most merry of days: I'm just strongly advising against the use of plastics where, in my opinion, they don't belong.)
H.
