JB weld
JB weld
I have noticed a few people have used JB weld and pvc in the construction of a condenser (not in the vapor path). I tried the same thing but used different glue with crappy results....
Does the JB weld bond well with pvc and copper???
Will using ABS pipe be any different then pvc (I have some lying around)??
Don't take life too seriously -- you'll never get out of it alive.
JB weld bonds well with just about everything. Its good stuff to have layin around if ya like to work on a little bit of everything. It can be drilled, machined, and even taped with threads if they don't have to be very strong. It's just good stuff. It does take awhile to cure though, the quick stuff isnt as good as the long cure.
If it was easy everybody would do it.
Please join the Partnership For an Idiot Free World.
- Location: 50 miles past kikatinalong up that dirt track
I got the snots with my pvc outer liebig condensor.
JB weld works best IMHO bonding two things that expand and contract at the same rates when heated and cooled copper and pvc dont.
First run was good but when it cooled it must have cracked the second run leaked.
I coated the whole join with epoxy glue it lasted 5 runs then leaked.Its now in the "well that didn't work" pile.
Such is life
- Site Admin
hmm
You're trying to connect copper pipe to PVC? I'd find the right sized rubber grommet at any decent hardware store, slip it over the copper tube and then drill the appropriate sized hole in the PVC to mount it.
- Site Admin
more
It should yeh. I'm sure you can find a rubber grommet with an inner diameter to match the size of your copper tubing.
- Husker
Do it properly. I used PVC casings on condensers with rubber grommets when I first started but it didn't feel right. Use proven materials, they look better and last forever, if they are soldered/brazed correctly?
I'd love to make a copper one, and that'll be my next project, but PVC is so much cheaper! I also don't have room for a worm/bucket condenser..I've tried the silicone but wasn't too impressed by it. I'll try the grommets for sure
Thanks for all the help
Silicone
i have a hard time getting all my measurements at home and then going to the store and getting everything right the first time. I like silicone's "fill-in-the-blanks" ability, and i don't mind the ugly-factor - i think it adds charm
I've used silicone from copper to copper (outside vapor path, of course). It can take much longer than advertised to cure if it's applied thick in unventilated spaces - up to a week in my experience, whereas the package said 24-48 hours.
expensive sealant seems worthwhile, especially since you don't need much. aquarium sealant from walmart, for example, doesn't contain all the "extra" spaceage antimold stuff...
Far better an approximate answer to the right question, which is often
vague, than the exact answer to the wrong question, which can always
be made precise -- j.w. tukey
So I've wandered through three hardware stores (Home Depot, Home-Do-it-Center and Lowes) and couldn't find grommets in any of them... What else are they used for? Any viable story to tell the hardware people when asking what they''re for??
There are different types, and they are used in all sorts of situations, usually for protecting electrical cables, but other stuff as well like sealing a join (what you want it for). Electrical suppliers usually have a range. Car firewall is a good a story as any. I have bought dozens over the years, and never been asked what they are for. Most businesses don't give a rat's behind what you do with it, as long as you pay 'em. I wouldn't worry about it, just go buy it.mikeac wrote:So I've wandered through three hardware stores (Home Depot, Home-Do-it-Center and Lowes) and couldn't find grommets in any of them... What else are they used for? Any viable story to tell the hardware people when asking what they''re for??
Be safe.
Be discreet.
And have fun.
Be discreet.
And have fun.
Sent a friend... "I don't know" was the story and we found em' just got to grow a pair and stop being so paranoid I geuss... Thanks for the help!!TRANSPLANTED HILLBILLY wrote:Your insulating a wiring harness thru the firewall of a car your workin on. Or anysuch story that sounds resonable should do fine. Or just send the wife, all she has to do is say "I dont know"![]()
- Site Admin
wow
I find that kinda hard to believe.
First hit on google search for "rubber grommet"
http://minorrubber.thomasnet.com/catego ... r-grommets
- Site Admin
idea
Try auto parts stores perhaps. They often have a set of drawers dedicated to rubber bushings, grommets, small plastic clips and so on which often break in automobiles.
- Location: Flaxas (Somewhere between South East Florida and North West Texas)
Or you could say the wife sent me and I dont knowTRANSPLANTED HILLBILLY wrote:Your insulating a wiring harness thru the firewall of a car your workin on. Or anysuch story that sounds resonable should do fine. Or just send the wife, all she has to do is say "I dont know"![]()
Johnny Reb
Southern Cookin, Southern Bell, Southern Whiskey... Damn, I cant figure out the right order.....
Save the Confederate Dollars, The south is beginning to rise again.....
- Site Admin
yeh
"She fixes all the appliances...she's got the blender in a hundred pieces and sent me for this."
Re: yeh
That should be a sticky!!! LoL! It seams people are always feeling paranoid about buying stuff and that seems to be the most general excuse that could work for anything:Uncle Jesse wrote:"She fixes all the appliances...she's got the blender in a hundred pieces and sent me for this."
"20kg of sugar? I donno wife's doing some canning or cooking or somth'n...I just get what I'm told...."
I Love IT!
