Coil in a Liebig
punkin
Coil in a Liebig
Post by punkin »
I'm very much still learning, and maybe this should be moved to the novice section, but when i move into my new shed, i'd like to get rid of my coil and move to a system that allows me to collect at bench height instead of floor height.
Was thinking a liebig was the only way to do it, short of moving my keg upwards or making a very small coil in a small bucket and recirculating water through it.
I have a glass condensor (faulty) that's a liebig type one, but has a very pretty coil up the guts.
Seeing as i have access to any copper or fittings i like, was thinking about making a long halfinch coil, in a two inch jacket, suspending it vertically to prevent any liquid buildup?
I guess i'm not the first one to raise the idea although i haven't read it anywhere that i can remember.
Thoughts and views or alternative solutions so i'm not squatting on a stool? :cry:
showrguy
Post by showrguy »
i dunno ??
but, i think you"d need more than a 2"jacket though, i don't think you could bend/coil 1/2" that tight consistently without kinking it ???
course, i could be proven wrong.......
you could use a chunk of 6" or 8" pvc with end caps for the jacket with a circulating pump, instead of copper or stainless but she might get a little heavy though depending on the overall length..
mikeac
Post by mikeac »
I have thought about the coil in a lieberg idea and even gave it a go...ish. And I still think it would work just fine, however a lieberg condenser is just so easy to make that I can't see the benefit of having the coil over just being straight?
alice
Post by alice »
I think a coil in a liebig condensor would be super efficient - it'd be a sure way to avoid problems with laminar flow of the coolant for sure.
Taking it even further, a copper coil in a glass jacket would be ultra-cool in every sense of the word...
punkin
Post by punkin »
mikeac wrote:I have thought about the coil in a lieberg idea and even gave it a go...ish. And I still think it would work just fine, however a lieberg condenser is just so easy to make that I can't see the benefit of having the coil over just being straight?
As Alice said, there's a couplea benefits that seem to meet the eye.
Turbulence in the flow is one and another is horisontal space, which is my main concern.
How big a jacket do you guys think i'd need? I've never tried to roll pipe before.
Only picked half inch cause that's the smallest i have in the shed, and i still wanna run the pot still around the 3 litres an hour mark, so didn't wanna restrict it much more than it is now (1/2 inch coil in a bucket
Usge
Post by Usge »
Punkin, you ever see one of those "gatlin" condesners? From what I've read, it might be well suited match for an open throat rig like you have.
punkin
Post by punkin »
I've seen heat exchangers for tractors that i was looking at for a hot water system for my car.
I think this's what you mean?
They have a large outer shell with a whole bunch of small pipes runnin through there?
Usge
Post by Usge »
Yes..thats the one. They have a link on the main site on how to make one for a nixon stone offset. (with pics). Not sure exactly how you'd have to adapt it for potstill use.
The link for it is messed up though. Here's a fixed link:
http://homedistiller.org/MakingtheGattlingCondenser.pdf" onclick="window.open(this.href);return false;" rel="nofollow
pintoshine
Post by pintoshine »
your idea is a good one. You coil may end up looking more like a stretched out spring but it would work. I was faced with the same problem and I used a reference form an old book and came up with this:
The condenser part is tow cylinders attached to each other at the top and bottom with the gas coming in between. That way water hits the inside and outside. This is a very compact and efficient design. I have knocked down as much as 18L/hour with this condenser.
HookLine
Post by HookLine »
Here's a little something I knocked up last weekend.
http://i152.photobucket.com/albums/s197 ... hanger.jpg" onclick="window.open(this.href);return false;" rel="nofollow
Be safe.
Be discreet.
And have fun.
tracker0945
Post by tracker0945 »
And that took you all weekend! So what slowed you down?
I would hate to be paying you.
2"x38" Bok mini and
Pot still with Leibig on 45 litre boiler
punkin
Post by punkin »
pintoshine wrote:your idea is a good one. You coil may end up looking more like a stretched out spring but it would work. I was faced with the same problem and I used a reference form an old book and came up with this:
Did you just roll yours outa sheet, pint?
HookLine
Post by HookLine »
tracker0945 wrote:And that took you all weekend! So what slowed you down?
All those holes. So many holes.
And you should have seen the quote from the pros. :shock:
Be safe.
Be discreet.
And have fun.
pintoshine
punkin wrote:Did you just roll yours outa sheet, pint?
Yes, I rolled the inside cylinder and used a locking joint to hold it in a cylinder. I soldered the locking joint. Then I rolled the outside one to leave a 1 cm gap between the two. I folded down 1 cm of the lip of the the inside cylinder toward the outside cylinder. I cut my holes in the outside cylinder, added the connection fittings. I inserted the inside cylinder and soldered the two together.
Here is what it looked like assembled.
The hardest part was fitting it into the jacket and getting it soldered up.
I bet something like this could be made from successive sizes of copper pipe too. Say use a 1" inside a 1 1/2" inside a 2"
This picture would be near impossible to build but it is a good theory.
punkin
Post by punkin »
Your build is above my skill level, Pint.
But your pipe drawings not :wink: :lol:
Think you've solved my condensor problem for me, that'll work heaps more efficiently with all that surface area :idea: :idea:
Do ya think it should have somthing in the outer or inner water jackets to create turbulence or better just a straight through run? Was thinking a small plate with lotsa holes drilled in to make sure the water flowed through evenly.
How long do you think it'd have to be? 12 inches enough? Eight even?
Thanks for the tip mate, and all the time you spent on the drawing and such, so good to have this level of assistance for free 8)
pintoshine
Thank you very much. If you can build one of these I would love to see how it could be done.
punkin
Post by punkin »
No worries mate, i'll take some piccies as i go.
tracker0945
Sounds a bit sus but I will believe you this time :wink:
2"x38" Bok mini and
