help the noob
help the noob
i am building a reflux and i was wondering how do yall seal up the where my thermometer goes into the column? also what thermometer do yall use its the last thing i need for my build.
Re: help the noob
I threaded in a 1/4 compression fitting. my rtd/thermometer probe has a 1/4 shaft. works great.
-Control Freak-
AKA MulekickerHDbrownNose
Re: help the noob
I soldered a 3/8 inch piece of pipe to the side of the column, at betweem a 30-45 degree angle, insert glass thermometer until it hits the oposite wall, putt it back about 1 inch so it is about inthe middle of the column and then slap some flour and water paste around the thermometer and peice of pipe.
The flour and water paste needs to be a bit on the stiff side, but once the heat hits it, it gets good and hard with no leaking.
I am thinking of going to a digital thermometer and and getting a piece of cork to fit the 3/8 inch pipe, drill a hole of the probe and try that out.
- LWTCS
Re: help the noob
I like that idea Brian. Sounds full proof.
What make is that thermo of yours?
Re: help the noob
I don't know what the name is of the thermometer, but I think it is a standard lab type unit. That's what it was advertised as at Bruhaus where I bought it from.
I will do a search and see if I can find out what the brand name is.
Re: help the noob
http://www.brewhaus.com/Thermometer-Lab ... 9C102.aspx" onclick="window.open(this.href);return false;" rel="nofollow
I should correct my spelling and it was that I purchased it from Brewhaus
- LWTCS
Re: help the noob
i've have a short piece of 12mm SS pipe welded into my column. I then dremeled down a piece of timber in the shape of a cone and drill a hole in the cone to suit probe thermometer. Just frimly push the timber into the pipe. I get a leak proof seal. Works every time.
Re: help the noob
I have two of these and they are very accurate.
Instant read means it takes about 6 seconds
http://www.amazon.com/gp/product/B000F9 ... B000F975JA
mount as suggested by Stimson
