I hadn't distilled for a few years and have forgot some things. I made a wash out of 20#s of sugar and a package of yeast with nutriants and 8 gallons of water. I didn't do the stripping and just got my reflux still up to temp and started collecting. Got rid of the fist 200 ml or so then collected the rest in half pint bottles that I numbered.
The stuff is pretty strong, tastes bad except for some of the bottles in the middle.
I want to try and run this through again to see if I can get it to taste more neutral, so my question is:
Do I need to add more water along with the spirit in the boiler?
I seem to remember reading somewhere that you add the same amount of water along with the same amount of spirit.
I didn't strip the wash, I just ran it slow....
"The washtub keeps on thump'n like the pounding in my head" -Diamond Kazzoo
Re: I didn't strip the wash, I just ran it slow....
Try bakers yeast Brian
Those turbos give you a really bad booze.
Joe
Joe
dilute to 35-40%, for two reasons, safety and some of the off taste will be left behind in the water.some add sodium carbonate befor the second run.
I did a search to try and figure out how much sodium carbonate and came up nill.Dnderhead wrote:dilute to 35-40%, for two reasons, safety and some of the off taste will be left behind in the water.some add sodium carbonate befor the second run.
Any Idea how much per gallon?
from parent site
""Ken recommends using Sodium Carbonate to reduce the amount of fusel oils present ..
.. try sodium carbonate @ 4.5 grams/ litre, add it when the wash temperatire is at 35-40 degrees C, add slowly then continue with your distillation in the normal manner. Sodium Carbonate is used in the production of soap and it combines with the oils to form a compound that does not evaporate at the normal distillation temperatures that we are using. Voila, cleaner spirit, less carbon treatment needed and more happy faces."
Duh, I searched the forum, not the parent site. Thanks.
