Euro 60
Re: Euro 60
can you post more pics of your set-up? eg: how you catch the distillatecoming from the tower etc.. i have a euro 60 as well, just curious to make a comparison
Re: Euro 60
Sure, Ill take some pics next time its running.
Re: Euro 60
Nully wrote:Store bought I'm afraid. Comes out about 92 - 93%, each run producing about 7 litres @ 90%. No complaints yet.
How large is the boiler?
![Question :?:](./images/smilies/icon_question.gif)
thanks,
"...there's two dates on your tombstone and all your friends will see 'em,
but the only thing that matters is that little line between 'em..."
Re: Euro 60
The boiler is 60 litre, but my fermentation barrel is less than 50. Sometimes ill throw in some unsuccessful stuff Ive made, that brings up the total a bit more.Bmf_racing wrote:How large is the boiler?
Re: Euro 60
Hey Guys,
Can anyone assist in the best mods, column packing and rerouting of water cooling system on the Euro 60 column?
I have read somewhere rerouting the water flow, and changing the packing drastically helps this still out, but I have not been able to find an specific details. I am also thinking of splitting the water in to 2 so column is controlled and the condensor is controlled. Thoughts? Anyone tried it with this still?
Cheers
Cheers
Re: Euro 60
Separate cooling of the top coil and liebig has some real advantages when running a still.
First off, it looks cool as hell on a still, but really gives you management of the separate temps of the 2 condensers.
When refluxing for an hour, there is no need to cool the product condenser, and when stripping there is no need to cool but one condenser.
I have a pot still and a Boka so it works for me as I can use either or both cooling lines. I can adjust how much water is being sent up to each condenser.
I got an old AC manifold set, mounted it to the top of my still and use the 2 valves to accomplish dual water feeds. It works real well.
Then built a water collection box to see how much is being supplied to each condenser but it is not needed, now I just feel the temps by hand and adjust accordingly. Here's some pic of my rig. Its was fun doing it.
OLD MAN IN THE SHED
Re: Euro 60
Looks a lot like some of the early Brewhaus units. Two SS Trash Cans welded together with a CM column.
DSP-AR-20005
DSP-AR-20005
Re: Euro 60
Yay here is preciselt same cooling system you have, what i am planning on doing.
Would you please enlighten me about the benefits of two separate coolings?
I have never had two different independent of each other cooling column's, but i am building one now.
So what are the benefits in this, how does it affect when i can cool them independently?
- T-Pee
Re: Euro 60
I answered that in this thread: http://homedistiller.org/forum/viewtopi ... 50&t=47122Motomoto wrote:Yay here is preciselt same cooling system you have, what i am planning on doing.
with this link: http://homedistiller.org/forum/viewtopi ... 17&t=25732
Please read the answers to the questions you ask.
![Problem :problem:](./images/smilies/icon_problem.gif)
tp
Handy Links:
The Rules We Live By
GA Flatwoods sez
Handy Links:
GA Flatwoods sez
Re: Euro 60
No need to be rudeT-Pee wrote: I answered that in this thread: http://homedistiller.org/forum/viewtopi ... 50&t=47122
Please read the answers to the questions you ask.![]()
tp
There was no explanation why should i build two different water circulations instead of doing one big cooling system.
But all that is clear to me now
- T-Pee
Re: Euro 60
Did you even bother to open that second link?? The whole thing is the explanation.
tp (done w/ this one)
Handy Links:
GA Flatwoods sez
Handy Links:
GA Flatwoods sez
Re: Euro 60
You would get better results by disconnecting the lower through tubes completely. And only using the top ones. On a separate water control then the product condenser.
And as pointed out the cm mod thread is just about modding a cm still like yours. It should contain the info you need to make the best if that still. Link in my signature also.
