LWTCS wrote:Good post Izzy.
Fact this has slipped away from me as a priority on the "to do" list cuz I'm growing more taste for the white.
Dunder, Punkin and a few others have talked about using a solara method.
My thoughts would be that a three barrel system would be my preference.
Imagine 3 barrels stacked on a stand one atop the other.
Fill your barrels starting with the bottom first,,,,then,,,as time passes the second gets filled. And finally the top or 3rd barrel gets filled.
By this time one assumes that more than a week has passed
Use your bottom barrel to draw down for drink. Then top the bottom barrel with likker from the middle barrel. Then top the middle barrel with likker from the top barrel. And top the top barrel with your white dog.
Depending on the size of your barrels and your draw down rate,,you could have relatively well cycled aged drinking stock that can be drawn off kinda regularly.
Maybe not a perfect solution but certainly not a bad solution I recon.
It's on my list.
A few years ago I did something the same with some rough fortified wine.
I used a row of glass bottles, some five- but mostly two-litres. Standing up.
The first filled was set maybe one or two feet below the rest; the last to be filled, maybe one or two feet above the rest.
After the first filled one (which is the one from which product would be drawn) I connected tightly to the bunghole in a little barrel, set maybe a foot below that jar, with a tap.
All the jars had bungs with two holes. Rubber, which would be unsuitable for spirit, so you would need to improvise there.
The last to be filled had a little airlock on it.
Then there was a tube from low in the first jar in the row (the one with the airlock);
(the last to be filled, which would be the highest in the barrel set-up),
to high in the next. And a tube from low in that one to high in the next; and so it went, adding more bottles to the 'filling' end as the supply increased.
It worked fine. You place a glass under the tap on the little barrel, and as your glass fills you see and hear the airlock letting air into the furthest jar and watch the level dropping there.
A Solera. Not dead accurate because of possible currents within the jars, but I think accurate enough because the draw would create a gentle current, for a very short time.
Anyway, a rough solera none-the-less. And a fun thing, too.
BTW The plastic U-tubes would be a no-no for spirit but our excellent coppersmiths could easily make copper ones.
Remember, one long leg for the first, a short leg for the next. Each time.
Cost? Maybe zero, depends on what you have have hanging around.
