bubblifier
Re: bubblifier
Very nice.
Prairiepiss
Re: bubblifier
Post by Prairiepiss »
That is sure a thing of beauty. Very nice camera work.
condensificator
Re: bubblifier
Post by condensificator »
thanks y'all! feels good to get the wheels spinning again....
aqua vitae
Re: bubblifier
Post by aqua vitae »
You are a true artist condensificator.
What kind of camera do you use?
condensificator
Re: bubblifier
thanks. my camera is a nikon d40x 18-200 lens. the image sensor is shot from living in the workshop, that's why there are always little specs in all of my pics. new similar models (d3000 d3100) have a built-in image sensor cleaner...gots to get me one. there was a recent thread on cameras here: http://homedistiller.org/forum/viewtopi ... ilit=nikon
Mr.Spooky
Re: bubblifier
Post by Mr.Spooky »
Kentucky shinner wrote:I have been ordering from them and the prices are great.
i looked at the websight and it said "type of business , whosale" dont that mean that they wont sell to the average joe?????
BTW,, those are some good prices :D
spooky
acfixer69
Re: bubblifier
Post by acfixer69 »
Hey Spooky
Have credit card ....Will sell
Paladin
Mr.Spooky
Re: bubblifier
Post by Mr.Spooky »
condensificator wrote:thanks. i actually got turned onto a better source from someone else on the forum, and it's very close to me, so i save on shipping: http://www.klgstainless.com/Ferrule.html
i did bookmark the austenitex site, though, in case i need something the klg place doesn't have.
so,,, this KLG place,,,,,,,, im trying to order some stuff,,,, and it wont let me build a "shopping cart"..
after i hit the "buy now" on a item,,, it wont let me go back and add to the cart :evil: .
what am i doing wrong????????
thanks
spooky
exon
Re: bubblifier
Post by exon »
Are those the two fellers who used those hard-hat diving rigs last? :roll:
exon
I am a pathological liar and functional illiterate.
Mr.Spooky
Re: bubblifier
Post by Mr.Spooky »
exon wrote:Are those the two fellers who used those hard-hat diving rigs last? :roll:
exon
:?: what
spooky
WalkingWolf
Re: bubblifier
Post by WalkingWolf »
He's a'ight now spook -- he had to step back and put a cold rag on his neck -- poor fella overheated.
Mr.Spooky
Re: bubblifier
Post by Mr.Spooky »
thanks
spooky
bu bu bu bu bump
kenfyoozed
Re: bubblifier
Post by kenfyoozed »
I've bought items from klg. I check their website again but it looks like it's not working properly. They also sell on eBay. I have in the past contacted them through eBay and got them to put an order in for me. Although lately I like stpats. Great service and fast shipping.
Copperman
Re: bubblifier
Post by Copperman »
condensificator, when you turned the inside of the weld ferrels to seat the glass, does the glass sit flush with the ferrel or is there a little protrusion to allow for a slight compression of the gasket when the tri-clamp is tightened?
Great looking project BTW.
condensificator
Re: bubblifier
the ones you are talking about, i turned so the glass was inset flush in the recess. the newer way that i am doing it requires no turning: http://homedistiller.org/forum/viewtopi ... 73&start=0
both ways have been tested and work.
EscarpmentDew
Re: bubblifier
Post by EscarpmentDew »
Condensificator, one of the things that has bothered me about my build is that there are places in my still that seem to hold liquid unless I hold the still at just the right position to drain it (nothing much really). I don't know if you see this as a potential problem with j-traps but I can't help but think that drilling one or two 1/16" holes into the bottom of the j-trap would be a benefit because it would allow proper drainage once the vapour flow ceases but would most likely hold liquid in the j-trap as long as there is a vapour pressure just as a normal perforated plate will. I was also thinking about using a 90 angle instead of a j-trap just so that there is drainage and there isn't a direct vapour path, but I doubt this would have the desired effect. Anyways, I'm not doing a build until I've finished reading flute talk and Complete Distiller. I'm a little fuzzy on the details.
Your still has the sort of beauty that only an object of nature seems to have, like an old mossy tree but the colours sparkle. Time and good use will be the final distinguishing characteristics no doubt!
Moved on up from distilling neutrals from simple cereal mashes to experimenting with grains and oaking.
Mr.Spooky
Re: bubblifier
Post by Mr.Spooky »
EscarpmentDew wrote:Condensificator, one of the things that has bothered me about my build is that there are places in my still that seem to hold liquid unless I hold the still at just the right position to drain it (nothing much really). I don't know if you see this as a potential problem with j-traps but I can't help but think that drilling one or two 1/16" holes into the bottom of the j-trap would be a benefit because it would allow proper drainage once the vapour flow ceases but would most likely hold liquid in the j-trap as long as there is a vapour pressure just as a normal perforated plate will.
nice observation EscarpmentDew.
spooky
condensificator
Re: bubblifier
thanks ED...makes sense. i'm not really concerned with that at the moment, but once i am running and trying to tweak things so they are perfect, i'll re-think this...sounds right to me? i was already planning on doing a little drain hole on the bubble-cap plates for that very reason (which i am going to have to wait on so i can get going on this bitch!!! perf-plates will be the first set).
EscarpmentDew
Re: bubblifier
condensificator wrote:thanks ED...makes sense. i'm not really concerned with that at the moment
I trust your intuition more than mine. I am really just starting. Just trying to throw some ideas into the wind.
condensificator
Re: bubblifier
i'm just starting myself! i think it's a solid idea and will prolly end up being in service after bubblifcation.
Re: bubblifier
Teehee :ebiggrin:
He said bubblification.
condensificator
Re: bubblifier
rockchucker22 wrote:So dude are you doing perf or bbl plates?
both...and valves...and whatever else comes down the pike...
perf first since i don't have a lot of time right now.
condensificator
Re: bubblifier
rockchucker22 wrote:You had the caps done that's 75% of the build. Either way can't wait it will be awesome. 8)
nope...not the way that i am doing it...more like 25-50%. i am doing them bolted on to 1/2" riser caps. i will get there, but i am SUPER busy right now...no time to play.
exon
Re: bubblifier
Post by exon »
condensificator wrote: but i am SUPER busy right now...no time to play.
...this is NOT good...
Work getting in the way of play. :wink:
...but good for U, condens !
Glad ur werk is something u love!
You are a fortunate fellow. :)
I enjoy your posts and very much appreciate you posting along with your pics.
exon
Chiller
Re: bubblifier
Post by Chiller »
Apologies for off-topics:
Has anyone bought from KLG's site recently? The site looks like its being updated, I'm having the same problem as spooky but can order one at a time if necessary. I was just wondering if they're still operating, I'm in America until the 26th (April) and, if i order today or tomorrow will I get my parts in time/at all?
- Chiller
Poetic, not poetry
acfixer69
Re: bubblifier
Post by acfixer69 »
Chiller Try this link http://klgstainless.com/Ferrule.html" onclick="window.open(this.href);return false;" rel="nofollow I had the same problem :)
AC
Chiller
Re: bubblifier
Post by Chiller »
Oh, I was aware of that link :D what I meant was: is it still ok to buy from them? As in, it won't take 2 weeks for delivery?
Edit: KLG doesn't supply gaskets - is there some sort of standard? I.e could I buy them from somewhere else and they would fit?
Poetic, not poetry
Kentucky shinner
Re: bubblifier
Post by Kentucky shinner »
Chiller wrote:Oh, I was aware of that link :D what I meant was: is it still ok to buy from them? As in, it won't take 2 weeks for delivery?
Let me know what you need I will send it with your other stuff.
Chiller
Re: bubblifier
Post by Chiller »
Sorry ks I already placed my order with them! I had to go with the cheapest option, sure you can understand, on a tight budget :( So I tried my luck. If they don't deliver, then I'll cancel, and get them from you before I go back. Still send the original order I placed with you asap please
Poetic, not poetry
likkerluvver
Re: bubblifier
Post by likkerluvver »
Bump
Hey Condensificator, I'm wondering whether you've done any more work on your "Bubblifier". What you had completed sure looked impressive. :)
LL
