Hi from Ohio
conejo148
Hi from Ohio
Post by conejo148 »
Hey all,
I Inherited a 50 gallon stainless pot with matching arms, valves, and 30 gallon thumper, copper worms, and even 8 plastic food grade blue barrels-basically everything I need to get going. Came from the western Virgina hill country by way of my father inlaw. Look forward to using it to power the Mrs. E-85tahoe, and to help beat the chill up here when it gets cold. I realize a reflux may be better for making fuel, but hey, it's what I got. :D
My first question is that my drinking water is from our pond, treated by various mechanical filters and treated with iodine 2 times a year. The iodine isn't taste-able after about 2 weeks, so I wouldn't run anything until a month after the treatment, but can this cause any problems with flavor, or worse yet, health? I'm inclined to say since I drink it, it's ok, but never hurts to ask.
Second question, given the size of the still, I'm going to go with a propane burner..any idea how long should it take for a stripping run so I make sure to set aside enough time? Most of what I've read is all in liters, and my thermodynamics are a bit rusty.
I should note that I've watched my previously mentioned father-in-law, so I've got the set up down, use of the flour paste, vapor leak-testing, so the size of the still doesn't scare me any more than if it was the little 5 gallon stovetop cooker I use the woodshop stove. He always used wood to heat, so not sure how to translate to propane.
Thanks for all the great info so far, looking forward to putting it safely to use.
Re: Hi from Ohio
Greetings................
But why did your FIL part with his rig?
conejo148
Re: Hi from Ohio
Post by conejo148 »
Retired back to Virginia and is also diabetic and gave up drinking. He thought I would enjoy it, plus given his surroundings, a lot less likely to get me in trouble than him.
Re: Hi from Ohio
Welcome, I would say you really got a jump start :D As far as the pond water someone else might have an answer for you. I am on a well and use a purifying system that works well for me!
Kentucky shinner
Re: Hi from Ohio
Post by Kentucky shinner »
Greetings.. hey if you dont mind post us some pics of your rig.. I would love put my eyeballs on her.
conejo148
Re: Hi from Ohio
Post by conejo148 »
Here's some pics of her in the barn, didn't want to lug all of the stuff out of the loft yet, wife gets upset when I mess up MY barn....go figure. Not yet warm enough to get her going, but going to clean it all up this weekend. The silver ring at the top of the barrel is actually the stainless lip rolling over the side--seamless and polished smooth on the inside.
Cooker with 55 gallon barrel lid for reference
Pot with 55 gallon barrel lid.jpg (16.92 KiB) Viewed 626 times
Worms, thumper, and such
Closeup of 2" valve
Closeup of 2" valve
Valve Closeup.jpg (14.53 KiB) Viewed 626 times
Dnderhead
Re: Hi from Ohio
Post by Dnderhead »
when in question ,do a small ferment.then you will know.
