What is a parot? Operation And design..
I NEED to know what a parrot is and its operation as well as design. Ive looked and cannot find an answer.
Re: What is a parot? Operation And design..
http://homedistiller.org/forum/viewtopi ... 08&start=0
holds the hydrometer and used to catch the output from still so you can have a continuous reading.
I moved this from mentors to here. It'd hardly a mentors question.
Fer crissake I typed parrot intp the search function and got this.
Search found 1380 matches
Search term used: parrot
1380 and you couldn't find one!!! Is this an indication of what we can expect from you in the future or will you actually try???? http://homedistiller.org/forum/viewtopi ... 9#p6885409
Cumudgeon and loving it.
It's a liquid circuit which allows a hydrometer to be floated to measure the abv of the distillate.
Probably because Parrot was spelled with only one 'r' ('parot')blanikdog wrote:I moved this from mentors to here. It'd hardly a mentors question.
snip
I typed parrot into the search function and got this.
snip
Even parot (which incidently I think is the correct spelling ) returned a generous amount of information. )
Search found 71 matches
Search term used: parot
Parrot is a container that accommodates an alcometer allowing the input to be secreted at the bottom and the overflow to go out thru the parrot's beak.
It talks non-stop tellin the ABV as it happens, live, as seen on TV!
