All these drawings and Illustrations will serve to give us a very detailed resource complete with parts list and step by step in structions on how to build...
and so it continues... Just noticed the new Smilies, big hand for the mods...
The thermometer probe is shielded within its own port and never comes into contact with the refluxed distillate on its way to the trays. Dont know how the other guys have done this, but I will do it with a scalloped ½" pipe... I'll do a quick drawing of it tomorrow as a piccie speaks a thousand words...Usge wrote:Got a question Sam....what keeps the refluxing distillate dripping down from above from throwing the therms' reading off?
The height will be the same, whether it's inside or on top of the column.Mr.Spooky wrote:the heigth thing was the only thing that i ran across when i was concidering doing a "drop in deflag". im gonna go ahead and do a external deflag just because of that
Centimeter wrote:I was wondering, wouldn't directing reflux from one plate to another plate mess up the equilibration of the column? I thought a plate was more of a thermal environment rather than a physical plate. If you direct cooler condensate from a higher up plate to a lower plate, aren't you essentially making two plates with the same/similar thermal environment, thus negating the "plate"? It seems to me that a more stable approach would be to send it all back to the boiler and have it start over again.
My original design does not have the pipe going through, Samohon made it that way for easier construction.Rum Bum wrote:It looks sharp so far! In the diagrams it shows the pipe that goes off the column going all the way threw to the other side for more support, I see you just soldered yours straight to it. Which I'm sure is fine with your solder skills, you make everything look like a breeze Minor detail but if you had gone all the way through, would you just drill some holes in the bottom of the pipe to keep the vapor flow?... Would you use slits, holes, or cut a large slice out?
Ther are 2 ways to do this... If, like OD, your soldering skills are up for it, then mounting the pipe directly onto the face of the 4" pipe is the way to go. If not, the the pipe can be put all the way through the 4", capped and scalloped... Would even add a little more rigidity IMO...Rum Bum wrote:In the diagrams it shows the pipe that goes off the column going all the way threw to the other side for more support, I see you just soldered yours straight to it.
No its only a brass ring about 1/4"thick that just slips over the tube, and when soldered to the tube and the column it makes a firmer joint without having to put gobs of solder to make it stronger.Samohon wrote:Like a tank connector OD..?
Not quite sure what you are trying to say there,,,,,but I shall restrain myself from experiencing the personal humiliation that you seem to be hoisting upon my soldering skills..olddog wrote:makes a firmer joint without having to put gobs of solder to make it stronger.
You can just see the soldering on the bottom plate in my last pic. The method was first mentioned by LWTCS when he built his thump tower, You position the plate in the column, then cut a length of soft silver solder, and bend it so it fits around the inside of the column, you then flux the column and plate and drop the solder ring into the column which should then sit on the proposed joint area where the plate contact the column. You then apply heat to the outside of the column in the area where the plate sits. Its important to move your torch away as soon as you see the solder melting, otherwise too much heat will liquify the solder and it will run through the joint and down the inside of the column, but the outside /inside method works well in places where you can't get a torch.guittarmaster wrote:By any chance did you take photos of how you soldered those plates and weirs in there?
