noise and stealth...
Re: noise and stealth...
Strange you couldn't find a three ring burner....
Here in Aus they are in every camping gear shop along with two and four ring burners.
The three was about .... $40 Au
TAF
TAF
Build it, don't buy it
oh, i found a few, in new zealand and austrailia, but nobody would ship to usa...
strange...
strange...
tell me how hard it is to do... tell me how expensive it will be... just don't tell me what i can not do...
lead, follow, or get out of the way... ankle biters will be kicked...
•*´¯)¸.•*´¯)¤ª"˜¨¯¯¨˜"william..."˜¨¯¯¨˜"ª¤(¯`*•.¸(¯`*•
Sorry LW, I thought you were joking about the flip flops. I've had some pretty nasty steam burns from boiling tea kettles and they hurt like hell. Also had a boiling tea kettle fall onto my leg and the scalding hot water ended up in my boot. Nothing funny about a burn ...LWTCS wrote:Funny for you.
I don't move so good any more. I only have enough "spring in my step" to audibleize my displeasure.
Could drop 20 pounds I guess,,,,,or put the dump valve and hose on my next boiler.
I do all my own stunts
- LWTCS
blind drunk wrote:Sorry LW, I thought you were joking about the flip flops.
Ah don't give it another thought......
No more flip flops,,,,,or just let it sit till the next day...
Is there something magic about a three ring burner? I have a single ring Bayou Classic that puts out plenty enough heat to run a beer keg boiler.hackware wrote:oh, i found a few, in new zealand and austrailia, but nobody would ship to usa...
strange...
Braz
ok just read your post.Everman needs a shed,or a leanto,build one behind the trailor,leave the lawn mower outside the door..it fools them evertime.just saying.. miss direction..
I was thinking exactly the same Fastill. Mine's the same. I use an 8" outer ring with a 5" inner ring ander a fifty litre boiler. As soon as the heat is right - using the spirit flow, NOT a thermometer - I turn the large ring off, reduce the small one to give a steady pencil lead flow and there is not a sound apart from my occaisional fart (which I do to cover the smell of ethoFastill wrote:I don't know what kind of propane burners some of you are running but I bought a cast Iron camp stove, my keg sits right on top of it, heats up 10 gallons in about 1hr15min. and I have to look under the keg just to see if it is on. Literally can NOT hear it run. Like an indoor propane stove burner but made for camping.
I shudder to think of the boiler size that requires a burner that makes any discernable sound. Maybe I'm more deaf that I thought , but the missus agrees that the noise is the least of my problems, of which - according to a couple of forum members - I have many.
Cumudgeon and loving it.
Could this be considered a safety risk? If not for the fact it is a flammable gas near a open flame. But also the risk to others health that may be in smelling distance?blanikdog wrote: there is not a sound apart from my occaisional fart (which I do to cover the smell of etho)
at the rate it is taking me to get started, i won't need an outside burner till this fall...
been too friggin hot to do anythin outdoors anyway...
had thought to b living n my rv by now...
this mississippi humidity is killing me...
(spent the last 30 years n a desert...)
but sumtimes this topic is better than tv...
i will find a way to get a quiet burner yet...
just had a wild ass idea...
how about a v8 powered still...?
really...
an e85 powered pickup truck, exhaust powered heat exchanger to a boiler...
plumbing inside a bed mounted tool box...
really...
I bought a turkey fryer kit for cheap and use the burner from it it is quiet and gets the job done I just had to bypass the timer
Thought I had had some bad dump outs but that one is too funny LWTCS, I'll try to remember not to pull that one. Still laughing.
The burner I have now is a jet engine but my old one was one of the circle type burners and it was quiet.
