One of my pots just had the handle break off the center of the lid. I'm wondering if I can turn it into a quick and easy (and very small) pot still.
It's a 5qt metal pot (best I can tell), with a food grade (obviously) teflon lining and a glass lid. The lid has a 5/32" hole in the center from where the handle used to be mounted. I'm thinking I can just drop some 1/4" copper tubing down that hole and seal it, bring the tubing up and into a coil to condense. I figure I'd seal the lid and the tubing with either PTFE tape or flour dough.
I'm sure I won't get great results from this, but I think I can pull it off for about $20 (flexible 1/4" copper tubing, plus however I do the condenser). I think it might just be an interesting starter project before I build a real still.
Does this sound feasible? If so, what's the recommended condenser? I'm leaning to worm bucket, but open to suggestions.
Pot to pot still conversion?
Re: Pot to pot still conversion?
1327539551 wrote:One of my pots just had the handle break off the center of the lid. I'm wondering if I can turn it into a quick and easy (and very small) pot still.
NO
Bayou Ethanol
Ethanol Fuel Producer
AFP-LA-15027
http://www.BayouEthanol.com" onclick="window.open(this.href);return false;" rel="nofollow
AFP-LA-15027
I'm now confused - when reading through the forums, it was repeated over and over that PTFE (Teflon) is the only safe plastic - why is it safe for seals and gaskets and not the boiler?
Glass is no good. Yes I'm aware of the consensus on PTFE gaskets. I don't believe its feasible to use a boiler coated with PTFE. Others may offer a different view, but that's my position.1327539551 wrote:I'm now confused - when reading through the forums, it was repeated over and over that PTFE (Teflon) is the only safe plastic - why is it safe for seals and gaskets and not the boiler?
Bayou Ethanol
AFP-LA-15027
AFP-LA-15027
I don't see why the glass lid should be no good. After all, on the parent site it pictures an all glass pot being used as a flavor still.Bayou-Ruler wrote:Glass is no good. Yes I'm aware of the consensus on PTFE gaskets. I don't believe its feasible to use a boiler coated with PTFE. Others may offer a different view, but that's my position.1327539551 wrote:I'm now confused - when reading through the forums, it was repeated over and over that PTFE (Teflon) is the only safe plastic - why is it safe for seals and gaskets and not the boiler?
As for the Teflon coating in the pot. I am personally wary of Teflon coated kitchen equipment and it has all been banned from our house for many years. A properly seasoned cast iron pan provides a better non-stick surface anyway - but I digress.
She's only a whisky maker but I love her still.
Teflon coated pans are not good to cook food with in my opinion. So I wouldn't use it in a still. By the way that pan coating is differentr then the PTFE used for sealing purposes around here.
Just my 2 nickels
Just my 2 nickels
i agree, we did away with all teflon coated pans around here, it peels off eventually and i dont want it in my food or drink. btw sooner or later you will not be happy with a 5 qt. pan anyway, its far to small for making cuts ect. go as large as you got room for, 5 gallons is a nice size to learn on, better yet get an 8 or 15.5 beer keg.
today marks the dawn of a new error.
