Couple of questions and Yes ive read and searched
BackwoodsBBQ
Post by BackwoodsBBQ »
Well being a fng here I figured id get a couple things out there. One there is so much information here it can be hard to find information on one particular aspect of something, Ive got a couple of good ideas for this and will save those for a another time though. I am sure the info i want is here but sometimes there is so much conflicting info that its hard to determine the right one.
Example my question number one,
On a vm still head is there a port to atmosphere? Ive seen plans and stills here with and without though i think the ones without just neglect to mention or diagram a vent?
And also what size for atmosphere vent and does it protrude down into the cap at all?
Still I am currently working on is a vm with the boka style lm take off for heads ect basically its easy to do and gives me more versatility.
Question 2 when determining height I know there in no advantage to going more than 30 x diameter but is that including the condenser? Or just up to take off port?
Height is not an issue for me this is going to be for the purest neutral i can get. And im not worried about production speed either. Money isnt an issue here i just want to make the best that i can.
and last one 3
The condenser coil. Double wound, cold finger, ect ect if get this right the more cooling area the more reflux the higher rate of out put? Or is it more relfux cleaner product? I mean i can create something that cools extremely well with about 10 times the surface area of the coil method but is there a point to it?
This topic has 11 more replies
Register Login
