3"boka packing
Sloanick
3"boka packing
Post by Sloanick »
I am just finishing up my 60" tall (plus condenser) 3"wide boka.
Where is the best place to order packing?
I was looking at smileys but I also wasn't sure how much I would need seeing that most information is for 2"columns
any help would be great.
Also has anyone had any experience with a 3/8 take off needle valve?
I chose 3/8 so I can do striping runs.
yes I know they have lead. I will pickle.
I was thinking of modifying it by filling in the hollow needle. I read that on another post. I think it was by rad... I could be wrong though.
Sloanick
Re: 3"boka packing
Post by Sloanick »
26 views and no advice? :(
I called smily's and left a message but they haven't gotten back to me.
if anyone has packed a 3" column and knows a good supplier i would love to know about it ;)
Prairiepiss
Re: 3"boka packing
Post by Prairiepiss »
Try mile high. They sell packing. And 3" stills. So mike mite be able to help you out.
I've never packed a 3" so I can't help you there. And I just use Scrubbys I buy at wallgreens.
Sloanick
Re: 3"boka packing
Post by Sloanick »
Thanks! I will check them out!
I tried using my scrubbys from my old still lol not a chance
Sloanick
Re: 3"boka packing
Post by Sloanick »
for you folks in the U.S. you can get pest control copper mesh pretty cheap! I could get it too but shipping is over $100!!! :shock: anyway it is free for you guys so have at it.
rubber duck
Re: 3"boka packing
Post by rubber duck »
You could try lava rocks, MR has been having a lot of success with them. The worst that could happen is it doesn't work for you and your out 5 dollars.
Sloanick
Re: 3"boka packing
Post by Sloanick »
rubber duck wrote:You could try lava rocks, MR has been having a lot of success with them. The worst that could happen is it doesn't work for you and your out 5 dollars.
WOW thanks! Just read the whole thread! skimmed a bit but got everything i could about lava rocks.
So long story short. They are safe, and work great in a 4" column
They are safe right?
I am going to try them in my 3"
VERY helpful! you saved me 70 bucks my friend
moe fishwater
Re: 3"boka packing
Post by moe fishwater »
I know I'm coming in late on this, but I thought I would share. This is where I found very affordable copper mesh. It's used for rodent proofing houses. http://www.pestmall.com/search.php?keyw ... b81399fd1f" onclick="window.open(this.href);return false;" rel="nofollow
Some go to church, and think about fishing. Others go fishing and think about God. http://www.pleasantpheasant.net
Sloanick
Re: 3"boka packing
Post by Sloanick »
moe fishwater wrote:I know I'm coming in late on this, but I thought I would share. This is where I found very affordable copper mesh. It's used for rodent proofing houses. http://www.pestmall.com/search.php?keyw ... b81399fd1f" onclick="window.open(this.href);return false;" rel="nofollow
yes I was very excited when i found this! but quickly disappointed when i saw the shipping price to canada :cry:
lava rock is working great just so ya all know!
rubber duck
Re: 3"boka packing
Ya they're not bad at all are they? It's the cheapest and easiest way to pull 95%+ I've found.
Two questions, are you breaking them up into smaller rocks or are you just using them as they come in the bag? What's your approximate run speed and abv?
sambedded
Re: 3"boka packing
Post by sambedded »
I've read reports about using ceramics rings for aquarium filters. Like this one - http://www.amazon.com/Hagen-Fluval-Pref ... B006C8H24G" onclick="window.open(this.href);return false;" rel="nofollow. Some peoples claims that this media much better than cooper/stainless scrubbers, others said it works similar to scrubbers. Any way - I'm going to try and you can buy this stuff at any petstore.
Sloanick
Re: 3"boka packing
Post by Sloanick »
rubber duck wrote:Ya they're not bad at all are they? It's the cheapest and easiest way to pull 95%+ I've found.
I am just using them as they came with a centring ring half way down a 60" column (plus condenser & plates)
I have to admit I am very new and poor so I'm saving up to build my parrot, and a good thermometer.
I took the first 300ml off slow! like a drip a second. then I got sick of waiting and playing with the still (my water pressure is up and down making it very hard to keep the output warm/hot without vapours escaping) then I kicked it up to a dribble for the whole run kicking out 3L at 96percent (hydrometer is probably a bit high, and yes i'm bring the temp down)
I could not detect heads! I used to be able to smell them so easy on my old PM/CM still and i could smell them in the foreshots (300ml of a 40l wash)
maybe wineo's plane old sugar wash just doesn't put out too much heads...
even at a dribble this was a 7 hr run though...
Maybe i couldn't smell heads because I had to clean the kitchen up and didn't let it air for 24hrs too... (i have to unplug the stove to run my still lol)
