The Book of Dnderhead
The long and storied history of distilled spirits.
HolyBear
Post by HolyBear »
"Blessed is the man who finds wisdom, the man who gains understanding, for she is more profitable than silver and yields better returns than gold. She is more precious than rubies; nothing you desire can compare with her. Long life is in her right hand; in her left hand are riches and honor. Her ways are pleasant ways, and all her paths are peace. She is a tree of life to those who wait embrace her; those who lay hold of her will be blessed." Proverbs 3, 13-18
Dnder has true wisdom of this craft. I've gone back and read most all of his posts. It occurred to me that there would be real value in condensing his words/sayings into one thread. This thread may fall short of the intent since cut and pasting his words I think would only scratch the surface of the wisdom I believe he holds, but at least it is an attempt. This thread may even become a reference...
Before posting to this thread, please read
http://homedistiller.org/forum/viewtopi ... 15&t=34613 thank you
HolyBear
Re: The Book of Dnderhead
Post by HolyBear »
Re: Stripping Run by Dnderhead » Thu Dec 27, 2012 1:24 pm
I like to take fore shots off each run.
HolyBear
Post by HolyBear »
Re: pump size for liebig
its not so much how big of pump,its the how efficient it is.it needs to pump to the height (head) and still push threw the cooling lines.
by Dnderhead Thu Dec 27, 2012 11:00 am
Forum: Novice Distillers Topic: pump size for liebig Replies: 5 Views: 80
HolyBear
Post by HolyBear »
Re: Long Fermentation -- error?
mashing is: cooking raw grain,then converting with enzymes /malt. as flaked grain is cooked (this depends where you git it) the cooking part is/maybe not not necessary,but boiling hot water is ,then cooled to mashing temps.(at this time you add malt/enzymes) these can start at 100f or 140f depending...
by Dnderhead Wed Dec 26, 2012 9:41 pm
Forum: Mashing and Fermenting Topic: Long Fermentation -- error? Replies: 9 Views: 87
HolyBear
Post by HolyBear »
Re: Help me understand these results?
either our thurmomater is off or you live on mount Everest. Id say first 100ml fores ,,next 200ml heads?
by Dnderhead Wed Dec 26, 2012 7:00 pm
Forum: Column Distillation and Design Topic: Help me understand these results? Replies: 3 Views: 47
That's a good one, :D
just-a-sip
Post by just-a-sip »
"remember a UNION is full of nuts.....HA HA"
Re: Adjustable Lyne Arm and/or Liebig
by Dnderhead » Wed Dec 26, 2012 6:25 pm
Just-A-Sip
HolyBear
Post by HolyBear »
Re: wine no ferment
Id add the calcium carb. and see.yeast are pretty tough little buggers.
by Dnderhead Wed Dec 26, 2012 11:50 am
Forum: Beer, and Wine Topic: wine no ferment
HolyBear
Post by HolyBear »
Re: I'm scared to ask by Dnderhead » Wed Dec 26, 2012 11:35 am
""I would look into freezing fruit wine" i would NOT consider doing this,it not only will condense the ethanol but all the head aches as well. much of the "fruit" brandy in US is brandy that flavoring is added. best to git neutral/vodka and then flavor as you want.Id start with fruit consecrate .adding as you want then sweeten. berries lend well to this.it wont be real brandy but ????? keep track of what you add,so either you can repeat or not.
Dnderhead Master Distiller
Posts: 11825 Joined: Sun Dec 23, 2007 10:07 pm L
HolyBear
Post by HolyBear »
Re: Water to Grain Ratio?
just fallow one of those recipes or others on tried and true,they are known to work. don't dive in ,trying to make your own recipe until you under stand what your doing. you will/can just git frustrated .
by Dnderhead Tue Dec 25, 2012 5:49 pm
Forum: Novice Distillers Topic: Water to Grain Ratio? Replies: 10 Views: 73
just-a-sip
"I have people come to me and want something like"X"
I do not Know what to tell them I haven't Had Commercial
in 20 years."
doing something right
Postby Dnderhead » Tue Jan 01, 2008 1:19 am
Just-A-Sip
HolyBear
Post by HolyBear »
Re: Column condenser
a pot still does not have a condenser in the column.(a reflux condenser)
by Dnderhead Wed Dec 26, 2012 2:40 pm
HolyBear
Post by HolyBear »
good idea,oaking is one of them all or nothing things.sort of like making coffee. once you start you need to finish,or it will taste like crap.
by Dnderhead Tue Dec 25, 2012 2:45 pm
Forum: Flavoring and Aging Topic: Aging on Oak......bad idea or bad oak, not sure Replies: 12 Views: 163
That's a good one... :D
HolyBear
Post by HolyBear »
Re: keg still help
that's a pot still no thermometer needed.
by Dnderhead Tue Dec 25, 2012 9:57 am
just-a-sip
"leave the drips for the reflux guys,bring it up to a small stream."
Re: RUN TIME I need sleep
Unread postby Dnderhead » Sat Dec 22, 2012 2:31 am
Just-A-Sip
HolyBear
Post by HolyBear »
brandy is distilled fruit wine,a bit more regulations than that but that's basic. if you do not want to ferment/distill you cant make "real"brandy. if you buy alcohol and flavor then that's what you have ..flavored alcohol/vodka
by Dnderhead Tue Dec 25, 2012 8:38 am
Forum: Novice Distillers Topic: I'm scared to ask Replies: 6 Views: 204
HolyBear
Post by HolyBear »
Re: Just musing by Dnderhead » Tue Dec 25, 2012 2:22 am
refluxing its sort of like going up stairs,2 steps up and a step back,each time it does this its redistilled. now each of these "steps" are graduated from "hot" on bottom to "cooler" on top.
Posts: 11826 Joined: Sun Dec 23, 2007 10:07 pm Location: up north
HolyBear
Post by HolyBear »
Re: hydrometer reading
"than one 7 gram packet of yeast was needed for a 19L/5gal " in theory you could start a ferment with two yeast cells. more yeast prevent "lag" this is the time it takes to start fermenting. but to much can cause off flavors,to much competition can make them become cannibals.
by Dnderhead Mon Dec 24, 2012 12:52 am
Forum: Novice Distillers Topic: hydrometer reading Replies: 9 Views: 137
HolyBear
Post by HolyBear »
Re: Straining mash getting ready to run
lees are,,grain,yeast,etc that fall to the bottom (all the stuff that dont ferment) sort of looks like yellow mud.
by Dnderhead Sun Dec 23, 2012 7:55 pm
Forum: Novice Distillers Topic: Straining mash getting ready to run Replies: 7 Views: 67
HolyBear
Post by HolyBear »
Re: Mr. Distiller by Dnderhead » Sun Dec 23, 2012 7:51 pm
IT IS STRONGLY Suggested NOT TO LEAVE IT UNINTENDED!!
HolyBear
Post by HolyBear »
Re: Wineos Plain Ol Sugar Wash
Ive never made this wash, but whats the temperature? (there are several causes of "stuck" ferments)
1,to much sugar
2,wrong temperature
3,lack of nutrients
4,low PH
5,weak yeast
by Dnderhead Sun Dec 23, 2012 10:45 am
Forum: Tried and True Recipes Topic: Wineos Plain Ol Sugar Wash Replies: 668 Views: 70875
ipee7ABV
Post by ipee7ABV »
cant wait till we get to the egg one
ipee7ABV
Post by ipee7ABV »
ok couldnt wait
if so a fresh egg will float to the top ,in a mix of 1.070-1.080sg.(9-10%)
this is about right for most ferments.your proof hydrometer just wont work.
some place i have a chart of sg=% alcohol,,,sg=% sugar ,,,but wont it wont do you much good.
WIski
Post by WIski »
by Dnderhead » Wed Sep 19, 2012 4:27 pm
"...suffice to say, you cant make whiskey in a week . I would recommend you stop putting it in the freezer and just let it age on it's own in the garage ""
exactly ,been saying this for years,, really heat ages faster than cold.(its a chemical reaction)many of the things that is so called forced/fast/quick aging.should be called "half ass aging" some make a slight diferance other nothing.if "the big boys" haven't figured it out with a million dollar budget how do you expect to.
WIski
Post by WIski »
WIski wrote-
Nominate Dnderhead for president!!! Common sense on every table and World Peace. Not to mention very entertaining.....
by Dnderhead » Thu Sep 20, 2012 8:55 am
""Nominate Dnderhead for president!!! ""
DONT git me started on that!
HolyBear
Post by HolyBear »
Re: do i need to clean my jugs? ;) if it was water then use as is.what are you going to do wash water out with more water?
by Dnderhead Fri Dec 21, 2012 3:38 pm
Forum: Safety and Related Issues Topic: do i need to clean my jugs? ;) Replies: 8 Views: 128
HolyBear
Post by HolyBear »
Re: Silver/White Rum Help by Dnderhead » Fri Dec 21, 2012 1:11 am
i say a diferant approach,,rum is made form molasses,good molasses is best. white rum is left in the white,aged in stainless or glass,but some is aged in wood ,then the color is filtered out. gold and dark rum is aged in wood. heavy rum (navel)is distilled once or twice in a pot still. the lighter rums are distilled more times or with a reflux still. rum made in Jamaica/Tahiti etc. they also add the scrapings from the "coppers" or the pots they cook down the cane juice in. some of the "cheep" rum (in the US?) is run off with a reflux still then flavored after.
Posts: 11839 Joined: Sun Dec 23, 2007 10:07 pm Location: up north
HolyBear
Post by HolyBear »
Re: WOODSTOVE? by Dnderhead » Thu Dec 20, 2012 8:33 am
ya well those odd looking "pots" the oval shaped ones made of copper,you see made into still boilers. they were water boilers,you removed one front lid one back and the divider,then the boiler fit right over the hole left.they were used to do you "unmentionables",dishes etc. (i guess if you have one ,you could call your product "bloomer shine"
"Bloomer shine"... :lol:
HolyBear
Post by HolyBear »
Re: Apple Shine stalled? Need advice!
I thank your pushing 14% alcohol,it could take a wile to ferment. you will have better product and better ferments if you keep it around 10%.
by Dnderhead Wed Dec 19, 2012 5:11 pm
Forum: Recipe Development Topic: Apple Shine stalled? Need advice! Replies: 14 Views: 200
HolyBear
Post by HolyBear »
Re: SF/ UJSSM/ Caramel
caramel is added after distilling ,even after aging
by Dnderhead Wed Dec 19, 2012 12:06 pm
Forum: Recipe Development Topic: SF/ UJSSM/ Caramel Replies: 11 Views: 167
HolyBear
Post by HolyBear »
Re: YEAST by Dnderhead » Tue Dec 18, 2012 3:23 pm
float around they have no control where they go ,some yeast is called "top" or bottom fermenting. this is really wrong, "top fermenting" yeast has rough "skins" and the co2 becomes attached,so these "take a ride along".(if you have a clear fermenter you can see this)this type of yeast will make more foam.often it is scraped off and used in next ferment in place of using new yeast.
