Flute (or the like) Family Reunion
Flute builders/ operators
If you please,, post a favorite pic of your flute build.
A breif commentary would be very welcome.
This thread is for flute builders only Photo's and build references only, no chat, use the Flute talk thread for that.
Staying un -muddied should help keep any information within this thread readily available and easy to find.
If you have documented your build on HD please also include the link to your thread.
Admin please feel free to amend any part of this request to flute builders.
Your on deck OD as you run the first and this is your design. Waiting on you pappy :D
Mod Edit: ALL comments will be deleted without prior notification...
Kentucky shinner
Re: Flute Family Reunion
Post by Kentucky shinner »
This is my first Flute... I still love this baby,,
http://homedistiller.org/forum/viewtopi ... 6#p6850633
olddog
Post by olddog »
The original Magic Flute was born with the idea for a Plated column like are used by commercial builders to be adapted for use for hobby distillers and to be mounted on a keg or similar, and to be able to produce a high ABV with a single run, and carry over flavor http://homedistiller.org/forum/viewtopi ... 0#p6834790.
OD
Kentucky shinner
Re: Flute (or the like) Family Reunion
This is one I just finished for one of our members here.
This was a cleaning run of vinegar and water. That is why the plastic jug and funnel are being used.
Notice the condensation on the delphag and graham... They are very cool.. the pool water was 49F
Shady's Flute
Shady's Flute
Mr.Spooky
Post by Mr.Spooky »
olddog
Post by olddog »
Here is the 3 plate Flute, custom built for Gretscham
OD
shady
Post by shady »
I received my hillbilly flute from Kentucky Shinner Tuesday this week. I haven't had time to run it or post until this weekend. I have run it twice now and it is awesome. :D It takes a little getting used to but now I am finally getting the hang of how to run it. It gave me great results with a lot of flavor. I am very impressed with the quality of workmanship. I don't think I could have asked for anything more. Thanks KS
moonshiner dave
Post by moonshiner dave »
Alright folks, here she is. I'm thinkin of naming her Big Bertha, but I'm not set on that yet.
The sight glasses are made from 1 1/2" copper unions. It took a lot of grinding and sanding and cussing to get these rounded but I like the look.
How I mounted the thermo. The compression fitting also holds the 1/4" tubing in place that holds the plates in. The other end rests inside a 1/4" cap that is soldered to the outside of the back of the column.
The stone age didn't end due to a lack of stones
Austin Nichols
Post by Austin Nichols »
Here's Mine :mrgreen:
5 plates, 3 windows, 3 reducer dephlag and shotgun product condenser.
Cheers.
Kentucky shinner
I call this one Ole big eyes.. all of my flute builds now have the 2" sight glasses... She went to a Micro distillery in Wa.
olddog
Post by olddog »
Here is the column I built for Dolikeadrink, it can be run in either 4 plate, 6 plate, or 10 plate combinations.
OD
just-a-sip
Post by just-a-sip »
no name yet
here she is though
http://homedistiller.org/forum/viewtopi ... 17&t=27895
Just-A-Sip
Ive been on the forum for a while but never noticed this thread before. Here are a couple of photos of mine.
Sungy
Post by Sungy »
Here is Pennie Lane
She is a 5 plate flute with plates that have valves.
Shot gun dephlegmator and leiberg product condenser.
Digital temperature monitoring and a modulating cooling water valve.
Cooling tower and 45 gallon water barrel.
15 gallon keg boiler.
Links to my builds are in my signature.
Vapour trails
Post by Vapour trails »
Thanks to Old Dog for opening up a new world for all of us. You should be proud of what you accomplished...
Heres what I come up with using the style of OD's MK2 for inspiration.
-4" column and 3 hand built easy flange site glasses
-3 bubble plates with 2" upcomers, 3" (handmade) caps and 2- 1/2" downcomers per plate
-6" reflag with 7- 1/2" tubes
-2" scalloped take off pipe
-3" by 14" shotgun condenser with 4- 3/4" tubes
-26 gallon boiler
Apart from the cooling lines and parrot, there were no fittings used in the construction process. I also soft soldered everything (although tricky to do). She will do a consistent 90%+ at over a gallon per hr with full flavour on KS's sweet feed. And as u can see by the pic below, with the plates filled with packing, 95%+ neutral at relatively the same production (kind of tough to get the packing out after neutral runs).
Feel free to PM me on any build related questions
SideJob
Post by SideJob »
That is beautiful thats for sharing.
