1st build/pot still with reflux column
Prairiepiss
Re: 1st build/pot still with reflux column
Post by Prairiepiss »
Flour paste. PTFE tape. Solder.
You dilute it with water to 40% or lower many say the get better flavors at 30%. Then run it again.
What are you heating the boiler with?
Richard7
Post by Richard7 »
@ 150 proof you could call it done. Dilute it down for drink. If you are after a more neutral do like Mr.p said. Dilute to 40% or 30% and re run.
Prairiepiss
Richard7 wrote:@ 150 proof you could call it done. Dilute it down for drink. If you are after a more neutral do like Mr.p said. Dilute to 40% or 30% and re run.
If he ain't liking what he's getting now. I doubt he would like it single run. Just a guess.
fowlmouth72
Post by fowlmouth72 »
Current recipe is: 6lb flake corn, 2lb rye flakes, 1.5lbs 6 row, 6 gallons water, 6 tsp ec 1118, 6 tsp wyeast nurient, 10 lbs sugar. Corn and rue are cooked for 1 hr first, brought down to 145.....barley added and held at 145. Sparged with distilled water before yeast, nutrient and sugar is added. Takes bout 8 days to ferment.
fowlmouth72
Is flour paste purchase Or made at home?
fowlmouth72
I've ran 3 cleaning runs, 1 with alcohol that got dumped. This is the 3rd since then......the best so far. I know it can be much better though.
One week on heavy toast with a dropper of maple sugar.
mystakilla
Post by mystakilla »
Flour and water= flour paste, good food grade, ethanol sealant!
Prairiepiss
fowlmouth72 wrote:Current recipe is: 6lb flake corn, 2lb rye flakes, 1.5lbs 6 row, 6 gallons water, 6 tsp ec 1118, 6 tsp wyeast nurient, 10 lbs sugar. Corn and rue are cooked for 1 hr first, brought down to 145.....barley added and held at 145. Sparged with distilled water before yeast, nutrient and sugar is added. Takes bout 8 days to ferment.
Sugar alone is 10% ABV potential. Add the grains depending on the conversion you are getting? Seeing how you don't have enough malt. More then likely your not getting full conversion of the starches. So I'm tons guess this one is around 14% potential ABV. Not counting the water you lost to the grains.
Flour past you make.
What are you heating the still boiler with?
And a week on oak ain't long enough for squat.
fowlmouth72
bellybuster wrote:
fowlmouth72 wrote:Distilled water. Why is high apv wort bad? I'm currently running a batch of all grain tha I estimate by taste, smell and yield is between 5 and 10.
Could you explain your process for estimating potential alcohol?
As far as a safe sealant, flour paste.
I've retread this entire thread and my man, you need to do some serious reading on both fermentation and distillation before you hurt someone. Once again, not being an ass, just concerned. It's not my responsibility to say so and maybe not my business either so take it for what you feel it's worth.
No worries, I'm taking it constructively, I've done quite a bit of reading. But when I found this site, I found most of it was either incorrect, not in depth enough or impracticle for home use....basically my base of knowledge is at a reset.
fowlmouth72
The other problem I'm finding is that there are so many suggested methods and recipes for mashing I know I haven't found the right one.... I know a week isn't enough, isn't rot for on it for 3 years.....just a visual of what I'm getting.
Prairiepiss
I would find NC hooch's Carolina bourbon recipe in the tried and true recipe section.
There are many ways people use to mash grains. But more then likely if it involves sugar. It's not a good one to follow. Sugar could be used a little to makeup for short falls from the mash. But after you get a good process down it shouldn't be needed.
fowlmouth72
Prairiepiss wrote:Flour paste. PTFE tape. Solder.
Electric burner with a thermostat......trying to control heat to a minimum. I'm running about 4 hours/4 gallons...cutting off at or about 190 deg. Vapor temp.
fowlmouth72
Prairiepiss wrote:What are you heating the boiler with?
Great....I'll start there after making some changes. Thx for all the help.
fowlmouth72
I'm estimating by yield......1.5 gallon yield @ 89 percent V 5 gallons of wash roughly equals 1/5 or 20 percent
Prairiepiss
Ok from this conversation these are my recommendations. Forget the stuff that got you down the wrong path. And start a new path. Start in the new distiller reading lounge. The safety section is a must too. The parent site is full of useful information. Some is a little out dated. But is a good learning tool.
When you have soaked up all that good info. Then go to the tried and true recipe section. Find a recipe that sounds like something you want to try. Follow it.
Get a mash hydrometer. Learn how to read it. Thread in the new distiller reading lounge.
Fix your still sealant. And rubber.
I'm going to guess on this one because you wouldn't answer my question I asked like 5 times. I'm guessing you are using your stove top to run your still. Electric stoves cycle on and off. This will cause surging which causes smearing of the cuts. So do research on how to remedy that problem.
Reread the novice guide to cuts and the distilling advice threads.
This should get you on a better path. And don't stop reading. And rereading.
Ok I was posting while you answered my question. So I have to add this.
You can not control the temp. The ABV of the boiler charge controls the temp. Like I said earlier. You do not need thermometers in a pot still. They will only be useful as some to occupy your time. And maybe tell you when you are close to taking product off. And maybe tell you when you are close to being done. You run a pot still by adjusting the takeoff rate. Adjusting the heat until you get a broken stream to a pencil lead sized stream.
There are some good threads in the new distiller reading lounge about this. And why you need a good heat source that has fine adjustments and a steady heat input. No cycling.
bellybuster
Post by bellybuster »
My hats off to ya Fowlmouth, ya took a good lickin and still here. Attaboy! Shows good character.
These guys here can bring you from mediocre/poor to a great product. They certainly got me on the right track although now they're just costing me money as I drool over the work of others.
fowlmouth72
bellybuster wrote:My hats off to ya Fowlmouth, ya took a good lickin and still here. Attaboy! Shows good character.
LOl...I've got pretty thick skin. I'm glad to have gotten all the feedback. That's why I posted in the first place.
bellybuster
Allot of folks go runnin with their tail between their legs after what they call here "tough love".
Prairiepiss
bellybuster wrote:Allot of folks go runnin with their tail between their legs after what they call here "tough love".
Was I being tough?
I thought I was being nice? :mrgreen:
buckwild1
Post by buckwild1 »
my momma taught me tough love. what they show here is pretty mild to what i grew up with. And it just shows they care and have a lot of passion for what they do
fowlmouth72
UPDATE....made some adjustments to my procedure and replaced the rubber with cork from NB. Diluted my distillate from my all grain batch from run one to 40 and re ran. Peak apv from run 2 was once again 89 percent. Run 2 was then fractioned by 9. First 200ml along with 1, 2 and 9 of 9 were excluded or dumped. 3-8 of 9 were blended and cut to 120. Bitter back bite is gone and it has virtually no odor. Well see how it tastes in a month or so, but it is definitely the best I've done yet. Thx for the instructions!
bellybuster
well done, still jealous of the 89%. Was that 2 runs in total or 3
Prairiepiss
Sounds like you are on the way. :thumbup:
So peak 89%? What did the hearts come off at?
fowlmouth72
Prairiepiss wrote:Sounds like you are on the way. :thumbup:
About 80 percent.
fowlmouth72
bellybuster wrote:well done, still jealous of the 89%. Was that 2 runs in total or 3
Two
