2" column to keg
DangitBuck
2" column to keg
Post by DangitBuck »
Hey everybody I have a quick question that hopefully is easy to answer. Would soldering a 2" ferrule to my column (seen here, http://www.hillbillystills.com/Copper_t ... _p/cs2.htm ) connect to a 15.5 gallon sanke keg with a tri-clamp? Or do I have to use the whole copper pipe to keg kit from mile-hi?
This is my first time working with a keg and I've looked around on the sight and can't find a page about keg connections, thanks for your time reading this post!
Prairiepiss
Re: 2" column to keg
Post by Prairiepiss »
Search for easy flange. And everlasting PTFE gasket to go with the easy flange. :thumbup:
bellybuster
Post by bellybuster »
That piece already has a coupling attached, just slide your column in an solder
Condensifier
Post by Condensifier »
I'm going to use this "easy flange" method for the extension I'm going to make for my 3". It looks pretty clean.
http://homedistiller.org/forum/viewtopi ... =2&t=13631
DangitBuck
Thanks everybody for the help:) ill definatly try that :D
condo33
Post by condo33 »
I used the easy flange technique and everlasting PTFE gasket. Probably have a $1:25 in the whole thing and found it very easy to do.
Condo33
