I read that I need about 78-82C and the end of the run should be stopped at about 86-90*C? How's come I can't get any drops when my column temp is at 80*? I have to turn up the heat to 85* to get that tell tale broken pencil drippings.
On the other hand, this is a stripping run and I read that I need to run fast and hard, " as mush as my condenser can knock down" I have my water throttled down to about half of what I can put into the shotgun.
First 400 mL caught and separated. Collecting the rest in 1-1/2 pint (700mL) jars. Temp was at 89*C and only at 65% ABV.
Now's the time to chime in you experts! Much appreciation in advance.
EDIT/ADDITION: had a thought that maybe I need to concentrate on the broken pencil lead approach and disregard 88-90*C column temp. Watch the flow, taste test now and again, and keep collecting my 700mL jars until ABV drops off or temps start to shoot up.
2nd edit: according to the calculations on the home page, I have 20% alcohol and my wash will boil at 12* below that of distiller water which is 100*. That figures out to 88*C...which is where I start to get that broken pencil lead flow.
