DIY spiral-prismatic packing
kol2nas
Post by kol2nas »
Here is a DIY of spiral-prismatic packing that Odessit mentioned in his post http://homedistiller.org/forum/viewtopi ... g&start=15
A photo is worth a thousand words so:
A simple bench
A simple bench
Mandril
Mandril
In action
In action
How it looks when done
By changing the form of mandril, different forms of packing can be achieved.
Measurements for the optimal performance must be:
diameter of packing 1/10 to 1/12 diameter of column
diameter of SS wire 1/10 diameter of packing
Pictures were taken from the forum of like-minded people in Russia
http://homedistiller.ru/forum/index.php?topic=50.60" onclick="window.open(this.href);return false;" rel="nofollow
Thanks to Altair
Re: DIY spiral-prismatic packing
Very cool. How long did it take to manufacture that bottle of packing?
kol2nas
Post by kol2nas »
If using hand scissors then about two weeks two hours a day :)
But you can construct another simple bench to automatize that work a bit.
LearJet
Post by LearJet »
Is there a place you can just buy this stuff from?
kol2nas
Post by kol2nas »
Haven't heard of any e-store providing them. Only a few Russian folks who sell directly.
jake_leg
Post by jake_leg »
So that's what you were up to with the compressed air valve :clap:
Very cool, I wished that link in Russia had an English translation. I would have liked to read the comments.
Washashore
Post by Washashore »
Very cool, but why not use copper wire?
Coaster
Post by Coaster »
@ Washashore,
You beat me to the Keyboard. Asking the copper wire question was also my question to manu de hanoi.
Regards,
Coaster
manu de hanoi
Post by manu de hanoi »
hi,
Copper is expensive here in VN (but stainless steel is cheap) that's one reason,
other reason is that copper corrodes and that given the expense of making SPP, you may not want that
other reason is that copper is soft and that it prolly wouldn't stand the tension at a similar thickness - I'm using one of the thinnest possible wire gauge.
I put some copper foil in the columns, that doesnt mean all the column has to be made of copper.
However if you google around you'll find that some people can use copper for SPP.
F6Hawk
Post by F6Hawk »
I wonder if aviation safety wire is made of SS?
bellybuster
Post by bellybuster »
Most aviation lock wire has iron. It is mostly nickle with some copper.
I had the same thought but checked my stash to see.
Odin
Post by Odin »
kol2nas wrote:Haven't heard of any e-store providing them. Only a few Russian folks who sell directly.
For people interested in buying SPP: I am selling it.
Odin.
Maritimer
Post by Maritimer »
Bushman wrote:Very cool, I wished that link in Russia had an English translation. I would have liked to read the comments.
You can read it using Google translate. Here is a translation of the first post on the page cited, which is page 4 of the thread:
When you worked at a small pottery and firing it, so purely for fun decided to try to create one clay beads for packing. Took coriander seeds (They are ideal balls) and covered with a layer of clay, the method drazhzhirovaniya seeds. Catal blocked until a diameter of 5-6mm, the last portion of the clay added starch to obtain a porous surface (starch during firing fading). After drying, fell asleep in a thick tin can and put it in the oven on the wood, put on a little more wood and set on fire. An hour later, oven burnt and that's what happened (How to insert a picture?) Filled with water exposed to the street stood in the water for almost a month, freezing razmerzaya but not soaked. Who house gas, the problems with the firing nor any.
M
Odin
Post by Odin »
Okay, that clarifies things ...
Odin.
Maritimer
Post by Maritimer »
Hey, it's really fun looking through this forum. It's http://www.HomeDistiller.ru" onclick="window.open(this.href);return false;" rel="nofollow . If you have the Google Toolbar, just click on Translate. In fact, once you use Translate, everything that's in another language gets turned into English on subsequent uses.
M
F6Hawk
Post by F6Hawk »
Figures. I was going to check manufacturer specs on a roll or two today and see.
DAD300
Post by DAD300 »
Some aviation lock wire is annealed SS. There is a lot of fishing line that is hardened SS. But the best I found in quantity is SS mig welding wire. It comes in better sizes (.020-.036) and quantities at about $3 a pound.
A liter of "C" size SPP takes about 3.7 pounds of wire. A 2" x 30" column will take about 1.5 liters. A 3" x 30" column will take about 3.5 liters.
DSP-AR-20005
Odin
Post by Odin »
And I'd advise to make the SPP a bit more open. Easier drainage, higher possible energy input, more reflux, more SPP in its optimal working range. And some other benefits that go beyound this tread's goal & topic.
Odin.
