DIY Beam Balance for Specific Gravity Measurements
Lester
Post by Lester »
This may have been discussed here on HD earlier but I don't really know, can't find it with the search function.
Here is my method & equipment for taking the SG of the wash as it ferments. I believe my method is sound but if someone thinks otherwise please feel free to explain why.
I don't have a Specific Gravity (SG) meter & glass tube so I made a beam balance out of a piece of 3/8" alum tube about 400mm long. A bicycle spoke going through the beam works as a fulcrum. Rails for the spoke to roll on: Short piece of U-channel. The sample bottle is suspended off another piece of spoke that goes through the beam and is 50mm away from the fulcrum. A sliding weight is made from bolts, nuts, washers, etc.
Here's is my procedure for calibration:
1. Take a small empty bottle about 60~120cc and balance it off with your sliding weight. Where the beam is balanced make a mark, this is "zero".
2. Fill the bottle to the lip (you will always fill it up to here) with water and move your weight to balance the beam again. This is your 1.000.
3. Measure the length from 0 to 1.000, divide that number by 10 and proceed to mark off each increment on your beam. Starting from 0, each mark will correspond to 0.01, 0.02,......1.000, 1.010, 1.020.
To use it just fill the bottle to the lip but this time with your sample and move the weight to balance the beam again. Once balanced, you can read the SG directly off the marks you just made.
To make the tick marks on the tube permanent do a single pass with a pipe cutter. It leaves a mark but won't severe the pipe.
Since this is a ratiometric method it doesn't really matter what the actual weight of the sample is. You are just comparing your sample's weight with water's weight which is what the definition of SG is.
Notes:
It is preferable to use a small-lipped bottle so you get better repeatability of you sample size.
You can use another weight that is fixed to the long end of the beam to offset the bottle's weight. This way your sliding weight will be lighter and you maximize the use of the length of the beam.
Similarly, a beam balance can be made to read EtOH %. I will work that out some other time.
Life is not about waiting for the storm to pass, it's about learning how to dance in the rain.
Reboiler: http://homedistiller.org/forum/viewtopi ... =1&t=43653
Thermometer: http://homedistiller.org/forum/viewtopi ... =2&t=43379
S-Cackalacky
Re: DIY Beam Balance for Specific Gravity Measurements
Post by S-Cackalacky »
Sounds really interesting, but it's a little difficult to follow your verbal description and even harder to figure it out from the photo - too much other crap in the picture to know what's part of your device and what's not. Could you maybe put up some drawings, or maybe a better picture?
S-C
ozone39
Post by ozone39 »
What was the length from 1 to 0 that you divided by 10? Seems you could do the same with just a balance scale and adding weight to the side that you are getting the SG for....have two containers that weigh with the same, with the same amount of liquid in them (one with water the other with what ever your measuring) on each side of the scale...not sure, just typing out loud here...
Lester
Post by Lester »
S-Cackalacky wrote:Sounds really interesting, but it's a little difficult to follow your verbal description and even harder to figure it out from the photo - too much other crap in the picture to know what's part of your device and what's not. Could you maybe put up some drawings, or maybe a better picture?
S-C
A beam balance is similar to a see-saw on a kid's playground. If the weights of the kids are identical and the arms of the beam are of the same length then the beam will be balanced. If one kid is twice the weight of the other then he can sit halfway on the beam and it will again be balanced.
To express in mathematical terms, weight1 x arm length1 = weight2 x arm length2. If this condition is met then the beam is balanced. From the expression it can be seen that an infinite amount of weight & arm length combinations is possible. Simple ratio and proportion.
To gain more resolution for a given length of beam one arm can be made longer than the other. If that arm is longer then it also follows that the weight on that arm can be made lighter.
Taking all measurements from only one sample size, say 100ml, makes the actual weight of the sample & water irrelevant. If the sample is 109% of the weight of water then it is also the same as saying that the SG is 1.090. So by making the beam
9% longer (move the weight to this position on the beam) we regain balance, and read that off from the scale we have drawn.
I have been around long enough to have seen a lot of beam balances in use in grocery stores. They were replaced with dial scales then eventually digital ones.
Sorry for my poor English. :oops:
Lester
Post by Lester »
ozone39 wrote:What was the length from 1 to 0 that you divided by 10? Seems you could do the same with just a balance scale and adding weight to the side that you are getting the SG for....have two containers that weigh with the same, with the same amount of liquid in them (one with water the other with what ever your measuring) on each side of the scale...not sure, just typing out loud here...
Yes what you described is also possible. I just found it easier to move a counterweight than having to add or subtract water from one side.
The length is 250mm. I have deliberately made it that way but I have a hard time explaining how I did it.
Lester
Post by Lester »
When using this same method for alcohol % measurements, I am still unsure if it will result in ABV or ABW. The method described above is really just comparing weights (ABW) but then again the container's volume is constant and that is ABV. Perhaps someone with knowledge about ABV/ABW relationships can help me out with this. :crazy:
Lester
Post by Lester »
Sorry, there's an error here. The marks just made should read 0.1, 0.2........1.000, 1.100, 1.200.
Lester wrote:When using this same method for alcohol % measurements, I am still unsure if it will result in ABV or ABW. The method described above is really just comparing weights (ABW) but then again the container's volume is constant and that is ABV. Perhaps someone with knowledge about ABV/ABW relationships can help me out with this. :crazy:
The easiest way to get ABV is by doing some simple math.
ABV= (OG-FG) x 131 It's not exact, but it's very close.
ABW = (OG - FG) x 105
Or
To convert ABW to ABV, simply multiply the ABW by 1.25. So a 64% ABW alcohol would be a 80% ABV alcohol. If for some reason you want to convert from ABV to ABW, multiply the ABV percent by 0.80.
Lester
Post by Lester »
Or
Thanks for your reply Bushman. But that math implies that one has access to a Specifc Gravity meter which I don't, and so I came up with this beam balance method for taking Spec Gravity measurements.
But I am thinking more in terms of when I start getting EtOH out of my VM still because I also don't have an alcometer, (steep price tag over here). So if I take a sample and use the beam balance method described above, what will my reading be? ABV or ABW? This is what I do not yet understand although now I think the method I described will result in ABV.
