is this the right fitting for my heater element?
rager
Post by rager »
iv done my research and I think I found what I need but im a little confused.
i bought a 240v 5500w camco element part number 02363
i measured the OD of the threads and its 1 1/4. all the reading ive read is i need a 1 " NPT fitting like so .
http://www.amazon.com/Stainless-Steel-F ... t+coupling" onclick="window.open(this.href);return false;" rel="nofollow
or
http://www.stilldragon.com/adapters-and-couplings.html" onclick="window.open(this.href);return false;" rel="nofollow.
this is what i need correct?
also if i run this on 120v cuircut this element will be ok right? i know it will be around 1375w
thanks ive been slow on my build and would like to get this ordered up
Re: is this the right fitting for my heater element?
I looked for my supplier on line but I bought the one inch 1/2 coupling you show from Amazon and it works great but my price was about 1/2 what they list it for. If I find the name I will post it for you!
S-Cackalacky
Post by S-Cackalacky »
Rager, you didn't say what size your boiler is. If it's more than about 5 gallons, 1375 Watts will take a long time to heat up. My 5 gallon boiler takes just over 1 hour to come to full boil with 1375 Watts.
S-C
rager
Post by rager »
Bushman wrote:I looked for my supplier on line but I bought the one inch 1/2 coupling you show from Amazon and it works great but my price was about 1
there is this one...
and this one.. i like it because it has a hex nut . when i drill my whole in the 15 g keg ill drill it small enough so the hex will sit nice during welding
http://www.amazon.com/Parker-Stainless- ... t+coupling" onclick="window.open(this.href);return false;" rel="nofollow
i can turn these pieces down to my liking, im just want to make sure im ordering the right thing the first time. i hate doing things twice.
so i have the right thread pattern i believe ?
FreeMountainHermit
Post by FreeMountainHermit »
This for clarification.
http://www.grainger.com/Grainger/Coupli ... Pid=search" onclick="window.open(this.href);return false;" rel="nofollow
But for safety's sake I run this in my keg.
http://www.stilldragon.com/element-guar ... pters.html" onclick="window.open(this.href);return false;" rel="nofollow
FMH.
Blah, blah, blah,........
Found it! We have a Paramount Supply locally so I bought direct from the store. It was under $3.00
http://www.paramountsupply.com/products ... 200709.pdf" onclick="window.open(this.href);return false;" rel="nofollow
Prairiepiss
Post by Prairiepiss »
The threads on the element are straight pipe thread. It seals on a seal that is smashed when installed. Normally. They will screw into a NPT tapered pipe thread fitting. And if you wrap it with PTFE tape. It will seal fine.
I would go with the triclamp element guard setup. If at all possible. Suggested already.
rager
Post by rager »
thanks for the sites everyone .... just that much more reading/ studying ..
I do like the the element guard set up but if I don't go that direction I will be sure to implement safety into my design.
thanks again. ive got some reading/ drinking to do tonite
cheer yall
rager
brazenheadbeer
Post by brazenheadbeer »
I use these....
http://www.mcmaster.com/#4464k586/=p3pop1" onclick="window.open(this.href);return false;" rel="nofollow
