Mason jar thumper ?
Bigmanley2
Mason jar thumper ?
Post by Bigmanley2 »
I'm making an 8 quart pressure cooker still and wasn't going to make a thumper for it but I've read or heard somewhere that you could make a thump keg with a large mason jar for this small size still. My question is, I can make one but how safe is this Idea and would you use this idea ?
Prairiepiss
Re: Mason jar thumper ?
Post by Prairiepiss »
Have you done a search about this? I'm guessing you haven't. By the fact that you asked the question.
Short answer. No it is not safe nor big enough to use as a thumper. And the fact your building a 2 gallon still. Shows you haven't done much reading around here. It's also to small to work worth a hoot. And will make learning to make cuts a lot harder.
meatheadinc
Post by meatheadinc »
Glass thumpers most consider unsafe.
You may find cuts a little difficult with small boiler.
Stainless I hope.. not aluminum.
Have you removed the rubber/ silicon seals ? If not replace with Teflon.
What goes up must come down, but a condenser helps
Bigmanley2
Prairie piss I sold my the big still I built so I'm looking for something to make a small still out of and the pressure cooker was my first thought because I have it and wouldn't take much work to build. Looking for something smaller around 5 gallons maybe, something I could do in my kitchen or garage, and I've done a lot of reading on here for the last few months but I can't remember everything at once, just not that much memory
Truckinbutch
Post by Truckinbutch »
:roll:
OBX Phantom
Post by OBX Phantom »
Bigmanley, Take a look on E-bay at SS milkers. They are 5-6 gallons and already have 2 holes in the lids so they are easily modified to make a still. The biggest problem with them is that also have a rubber gasket but that is easy enough to fix. I have one of these as my thumper, and it works great.
If you are not living on the "Edge", then you are taking up too much space!!!
drinkingdog
Post by drinkingdog »
Bigmanley2 wrote:Prairie piss I sold my the big still I built so I'm looking for something to make a small still out of and the pressure cooker was my first thought because I have it and wouldn't take much work to build. Looking for something smaller around 5 gallons maybe, something I could do in my kitchen or garage, and I've done a lot of reading on here for the last few months but I can't remember everything at once, just not that much memory
One thing nice about this forum is there is the HD Google search button top right center. So you don't have to remember everything. You do have to take some of your own time though to read more. Also may I suggest that when you do a search to read more than one post because of the age of the post or the fact that some of the less experienced people here sometimes post the wrong answer.
Reason: Fixed quoted text...
My Grandpa used to say. Don't argue with an idiot, because he will just drag you down to his level then beat you with experience.
He also used to say. I didn't say it was your fault. I just said that I was blaming you.
DD
Husker
Post by Husker »
Bigmanley2 wrote: Looking for something smaller around 5 gallons maybe, something I could do in my kitchen or garage
One thing that also works well, is the cheap 5g boil pots, with a rim that sticks out (flat), and a flat lid extending out to that rim. Pretty easy to seal these up with flour paste, and a few black paper clip things. This type pot, or something similar: http://www.homebrewing.org/product.asp? ... QgodAUQADw" onclick="window.open(this.href);return false;" rel="nofollow I found that one in 5 seconds, googling 'cheap cooking pot'.
I think rad has instructions on making a small stovetop still, with a cookpot similar to this. I know there are many theads with pix, where people made them like this. I know a lot of people 'think' the pressure cooker is a good thing to make a still out of, because the lid 'locks' down, and there is already a hole in the lid. However, usually the pressure cooker is not the ideal boiler for a still.
H.
ShotnVA777
Post by ShotnVA777 »
OBX Phantom wrote:Bigmanley, Take a look on E-bay at SS milkers. They are 5-6 gallons and already have 2 holes in the lids so they are easily modified to make a still. The biggest problem with them is that also have a rubber gasket but that is easy enough to fix. I have one of these as my thumper, and it works great.
Thanks for that stainless steel milker idea! Damn! This is guna work PERFECT!!!
Anyone planning on making a thump keg for a 5 Gallon Pot Still, you need to check this site out...
http://hambydairysupply.com/xcart/produ ... 228&page=1" onclick="window.open(this.href);return false;" rel="nofollow
They say 1/3 the pot size right? Well 1/3 of 5 is 2.44444444XXXX, SO I round it off to 2.5 and that's EXACTLY what the size of that milk container I just provided a link for! Hope this helps somebody, keep boozing and cruising (in the woods of course!) :Shh: :wink:
Hound Dog
Post by Hound Dog »
1/3 of 5 is actually closer to 1.66666666667. The 2.5 number is half of five. But....... that is an even better size for your thumper.
Using Google Search
