floaties
sunshine1101
floaties
Post by sunshine1101 »
been saving stripping runs of UJSSM pulled jars out of the cabinet and one of them ( i believe it was mostly tails) had some floaties suspended in the jar. it didnt smell bad so i filtered it through a coffee filter into the boiler with the rest of the low wines and ran it slow. when the filter dried it had green specs in it. is this normal?
coffee filter.jpg (36.33 KiB) Viewed 1084 times
15 gallon keg boiler
copper pot still head
Liebig condenser cooled with a recirculating pump in an ice bath
http://homedistiller.org/forum/viewtopi ... 50&t=44696
Fastill
Re: floaties
Post by Fastill »
I've had them running hard into late tails. They will eventually settle to the bottom of the jar. I Didn't add that jar into the feints jar. just dumped it out.
dakotasnake
Re: floaties
Post by dakotasnake »
sounds like just the green patena from the copper, must not have used it for awhile, keep that beast bizzy and it wont happen. just filter and run it again.
today marks the dawn of a new error.
sunshine1101
Re: floaties
Been used weekly for the last month. Was surprised to see the green. But that was actually the first run of the year after it sat fpr a few weeks. Whats the best solution to clean with in that case?
Lazarus Long
Location: I have so many posts my counter started over.
Re: floaties
Post by Lazarus Long »
When I made my column, I made it so the column could be removed, turned upside down, all openings temporarily capped, and the column filled with vinegar for a soak. After an hour pour the vinegar back into a container for later soaks.
What He Said
Re: floaties
Post by What He Said »
Clean with tomato juice. Use copper wool and a snake rope to brush out your tubing. You might have PH issues causing excess oxidation. The rope and wool will get into places vinegar just can't clean alone.
