Can moonshine make you blind?
I had my first run last night, i distilled 5 gallons of wash and collected quite abit of shine, i dont have a themometer on my still so i was just going on judging it, i threw out 200 mls of the first stuff that came out of my still every run(i was only running 16 qaurts at a time, anyways i have my shine but im kind of afraid to enjoy my product because i am worried of all the stories i have heard about moonshine making people really sick... Will it or will it not? Any help will be appriciated thanks!
Re: Can moonshine make you blind?
solid research will ease your mind. Just asking the question will undoubtedly get many replies, all of which are opinion. research will get you facts.
sorry, kind of a useless post but.....
You would need to drink a lot of the stuff you threw away. To get that sick. At most since you didn't make cuts. You will have a hangover. Making proper cuts would remove the heads and tails. And even hangovers.
But you could collect all that comes off the still. And you could drink it. With only a bad hangover. It wouldn't taste good.
And sounds like you have a pot still. Do a thermometer would have done you no good.
Learn about making proper cuts. The novice grid to making cuts. Can be found in the must read new distiller reading lounge.
- sambedded
Bad moonshine can give you nasty hangover but it virtually impossible to get blind unless you are doing your wash from a wood
Methanol metabolizes as formic acid, which can screw up the central nervous system.
Proper cuts eliminate this possibility.
Would you go blind if you drink beer or wine? No!
When you distill beer (grain) or wine (fruit) you concentrate the good stuff: ethanol, and dispose of much of it's hangover causing cousins.
Drink only the good smelling and tasting stuff in the middle of your run and throw everything else back in your next run, sans the foreshots that you pitch or kill weeds with.
Thanks everyone
- sambedded
Yes, butwoodshed wrote:Methanol metabolizes as formic acid, which can screw up the central nervous system.
Sugar washes have almost no methanol at all. Grain mashes have very little. Fruit washes have some noticeable amount of methanol but still not enough to do any serious harm.
Yes but the cure for methanol poisoning is ethanol. So if there is some present you are getting the poison and the cure.sambedded wrote:Yes, butwoodshed wrote:Methanol metabolizes as formic acid, which can screw up the central nervous system.
Blindness and other ailments associated with moonshine from the past. Was from things that should not have been used to make it. Like lead solder, old radiators, or any other cheap crap they could build a still from. Also they would add things to the moonshine. To up the volume and make it seam like it was a higher ABV then it was. So they could make more money. Solvents and cleaners and whatever else they had on hand. Not to mention the propaganda handed out by the wonderful government. To scare people away from it.
- NZChris
If you didn't properly clean any flux out of the still and condenser you might get pretty queasy.
- Condensifier
Plus ethanol is the antidote for methanol so ...
I thought I just said that.Hobby wrote:Plus ethanol is the antidote for methanol so ...
- Condensifier
Yup you did, I guess I read too fast sometimes and you used "cure" not "antidote" so I missed it. Oh well.
I got pretty blinded on it last night but I'm fine today...
Lead, follow, or get the **** out of the way!
- sambedded
Prairiepiss wrote:I thought I just said that.Hobby wrote:Plus ethanol is the antidote for methanol so ...
Ethanol is an antidote, yes.
But to cure methanol poisoning you have to keep some level of ethanol in your body for a few days.
so if you constantly drunk - you are safe
Well usually the ones that don't make cuts. And like to drink it. Are only doing it for one reason. But then again they probably need to worry more about their liver. LOL
Under the right circumstances, methanol can make you blind, but so can a pencil.
heartcut
W. H. Auden
W. H. Auden
- LWTCS
I bring a bottle to a feller that throws a wonderful party about three times a year.
When I met him he explained that his pap was a driver for an outfit when he was a young lad.
He used to help his pap load the trunk of the car.
He said them fellers used to add battery acid to distort the bead....He even kinda whispered as he explained.
His pap knew it was shameful but he explains that times were hard for black folks back in 1950s Alabama and work was work.
He is now a driver,,,,,,for a trucking company.
I bet his pap could tell lots of stories
- Da Yooper
WELL Jake, how did it taste? You got blinded yes it happens sometimes.but how did it taste?
Fail to plan == plan to fail
- drinkingdog
Going blind from methanol from your properly made moonshine has about the same chance of going blind from doing what your mother told you not to do. Being young and never thinking mom would steer me wrong I figured I would quit doing it when I had to get glasses.
if you follow the directions given here in making proper cuts you will avoid hangovers and produce something pleasant to drink. Like I said earlier the chances of going blind from drinking properly made moonshine is about the same as spanking your monkey.
My Grandpa used to say. Don't argue with an idiot, because he will just drag you down to his level then beat you with experience.
He also used to say. I didn't say it was your fault. I just said that I was blaming you.
DD
DD
I was merely pointing out what methanol does. Never said it will make you go blind but the possibility is there. My brother could be stung by a thousand bees and suffer for a while. One can kill me.
Just sayin
Just sayin
Jake, all you need to do is throw a carrot in your wash every time.....problem solved.
Carrot cake shineOlympicMtDoo wrote:Jake, all you need to do is throw a carrot in your wash every time.....problem solved.
IE
Well guys i drank it and went blind for a couple hours
it was actually really good! I have another question, i have a bottle that smells like nail polish remover, should i chuck that stuff or is it okay? Thanks
- Location: big ole'island on the West Coast Canada, soon to be underwater when the big one hits
I have one as well... Its called nail polish remover. Wife loves it. Works like a charm.
- T-Pee
Chuck it. That's foreshots (poison/acetone). Or let your wife use it on her nails.JakeWareham wrote:...i have a bottle that smells like nail polish remover, should i chuck that stuff or is it okay? Thanks
tp
Handy Links:
The Rules We Live By
GA Flatwoods sez
Handy Links:
GA Flatwoods sez
- Tater
only if you play with yourself while drinking it.
- Truckinbutch
Tater wrote:only if you play with yourself while drinking it.![]()
- Truckinbutch
I've never witnessed anyone going visionwise blind . I have seen many people judjementally impaired to the point of being blind in judgement . Take home what looks like a 10 and wake up next morning with a 2
