4500w vs 5500w
- MoonWhisky
4500w vs 5500w
I have a 4500w low watt density heating element now and was wondering if could use a 5500w medium watt density or will it scorch the wash, it's a 8 gallon pot still
MW
Bubble Bowl Column - http://homedistiller.org/forum/viewtopi ... 17&t=49873
Discuss Ideas & Designs on Plates - http://homedistiller.org/forum/viewtopi ... 17&t=49935
- sambedded
Re: 4500w vs 5500w
What does make you unhappy with the 4500Watt element?
- MoonWhisky
Re: 4500w vs 5500w
Nothing really but I will be getting a bigger pot most likely a 15.5 gallon keg in the future and till then I was wondering if a 5500w medium watt density will burn up the wash. I only have 13.5 inches to work with right now or I'd have a 5500w ulwd ripple element.
MW
- T-Pee
Re: 4500w vs 5500w
You don't have to turn it all the way up, ya know.
tp
tp
Handy Links:
The Rules We Live By
GA Flatwoods sez
Handy Links:
GA Flatwoods sez
- sambedded
Re: 4500w vs 5500w
I'd use 5500Watt ULWD ripple elements. It fits in 13".
- acfixer69
Re: 4500w vs 5500w
+1 They are "Like they were made for Stillin in"sambedded wrote:I'd use 5500Watt ULWD ripple elements. It fits in 13".
AC
- MoonWhisky
Re: 4500w vs 5500w
What's the brand name and where did you get it please. All my local hardware places don't have one
MW
- acfixer69
Re: 4500w vs 5500w
http://www.amazon.com/Camco-02963-Screw ... a+low+watt" onclick="window.open(this.href);return false;" rel="nofollowMoonWhisky wrote:What's the brand name and where did you get it please. All my local hardware places don't have one
There you go
AC
- MoonWhisky
Re: 4500w vs 5500w
Are most rippled elements ulwd because there's on at my local ace hardware but it doesn't say ulwd just says 5500w and looks just like the one from Amazon but the brand name is sandhog
MW
- Jimbo
Re: 4500w vs 5500w
ultra low watt density just means the watts per centimeter of length is low. In the case of the Camco one, its curvy and folded back twice, so makes 4 trips back and forth. If the one you see is just as long and is 5500 watts, they watts per centimeter will be low like the Camco one.
I dont think I stated that as clearly as I could, if you dont understand smack me upside the head and Ill try again.
- MoonWhisky
Re: 4500w vs 5500w
No I understand just I don't like buying something in less it clearly states what it is and the sandhog doesn't say anything but 5500w but it is the same length and folded back and rippled so I will be going with that one instead that way I can keep everything the same when I decide to upgrade to a larger broiler
MW
- MoonWhisky
Re: 4500w vs 5500w
My element housing is drilled out for 1-1/4 this is the same size right?
MW
- Red Rim
Re: 4500w vs 5500w
I believe these are one inch. There are some makes that are 11/4 but most are one inch. It will say right on the package at the hardware store if that is the route you take.
- MoonWhisky
Re: 4500w vs 5500w
Yes most are 1" but the hole size needs to be 1-1/4" to slide the element through. And was wondering if the 02963 element was the same mounting hole diameter
MW
- acfixer69
Re: 4500w vs 5500w
The camco element will fit thru a 1" half coupling easily. I have 2 of them.
AC
AC
- MoonWhisky
Re: 4500w vs 5500w
Excellent! Because I already have all the hardware for a 1" heating element
MW
