Salt, water, or nothing???
- MoonWhisky
Hello I just bought some 1/4 (6mm) copper tubing coil and will be making a double coil for a 2" reflux about 5 foot tall questions is will I need salt or water or nothing at all to make the coil I've seen people doing it with nothing in the tube is this okay or will it kink up I have a 5/8 (15mm) bar for the inner coil and I guessing something like paper or card board can be used to make the second coil back over. Please help a noon out
MW
Bubble Bowl Column - http://homedistiller.org/forum/viewtopi ... 17&t=49873
Discuss Ideas & Designs on Plates - http://homedistiller.org/forum/viewtopi ... 17&t=49935
- T-Pee
Re: Salt, water, or nothing???
Take a bit of a read and make a choice with what you think would work best for you: http://homedistiller.org/forum/viewforum.php?f=87
tp
tp
Handy Links:
The Rules We Live By
GA Flatwoods sez
Handy Links:
GA Flatwoods sez
From what I have seen, it depends on the type of tubing you have. If it's the cheap Home Depot ice-maker supply line, it's going to crush when you look at it. If it's the heavier tubing designed for AC systems, you can probably wind with no filler.
For the cheap tubing, I suggest filling with water and freezing it. Ice.
- MoonWhisky
Silly question but the ice expansion, will it crack the tubing or is this not a problem?
MW
- kaziel
If you will bring it to below zero slow it will have time to expand via openings of tube. If you have more tube then you need try it (winding) with nothing first. I'm a guy that has two left hands and I went empty tube and it was good to go on first time. I'm trying to get every one to wind coils from 304 SS flexi tubes (you can find coil like that in topic in my signature) it's much easier then cooper and it's a least as efficient as cooper one. Fell the cooper and go slow.
Vodka consumed wisely is harmless even in large amounts.
My all stainless 2" VM still
My all stainless 2" pot still with Dimroth condenser SS Pot Still
My malt mill - two roller - DIY
My keggle - mash/filter tun
- MoonWhisky
I tried it with nothing in the tubing and it instantly kinked
I have it in the freezer with water and closed ends I'm scared the wall thickness is .030"
MW
the SS flex tube works great, i'd suggest going that, way easy
- MoonWhisky
what diameter SS tube and how long should it be for a 5 foot column
MW
- firewater69
I wrapped a double coil, 0.250 o.d. x 0.028 wall. i bent the first coil around a steel rod 0.937 diameter then wound it back over itself. after that i grab the outer coil and twist backwards to seperate them a little. it fits a 2" column without touching the sides. i used nothing inside the coil.
- MoonWhisky
As soon as any Bend begins is starts to kink I don't understand why this is happening
MW
- firewater69
Didn't you say you were trying to bend around a 5/8" rod? That wont work well for you, find something closer to 1.00".
Kazeil, great coil! I have to check out your setup a bit closer, looks nice. You say you used 3/8"? That would be best but is a little harder to find than 1/2". I used Gastite brand gas line that has a removable yellow cover over the stainless pipe. It is very thin walled and easy to work with. Mine is in a 3" but could probably fit in a 2". You can also just loop it down and up and twist it. It does not have to be a coil shape it just needs to circulate water to cool the vapor. The stainless flows great, does not kink and you can make your condenser in less than a half hour, five minutes with the twist design.
Using Google Search
Using Google Search
- MoonWhisky
Okay I will look around when I bend it it starts to flatten out is this normal
MW
- firewater69
A little flattening is not a dealbreaker, but as long as its not kinked it'll work fine.
- ga flatwoods
It would probably help if you were to take off the hockey mask! Bend and flatten the ends after filling with water and yes freezing helps.MoonWhisky wrote:Okay I will look around when I bend it it starts to flatten out is this normal
Ga Flatwoods
much better looking avatar.
I am still kicking.
Ga Flatwoods
I am still kicking.
Ga Flatwoods
- firewater69
Love the avatar Flatwoods! I haven't thought about that in years.
- MoonWhisky
MW
- MoonWhisky
Hoping that should fit nicely tho
MW
- firewater69
- MoonWhisky
What diameter SS flex hose is used for a 2" column
MW
3/8" works best. It's cheaper than copper too...MoonWhisky wrote:What diameter SS flex hose is used for a 2" column
- MoonWhisky
Where do you buy the SS flex hose from I'm only seeing fuel line for like cars.. I need something more for a dishwasher right? Would home depot/Lowe's have it? Or is it a online thing?
MW
- kaziel
I bought mine in Solar power system store (solar water heating) online, but that's in Poland.
You are looking for gas line as in natural gas, not gasoline. It is gas pipe. Go to plumbingsupply.com and check out gas flex connectors for appliances. They have ones in all sizes with connectors on the ends. I used straight up gas piping by the brand name of Gastite. It is used to run gas in houses in this area.MoonWhisky wrote:Where do you buy the SS flex hose from I'm only seeing fuel line for like cars.. I need something more for a dishwasher right? Would home depot/Lowe's have it? Or is it a online thing?
Using Google Search
Using Google Search
- DAD300
SS Flex Gas Pipe (corrugated SS Pipe) used for the appliance to wall connection, solar hot water heaters, Ace Hardware, Home Depot, Lowes, Ebay...
DSP-AR-20005
DSP-AR-20005
Amazon. most common brand is Dormont
http://www.amazon.com/New-DORMONT-10-31 ... t+gas+flex" onclick="window.open(this.href);return false;" rel="nofollow
- MoonWhisky
Thank you everybody for the helpful input!
I made a new coil tonight and much happier with this I kinda added a custom cold finger... More like a "NUB"
MW
