Keegle with false bottom
- kaziel
Hello, I want to share one of my lates DIY projects. Since recently I've stated to make only AG (or partial AG) mashes I decided to make something for mashing and filtering in same pot - rather than using two separate vessels. I got lucky and found cheap 50l SS keg. using a grinder I've cut this open.
I've used up the blades for this. Thank using step drill I made a hole ~20mm and add 2x 1/2" stainless fitting, some teflon tape and silicone O-rings . From outside I've add stainless spring washer and 1/2" stainless ball valve with PTFE seal and stainless hose barb. Spring washer was mandatory since whuti this it was hard to make whole connection safe for turning around.
Next I've bought stainless strainer from Ikea and added cooper fittings. Strainer is 25cm diameter, connection is done loosley (can be disassembled). Elbow part is longer than needed to create small presser on the strainer from the top securing movement of false bottom while I'm steering mash (can event hit cooper pipe without any issues).
Happy with results so far. Make few runs on this setup and works really good. Also amount of dead space is small ~1l. Previously I was using bazooka screener and on big mashes it got "squished" by grains and flow was really poor. Also hitting with mash spoon was problematic.
Vodka consumed wisely is harmless even in large amounts.
My all stainless 2" VM still
My all stainless 2" pot still with Dimroth condenser SS Pot Still
My malt mill - two roller - DIY
My keggle - mash/filter tun
- Demy
Re: Keegle with false bottom
It is a system that has been used for many years in the homebrewing field, well tested. Good job
- kaziel
Actually it is not so popular in my part of the world. I've got inspiered by one of YouTube videos about homebrewing. Next possible improvement is to add grain basket and maybe pump system.
NormandieStill
I recently (well... not so recently now) built a RIMS system using the modular components from my still.. Currently rebuilding my controller to give me a PID to control mash temperature through the RIMS tube.
- kaziel
Perfect read!!! Thank you very much.
